GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Decide to get a CB.
Old Jan 21, 2008 | 04:40 PM
wormhole's Avatar
Decide to get a CB.
Well, I decided to go ahead and get a CB. These are two that I'm looking at (will they fit into where the ash tray is at?).
http://www.amazon.com/Cobra-C19DXIV-...0965703&sr=8-6
http://www.amazon.com/gp/product/B00...6ZMNCC89A4AASM
I'm still confused when it comes to want antenna to get and how to tune it properly. If you all have any other recommendations let me know
Old Jan 21, 2008 | 05:19 PM
toy_tek's Avatar
Sorry don't know if either of those will fit in the ashtray. The Cobra 18 fits under the stock stereo though, where the little cubby hole is.
I'm not an expert on antennas either, but the 4' firestick comes pre-tuned for an 18' coax cable. Which is about the perfect length if you mount the antenna at the back of the truck. I was pretty lazy when I did my setup and went that route.
Old Jan 22, 2008 | 08:15 PM
wormhole's Avatar
Will this fit where the ash tray is at (coin holder)?
http://www.walmart.com/catalog/produ...uct_id=4642484
Old Jan 22, 2008 | 08:29 PM
Tofer's Avatar
Sponsor
IIRC they should. i have my cobra 20xtr (http://reviews.cnet.com/two-way-radi...-30637936.html) in the ashtray, and before that i had a POS radioshack one in there.
the 20xtr looks to be the same size as the one your looking at
Old Jan 22, 2008 | 08:52 PM
Elvota's Avatar
I went with a Unden 510 XL which fit perfectly where the ashtray used to be... but that was on a 2nd Gen. Should be similiar on your 3rd Gen.
I got mine from this sight. I purchased a "as new" for a very similar price as seen here:
http://www.unidendirect.com/itemdeta...O510XL&tabid=1
Hard to beat in my opinion.
I also run a 4' Firestick, but had way better reception and broadcasting ability with a Wilson 1000 antenna mounted to the roof. I had mine hard mounted, and broke it off at the base twice in 1 month under low branches... so I am now using the Firestick.
If you go Wilson, you can get a magnetic mount which is fully removable.
Old Jan 22, 2008 | 08:55 PM
CJM's Avatar
CJM
All of those radios will fit.
I highly suggest you look for the cobra 19 IV as it has an RF gain knob.
Old Jan 22, 2008 | 09:50 PM
toy_tek's Avatar
Elvolta graphics
Originally Posted by Elvota
So you didn't buy your CB from the little old lady on Main street? Hmm. I told her you were coming in. She's probably hunting you right now.
Old Jan 22, 2008 | 10:21 PM
Elvota's Avatar
No... didn't buy from them but have been down there a few times for some tuning help and various bits. They are very helpful and seem to know there stuff.
Old Jan 24, 2008 | 07:37 PM
wormhole's Avatar
Did you guys hard wire it to the battery or did you run it to the fuse box?
If you ran it to the fuse how hard was it to wire it in? The CB that I got has bear wires on the end with no connections to run it directly to the battery.
Old Jan 24, 2008 | 07:45 PM
Elvota's Avatar
I think it's best to run the CB from the battery... something about less electrical interference.
I ran mine to a fuse box, but not the OEM one. I added a aux fuse panel some time ago for all the extra goodies I planned to add.
The CB has "bear" wires huh.... watch those, especially if they are of the Black Bear variety. They'll tear your arms right off!!
Old Jan 24, 2008 | 08:07 PM
wormhole's Avatar
I guess bear wasn't the correct word. I should've said pre stripped.
Old Jan 25, 2008 | 06:23 AM
Elvota's Avatar
Bare is right, bear is wrong, beer is good.
I'm just being a smart ass.
Old Jan 25, 2008 | 09:53 AM
wormhole's Avatar
Stupid english lanuage (I can't spell either)
Old Jan 25, 2008 | 08:59 PM
wormhole's Avatar
Someone commented on another forum to wire it using the cigarette light socket. So it can be plugged in when needed or to hard wire it into the cigarette lighter wiring.
Old Jan 26, 2008 | 11:36 AM
wormhole's Avatar
I picked up a Wilson "lil Wil" antenna today and after some more reading I've decided to wire to the battery using an aux. fuse panel/board. What gauge of wiring do I need when I run it from the aux. panel to the battery?
Old Jan 29, 2008 | 05:32 AM
toy_tek's Avatar
hey back to your original cb question i found this today from this thread
For the wiring you have to first figure out what is the max amp draw that you'll have at your aux fusebox. The one I got is rated for 30 amps, so the wire size is dependent on that. CB's are nowhere near a 30 amp draw, but if you add lights or anything else later on you need to make sure your main power wire is sufficient. Also its probably a good idea to add a fusable link right off the battery terminal to protect the power wire to the aux fusebox in case of a short. That is something on my upcoming "to do" list.
From www.the12volt.com see this chart:http://www.the12volt.com/info/recwirsz.asp
Going from their info, a 30 amp draw is equivalent to 200 watts which requires a 10ga wire for a 4 foot length. I put my aux fusebox just left of the brake pedal, which is roughly 4 feet back from the battery. I used some leftover Monster Cable power amp wire I had. Right now I only have my ARB compressor running off it, I will eventually get my CB power from the aux fusebox as well as whatever else I add in later.
edit: when you wire anything in hot to an aux fusebox, you gotta remember to turn it off!
Old Jan 29, 2008 | 07:55 PM
wormhole's Avatar
Old Jan 29, 2008 | 08:06 PM
toy_tek's Avatar
Originally Posted by wormhole
I should have worded that better... an aux fusebox wired directly to battery isn't idiot-proof. Your CB power would always be hot, meaning if you forgot to turn off your CB (or whatever) you'd most likely have a dead battery the next morning.
Old Jan 29, 2008 | 08:07 PM
Elvota's Avatar
^^ He means the accessories will stay on all the time until the battery is dead if you forget to turn them off.
Unlike factory equipment that is only hot when the key is in the "ACC" position and you can't leave on by accident.
EDIT: I type too slow.
Old Jan 29, 2008 | 08:09 PM
toy_tek's Avatar
Ironic since you drive like a bat out of hell.
btw, check your email.
