1990 4runner lift/tyre question .... from Romania
Old Jan 12, 2007 | 01:30 PM
zozoka's Avatar
Hello
Today i found this great forum.
I live in Romania, and i own an 1990 Toyota 4Runner 3.0 V6, manual transmission.
The car has 152.000 km.
I know the tyre/lift theme was discussed many times here, i read numerous post , and i think i found the proper combination , but please correct me if something is wrong.
I plan to put 33x12.5x15 Cooper Discoverer S/T tires on Eagle Wheels.
Wheels options are : 15x10 with BS 3 5/8, or 15x8 with BS 3 1/4. (must to buy from Germany, becouse not available here)
http://www.americanwheel.de/a19724-f...-5-r15-at.html
As for lifting , i was thinking about the OME suspension kit :
http://trdparts4u.com/PD-4RUNNER-OPT....aspx?MakeID=1
In front i plan to lift an extra 1 or 1.5" from torsion bar too.
Eventually i will buy this heavier torsion bars :
http://www.trdparts4u.com/PD-OME303003.aspx?MakeID=1
Can you please advice if the tyres will have enough clearance with the 15X10 or 15X8 wheels ?
The car will be used ~ 10% offroad
Thank you
Zoli
PS. Sorry for my bad english....
Old Jan 12, 2007 | 01:43 PM
reggie 00's Avatar
Tire size you plan on running should be fine. I am not sure of the back spacing, still a little soft on that as of yet.
As far as the bad English. You do your self an injustice. It was pretty good. There are way more people who live here that would not have been as half as coherent as you were.
Oh ya Welcome to YotaTech.
Nice ride
Old Jan 12, 2007 | 01:55 PM
4Crawler's Avatar
Get more backspacing on the wheels, no wider than 8" or better yet, find some 33x10.50 tires and keep the stock rims:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old Jan 12, 2007 | 10:38 PM
zozoka's Avatar
Thank you for reply
I will try to find some 15x8 wheels with 4" BS , but it's hard to find here in Romania, even in Germany.
If i use the 15x8 with 3 1/4 BS will have tyre clearance problems ?
The 15x10 has bigger BS 3 5/8, but as 4crawler posted , is better the 15x8.
I don't want to go with the stock wheels, i want to change to chrome wheels.
Thanks
Zoli
Old Jan 13, 2007 | 09:58 AM
4Crawler's Avatar
The wider you go the more likely the chance of rubbing up front. Less backspacing = wider, wider wheels = wider, wider tires = wider. If it rubs and not that bad, you can trim the fender where the tires rub. If it rubs bad, you can add a mild body lift to raise the fenders up away from the tire.
Old Jan 13, 2007 | 10:07 AM
zozoka's Avatar
Thanks 4crawler
I will go with the 15x10 wheels....and will see. If it rubs bad, than i will add a BL too.
I will be back with pictures.
Zoli
Old Jan 13, 2007 | 10:10 AM
aviator's Avatar
No advice on the tires for you zozoka but welcome to the family, and don't worry your english was good. Reading and posting here will help it get better and better.
Prosit! Aviator
Old Jan 13, 2007 | 10:14 AM
4Crawler's Avatar
A 15x10 w/ 3-5/8" b/s will stick out wider than a 15x8 w/ 3-1/4" b/s:
- http://www.4crawler.com/Diesel/Tires...ningTrackWidth
The more the track width, the more chances of rubbing when the front wheels turn side-side.
Old Jan 13, 2007 | 12:32 PM
zozoka's Avatar
Good link, thanks....I go with the 15x8
Reading some posts about the gear ratios, now i'm concerned about that.
I think in my 4Runner i have the 4.56 gear (1990 V6, manual transmission).
Will i have a big power loss, and bigger gas consumption ?
Should i change gears in differentials, or will be fine ?
Thanks
Zoli
Old Jan 13, 2007 | 12:55 PM
Tacoclimber's Avatar
Thanks
Zoli
If you have the 4:56's, you should be fine running 33's. I have 4:10's and 285/75R16's (33/11.50's) and I do fine. You shouldn't notice a huge change...
Welcome to YotaTech!
Old Jan 13, 2007 | 01:01 PM
zozoka's Avatar
I checked right now in the car, and i have the G285 code for gear.
As i saw it means G - 8" gears , 28 - 4.300 gear ratio , 5 - 4 Pinion, Limited Slip.
Produced in Japan, i think for european market...
Zoli
Old Jan 13, 2007 | 01:34 PM
You'll still be ok with 4:30's... Like I said, I'm running 4:10's and although I'm not winning any races off the line, it's not a dog, either.
You also have a manual, which makes it even better...
Old Jan 13, 2007 | 01:48 PM
zozoka's Avatar
Thanks Tacoclimber.
It seems all clear now.
Next week i order the OME kit+ Torsion bars + SDORI 1.5" Ball Joint Spacers + SDORI Custom 1" Coil Spacers
Also i order the 15x8 wheels with 33x12.5z15 Cooper Discoverer S/T tyres.
Zoli
Old Jan 13, 2007 | 01:51 PM
Thanks Tacoclimber.
Zoli
Very cool... If you can, post up pics when you get it all done. I would imagine that there aren't a lot of "built" Toyotas in your neck of the woods...
Old Jan 13, 2007 | 11:04 PM
zozoka's Avatar
I will post pics, from the whole process.
And you have right, not many "built" Toyotas here, in fact mine is the only 4runner in our city, and i think is not more than 50 in whole country..
Old Mar 13, 2007 | 01:42 PM
bodo4runner's Avatar
another 4runner from romania,tg-jiu
MMA_Alex
25
Apr 18, 2017 05:07 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87turboPA
Jul 12, 2015 07:49 AM
madxman21
Jul 9, 2015 10:26 AM
ptb12
Jul 5, 2015 01:49 PM
