Pre 84 Trucks 1st gen pickups
81 pickup multiple questions
Old Jan 21, 2013 | 06:50 PM
  #81
parkerst02's Avatar
will a ifs steering gear box work on a sas? also what would be a good paint job ya'll think would look good on it
Old Jan 21, 2013 | 07:49 PM
  #82
travis_h's Avatar
Ya you use an ifs box for your high steer. And for axles if your going to go chevy for an upgrade your better off going 1 tons. Especially if you going 40's +. If you go chevy 1/2 ton your probably better off staying toyota and building them. Just my .02
Old Jan 21, 2013 | 11:59 PM
  #83
parkerst02's Avatar
Yeah true to holding the 40+ what about rock wells and how difficult is it on converting it?
Old Jan 22, 2013 | 05:33 AM
  #84
travis_h's Avatar
I think the rockwells are a bit overkill. I would just stay with your stock toyota axles for now and start saving money for building them or D60 front and a D60 or 14blt rear. I had rockwells under a 75 chevy I built strictly for mud with about 20" lift. Ended up selling the truck before it was finished. They are just huge axles and the truck was not even close to practical.
Old Jan 22, 2013 | 07:22 AM
  #85
parkerst02's Avatar
Yeah figured I'd leave the Toyota til they break get 3/4 ton or one ton but isn't 3/4 front axles the same as half ton just thicker?
Old Jan 22, 2013 | 07:52 AM
  #86
parkerst02's Avatar
What kind of clutch and pressure plate do i use
Old Jan 22, 2013 | 07:58 AM
  #87
travis_h's Avatar
3/4 ton front if its a D44 is the same as a 1/2ton just with 8lug outer's I would find a D60 if your looking for bigger stronger. Maybe look at these clutches http://www.marlincrawler.com/clutch/heavy-duty
Old Jan 22, 2013 | 08:05 AM
  #88
parkerst02's Avatar
Is that for 350 to Toyota 5 speed
Old Jan 22, 2013 | 08:12 AM
  #89
toastyjosh's Avatar
I think this is what your looking for.
http://www.advanceadapters.com/categ.../0/0/0/0/80/0/
As far as tires, if your not running this thing on the road. Find some 35s to 37s stuff them in there. You will need wheels with some backspace or wheel spacers.
Then just cut up your fenders to make them fit. Or buy some junkyard springs, take out a few extra leafs and out them in the front and back.
Old Jan 22, 2013 | 08:47 AM
  #90
parkerst02's Avatar
I have the transmission adapter i need the clutch set up
Old Jan 22, 2013 | 09:55 AM
  #91
travis_h's Avatar
Oh no sorry. You need a chevy pressure plate and flywheel and a toyota clutch disc then
Old Jan 22, 2013 | 10:22 AM
  #92
parkerst02's Avatar
Which disc though
Old Jan 22, 2013 | 05:20 PM
  #93
parkerst02's Avatar
Well got most of my 3" body lift on today having problems with the back ones though. Went got just about everything that is needed. Goin with the 9." Somethin clutch disc and 10" chevy pressure plate. All i need is power steering gear box and a flywheel and I'll be ready to put it together. Hoping the drive lines are close to right
Old Jan 22, 2013 | 05:32 PM
  #94
travis_h's Avatar
Sweet deal. Hope to see it come together soon.
Old Jan 24, 2013 | 04:11 AM
  #95
parkerst02's Avatar
Travis what exhaust did you run it
in yours
Old Jan 24, 2013 | 04:28 AM
  #96
travis_h's Avatar
in yours
I ran 2 1/2" dual exhaust into two mufflers and dumped them in front of my tires. I have a set of ceramic coated block hugger headers. And my mufflers are custom built by a friend who does circle track stuff. They have a very unique sound to them that I like. I bought a few sticks of pipe and some u bends and made it myself. There are some pics on my build thread I think.
Old Jan 24, 2013 | 04:53 AM
  #97
Crimson Yota's Avatar
Originally Posted by kawazx636
I agree with Travis, if you don't have fab skills accompanied by mechanical skills then the swap probably isn't for you. And like he said, it's preference. I too enjoy watching these old trucks get resurrected. The only thing I can't stand is when somebody hacks up a perfectly good bed. I've been searching for a good shortbed on the mid east coast for over a year while I watch people on here "modify" and destroy them wheeling.
Couldn't agree more.. But I've been searching for a clean Longbed.. pretty difficult.
Parker, I don't think your truck is ugly at all. Looks like it has a lot of potential to be a beautiful truck. More pictures are always welcome.
Old Jan 24, 2013 | 07:22 AM
  #98
parkerst02's Avatar
I was wondering if regular headers would work but i don't think they will. So ifs gear box is what i need even if i don't use high steer? And it ain't that its just that ugly just a lot of rust
Old Jan 24, 2013 | 07:47 AM
  #99
4Crawler's Avatar
If you are keeping the stock push-pull steering, you'll need an '85 or older power steering box:
The '86 and later IFS boxes will only work if you swap to crossover steering:
Old Jan 24, 2013 | 09:35 AM
  #100
parkerst02's Avatar
Ok thanks so i need to find a solid front axle with power steering
