Stainless Braided Brake line replacement
Old Dec 23, 2006 | 09:07 AM
dfoxengr's Avatar
can anyone see any downfalls of using braided brake line for the entire rear-end to replace the hardlines on the axle housing?
im debating on this and remaking hardlines when i do my shock setup in the back.
also what size are the fittings that connect to the drums on toyotas? tacomas specifically.
the hardline is 3/16" i found
thanks
Old Dec 23, 2006 | 10:00 AM
waskillywabbit's Avatar
I would stick with as MUCH hard line as you can as those stainless steel lines do "flex" and that in essence reduces brake line pressure.
When I redid mine I just got 3/16" line standard lengths with Toyota fittings (a 2 footer and a 4 footer) at the local mom and pop auto parts place and had them cut down to fit. The Toyota is a 10mm fitting, but be careful to get the LONG fittings in the right places and not the short ones so they'll seal everywhere. Particularly the input (top) in the tee on the rear axle...a short fitting won't seal there as it bottoms out (at least on my 86 rear axle) on the 85.
Don't know specifically about the Tacomas but I'd think they could look it up at the parts store.
I do have ss braided line from the fitting in the back off the frame to the tee on the axle and on the front from the OEM hard line from the MC to the small hard line off the caliper.
Old Dec 23, 2006 | 02:20 PM
dfoxengr's Avatar
ok great. so from auto stores the lines come in straight lengths so i can bend/flare them myself?
didnt know that.
do you have a manual prop valve in there somewhere, and if so, did you mont it under the hood?
i want to mount mine under the hood but itll be a bit more work ive been reading.
thanks.
Old Dec 23, 2006 | 03:15 PM
I measured how much line I needed between fittings and had them cut to length and they reflared them, and then bent them myself...nothing to it.
Manual proportioning valve under the hood.
Old Dec 30, 2006 | 10:03 AM
dfoxengr's Avatar
thank for the info, i just got mine in that same location yesterday and removed the lspv finally today.
-derek
Old Dec 30, 2006 | 10:14 AM
Talking
-derek
You'll be glad you did!
Old Jan 4, 2007 | 03:31 PM
dfoxengr's Avatar
yes i am glad because it cleared up tons of room for my 4 shocks im mounting next week.
anyone know of a 20+" long DOT approved stainless rear hose that goes from LSPV to axle?
Old Jan 4, 2007 | 03:56 PM
SS braided brake lines: http://www.wabfab.org/products/brakes/brakes.htm
Jun 1, 2021 01:51 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
skoti89
Jul 8, 2015 12:05 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
