Fillsrunner4 3.4cralwer -pic heavy!
Old Dec 31, 2007 | 01:05 AM
  #101
DeathCougar's Avatar
WOW i dont usually look into SAS threads, but this one is interesting as heck!
I noticed you are in Sammamish. I am up here in Arlington, and plan on doing a 3.4L swap soon. I also plan on doing a SAS on my 87 4runner. For the 3.4L i will prolly get most the new parts from the dealer, but I will have to buy the ORS harness. I know nothing of wiring!
Old Dec 31, 2007 | 11:47 AM
  #102
fillsrunner4's Avatar
Ya you work at Nix99 right? I actualy bought the axle there for the SAS
I learned wiring in High School for my senior clasee project a few years ago. I build a guitar effects pedal from complete sratch. I could help you some with the wiring all you need is the diagrams from both trucks to make the adapter harness. Its really not that hard it just takes some time so if you dont have that then the ORS harness is probably the way to go. I dont really know about the whole kit but its probably best to source all the parts from the dealer or other areas instead.
Thanks for looking
Old Dec 31, 2007 | 11:57 AM
  #103
Elvota's Avatar
I had very limited wiring experience when I did my swap as well. I had ORS bookmarked in case things didn't work out, but Fillsrunner is right, the wiring itself actually isn't that bad. I think I had to connect maybe 10 wires from the 3.4 to the 3.0 4Runner. If you can save money on the harness, you'll be able to budget for all sorts of upgrades if you wish.
I have some tips here if you haven't seen the thread already.
https://www.yotatech.com/forums/f160...4-swap-128285/
Keep the pics coming. Massive amount of work you have done.
Old Dec 31, 2007 | 12:02 PM
  #104
The whole kit from ORS is high quality, and all OEM parts where possible.
but, I get a 30% discount from the dealer. that $20 hose prolly costs me $8, and the other parts are much less as well.
I may get ahold of you just for some help in doing the 3.4 swap. you went much farther than i plan on, in terms of drivetrain lift, etc etc. I am doing the 3.4L swap in a DD of mine.
Old Dec 31, 2007 | 12:05 PM
  #105
My swap is going into an 86 22RE 4Runner. Nothing 3.0 even existed yet lol. I have to figure out everything from wiring to tach to trans and beyond. I will most likely be keeping the 99 5Sp, and just getting an adapter to put the RF1A gear drive case behind it. I think marlin sells the adapter for $400. Otherwise, I have to get a whole new 3.0L or T100 trans, and the cost is a wash.
Old Dec 31, 2007 | 12:07 PM
  #106
Ya let me know Im always down to help a local member or any yota. Dont get me wrong the ORS entire kit is great quality plus they have tons on knowledge on there work. I just found that most parts from there kit i would have either had to change or i would not even use them.
With my Intake were i put it I was able to keep my Battery in its stock location so the small things like the tray and belts, hoses,ect were just not needed. Everyones swap is different it just depends on what you plan on.
Old Dec 31, 2007 | 12:11 PM
  #107
Ya just get the adapter and put the stonger gear drive case behind it with the passanger side drop. Fabbing some new mounts shouldnt be to hard since you have the 22re. I think the 22re wiring should be very similar and maybe even easier. The tack mod should be the same as well. I have a pic of the resistor needed and were you need to solder it too.
Again im glad to help if you need some
Old Dec 31, 2007 | 04:28 PM
  #108
brentcole5's Avatar
[QUOTE=fillsrunner4;50708039]How it sat
I think it was very skinny with the 12.5 35's on 8"wide wheels(i should have gone with 10" but this helped fit through some of the WA State tree trails
Out on the trails
Quote]
looks like
reiter pit, correct me if im wrong
Old Dec 31, 2007 | 04:42 PM
  #109
thats the upper portion of the power line trail, just before you get back out onto the main road.
Old Dec 31, 2007 | 04:51 PM
  #110
Yup most my wheeling was a reiter
Old Dec 31, 2007 | 10:56 PM
  #111
Anubiscougar's Avatar
:'( no more pix... i'm sad. Very nice build, great detail. Keep it up man.
Old Jan 1, 2008 | 03:13 PM
  #112
Gerdo's Avatar
Looks good!
Old Jan 2, 2008 | 12:16 PM
  #113
ya not at the moment however I was up snow wheeling with a few buddies and saw some sick rigs. It was a contest to see who could make it farthest up the trail by 3pm at tonga ridge. we had the lead in the least modded rig there. single cab SAS yota on my 37's. The iroks aired down to 0psi never lost a bead and work outstanding.
Ill post pics of it since my build is a bit on hold
Old Jan 3, 2008 | 04:31 PM
  #114
Snow pics Tonga ridge hangover run 1-1-08
Heres some pics of the snow run i told you all ide post. This was a comp to see who could make it farthest up the mountain before 3pm.
There were come sick rigs
Heres the rig I was in. The 37's are off my 4runner and basicaly the smallest out there but this truck did real well with them and its stock 22re
This is one pf my favorites. its got a 5.0l ford motor with Dana 60's and 41" iroks with longs. He had some motor problems on the trail but he beats this rig like crazy
Some more pics
Snow was Deep
Truck stuck so we pass
Eric got stuck so we lost the lead
Crash was there which was sick because his coild rig is amazing
We didnt finish since we helped out our buddy and didnt really have a chance right at the end. It was still alot of fun and I cant wait for next years run for the throphy and taking my rig up
Old Jan 3, 2008 | 05:34 PM
  #115
bigarms23's Avatar
looks fun but that blue 4runner looks cool and cold
Old Jan 3, 2008 | 06:06 PM
  #116
Thats "crashin" Kenny Bates. He is friggin nuts. He used to have a chevy 4.3L in there, but he blew that to pieces. Silly bastard keeps blowing up his R&P too. I race Figure 8 with him at evergreen.
Some more pics
Thats my buddy Jeff. His passeger is his brother Jake who I work with at Nix99. He has done all the steel work on all my race cars, and on crawler. He did all the fab work on his 4Runner too. That thing is SICK. He recently blew his front R&P up too, and runs a Hi-Po FJ80 diff.
It looks like Jeff is pushing you lol.
His rig really is quite amazing. I wheeled with him back in the day, and he is the most helpful nicest guy you could ever meet.
see replys above
Old Jan 5, 2008 | 05:27 PM
  #117
ya kenny is nuts he broke a few more things on the trail this day. he is a great guy. Crashes rig is sick and he was real nice he broke on the trail his stub or nuckle. ive just a few of the others but it was alot of fun and there were many capable rigs out
Old Jan 5, 2008 | 06:15 PM
  #118
yotasavg's Avatar
nice run!! i love snow wheelin', looks like a good time!!!
Old Jan 5, 2008 | 08:23 PM
  #119
how did they manage to break in the SNOW? I didn't think that was even possible lol
Old Jan 5, 2008 | 09:11 PM
  #120
wow... how did you guys even make it through that.. deep as crap. I'd love to try it some day lol!
