GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
CB Install in ashtray...
Old 01-24-2008, 11:37 AM
Vohaul's Avatar
Hi all,
just got a new cb...and i remember finding a how to post with pictures of someone's ashtray install in the 3rd gen truck / 2nd gen forerunner. Now ive searched for it but cant find it...
could someone if they remember where it is, point me in the right direction
Thanks
Paul
Old 01-24-2008, 11:45 AM
desertyodaboy's Avatar
whats a forerunner?? is it Chinese or something
Old 01-24-2008, 11:54 AM
Elvota's Avatar
I have one in my 4Runner... is that close enough?
It's a Uniden 510XL. Pretty much slid right in once I Dremelled out the rear of the dash pocket. It will depend on what size your CB is on whether or not it will fit.
I also got a 90 degree adapter from Radio Shack for the antenna cable at the back of the unit to reduce clearance issues.
Old 01-24-2008, 12:26 PM
nice garmin....thats what i want
Old 01-24-2008, 02:16 PM
Brenjen's Avatar
I've seen several installed in the ashtray & I saw a write-up about how to do it, it was simple & straight forward; I think the writer said they had to cut the plastic in the back after removing the tray but it wasn't a crazy mod or anything. If I run across it again I'll post up.
Maybe this will help, it's not the one I was thinking of but the FJ80 is nearly identical to the 4Runner:
CB Install
Old 01-24-2008, 02:32 PM
Vohaul's Avatar
Oh, I'm sorry, 4runner....I own a "pickup" so thank you for correcting me
thanks everyone else for the input
Cheers
Paul
Old 01-24-2008, 03:04 PM
elripster's Avatar
Here's mine.
Frank
Old 01-24-2008, 06:59 PM
80W90's Avatar
you should use a SWR meter and tune your antenna. also to place the antenna in an optimum ground plane location. if you operate it when its high swr, you can smoke your radio. an ideal swr is 1.1
Old 01-24-2008, 07:04 PM
b.miller123's Avatar
A "forerunner" is the guy that doesn't hear you say "fore!" on the golf course and goes running out of the way at the last second
Old 01-24-2008, 07:33 PM
Vohaul's Avatar
well, the truck already had a cb in it.....has a permanent roof mounted base that you can screw on the wilson 1000 antenna and 4 ft whip antenna...sucks when you foget in parkades specially cos the truck itself seems to barely get under the roof joists
the original cb ( a realistc) blew up....doesnt transmit or recieve anymore...so i got a uniden...this one fits in the ashtray location...
where does one get a swr meter anyway...can you buy them from the source / radio shack?
Old 01-24-2008, 08:21 PM
80W90's Avatar
this is why you need to use an swr meter. the same thing will happen to your new one.
if the existing equipment is old, replace it.
use 18' of RG-8x (a.k.a. mini 8) coaxial cable, and a fender mount, with a 102" whip. you can use RG-58, which is cheaper, but you will get longer life and better results with the mini 8.
you can buy a swr meter at radio shack for 20 bucks. instructions are included. or, i can explain it after you get it, if you dont understand.
or, if your radio shack doesnt carry it, John at http://cb-shopper.com/ will help you get every thing you need for any application
Old 01-25-2008, 03:11 AM
rocket's Avatar
Heres some ideas...
https://www.yotatech.com/forums/f97/cb-install-3rd-gen-truck-2nd-runner-52446/
https://www.yotatech.com/forums/f97/...ng-new-127528/
edit:
I almost gave up searching for this one but patience and persistence paid off.
"write-up" for an ashtray CB install... https://www.yotatech.com/forums/f116...acement-76444/
Old 01-25-2008, 04:39 PM
Vohaul's Avatar
Originally Posted by rocket
Heres some ideas...
https://www.yotatech.com/forums/showthread.php?t=52446
edit:
cket...that one that you fcound last was the one i found before but couldnt find before...and to boot, it was even your install
did you have to get a 90 degree bend for the antenna connection..or did it just slide back in
thanks
Old 01-25-2008, 07:30 PM
sh0kk86's Avatar
so do you guys think an external speaker for the cb would be better to hear?
nvdesertrunner
05-11-2020 08:18 PM
wwjr
09-07-2015 09:27 AM
punks_is_4x4
08-21-2015 01:35 PM
Esibnitsud
07-30-2015 08:19 PM
Quick Reply: CB Install in ashtray...
