rare situtation...removing a locker
so ive got a rear lockrite...i go to school in boone (you might have heard of our football team....) and the only time i really use 4wd anymore is in the snow...i just got new tires, the nitto terra grappler's, because i just dont have time for wheeling anymore. anyways, im entertaining the idea of removing the locker, for several reasons: 1) its annoying as hell in turns 2) i dont really wheel anymore 3) it was a pain in the snow last year 4) it disengages a lot while driving straight, causing me to suspect something is wrong in the axle, so im most likely having someone take a look at it soon...so while hes got it out...
so those are my reasons. im wondering what effect, if any this will have? thanks for any help/advice/comments
also, its been about two years since it was installed, and its come in handy maybe three times
WOW, a locker in the rear a problem?
I never thought so. Gets me thru 90% of my driving. If it weren't for the fact I occasionally need all 4 wheels driving I'd just run a locker in the rear. But I've got reg. detroit lockers, both front'n'rear.
Now the locker in the front on snowy roads that's another story.
crucial yea i dont have the open spider gear assembly. i had a few ring and pinion bearings busted when it was installed, so i dont know if thats why the shop didnt give me back the assembly, but at the time i didnt even think id ever take it out.
yea get an arb.
the thing is...i dont wheel anymore...and the only time i use 4wd is in the snow...and its not fun to drive in the snow
yea get an arb.
Sounds like you wouldn't want it. If it disengages while going straight, then it's very likely that one or both of the coupler halves are worn to the point where it ratchets when it isn't supposed to.
That happened to the Lock Right in the rear of the '94 Mazda Navajo that I had. The driver side coupler wore out after about 37,000 miles, which would cause that side to ratchet when it wasn't supposed to.
That's why I replaced it with a No Slip. The No Slip is much more durable, and it's smoother and quieter as well.
You should just be able to reinstall new spider gears and side gears. There probably isn't anything else wrong with your differential.
Just get a used 3rd member from a junkyard and swap it in. Only thing you need to do is match the gearing:
- http://www.car-part.com/
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
