22re won’t warm up completely
Hey guys, I’m having an issue with my truck not warming up to operating temperature, on the highway, the gauge just creeps over the white line and in the city and at idle, it goes up to about 1/3 but never reaches up to operating temp like it used too, changed the thermostat, any ideas or thoughts ?
Thanks !!
Thanks !!
About 1/3 to 1/2 up the gauge is what many people see when the engine is up to operating temperature with these gauges.
Your gauge is definitely on the low side.
Now we need to figure out if the engine actually running on the cool side, or if the gauge not reading accurately.
Do you happen to have an infrared thermometer gun?
If you do, you can point it at the thermostat housing and the top of the radiator to get an idea of how hot the coolant is.
Which thermostat did you use? Toyota says it should be rated at 88°C or 190°F.
That’s correct I used a 190, I don’t have the IR thermometer, but I will get one, what temperature should the radiator and tstat housing be at ?
thanks
thanks
This is good too to confirm gauge/sender in truck is correct, it was the right size for a 4wd stock '92 radiator:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
When my truck wouldn't warm up I put a 195 degree thermostat in and put some cardboard in front of the rad just to get some warm air in the cab. You should turn the rad fan by hand and see if it catches or if it's locked up that's caused some issues for me
Nice find, Paul22RE!
Comparing good and bad fluid coupling aka fan clutch:
https://www.yotatech.com/forums/f199...l#post52229129
cabot
Dec 7, 2018 09:09 AM
Mason Edmison
Jul 7, 2018 08:03 AM
