new lift coming, need advise
Old Oct 2, 2006 | 07:04 PM
curly_c's Avatar
ok i have 2 inch Bj spacers and 2 inch coil spring spacers on their way. i know i will need new shocks but im not sure which ones to get. i wanted rancho but i was told that they might not work with my truck being lifted so much.
so what do you guys think i should get? what will work the best with my set up? i have a 1990 4runner.
Old Oct 2, 2006 | 08:46 PM
rocket's Avatar
Did you mean to say 1.5" BJ spacers? never heard of 2"
For shocks, check out Pro Comps, Old Man Emu, Skyjacker, Tokico, and this.
whats wrong with the replies in your other thread... https://www.yotatech.com/forums/f116/shocks-89086/
Old Oct 3, 2006 | 10:39 AM
curly_c's Avatar
that thread i was leaning twards ranchos but i have sence been told that i can not use ranchos with that much lift, and the only other shock i have been told might work are skyjacker.
Old Oct 3, 2006 | 10:48 AM
slosurfer's Avatar
How much lift are you getting in the rear, that ranchos won't work. I got close to 5" of lift and have ranchos. Check out the bj spacer, cruiser coil thread for some shock info. I have OME in the front and rancho 9009's in the rear, works good for me. The rancho 9009's you have to drill out the bushing a little bit for it to fit, but no big deal.
Old Oct 3, 2006 | 01:33 PM
Sonofmayhem's Avatar
i Had ranchos on my 85 with 4in of lift for about 15yrs. I will either get ranchos or bilstiens for my trucks.
Old Oct 3, 2006 | 04:35 PM
curly_c's Avatar
well im going to have the coil spacers in the back which are 2 inches and then the downey hd coils that i already have in there. but that more or less just brang it back to stock levels. so im thinking about 3 inches in the back and i will have the 2 inch BJ spacers in the front and yes, they are 2 inches, thats what it says on trdparts4u.com thats where i got them
i kinda want to get ranchos cuz my dad has been running them forever and i know they are a good brand, i dont know much about skyjacker or pro comp but i have hear bad things about pro comp.
Old Oct 3, 2006 | 05:53 PM
rocket's Avatar
fyi, they are not 2" and if they are, be prepared to kiss your CV boots goodbye.
Its says 2nd generation...not 2 inches. lol
have you seen this... https://www.yotatech.com/forums/showthread.php?t=54794
Old Oct 3, 2006 | 06:13 PM
curly_c's Avatar
huh... must have put the 2inch coil spacers and the bj spacers together in my head. must have been seeing things, anywho, yes i have seen those lifts and seeing as i already have Downey HD coil spring ON MY 4runner and the rest of the lift is on its way that doesnt halp me at all. i just need sugestions on shocks. if i can use rancho shocks that would be awesome but sence i have been told both ways im not sure what to do.
Old Oct 3, 2006 | 06:47 PM
slosurfer's Avatar
I don't know about the front, but you can definately use rancho's in the rear. Who is telling you that you can't use rancho's? There probably isn't one listed on their application guide, but many are running the rancho 5009's or rancho 9009's in the rear with their lifts. I forget what vehicle they actually go to, but they fit with just trimming the bushing a little bit. I don't know about the front, but considering that there was a rancho suspension kit, I don't see why they wouldn't have a front shock for a little suspension lift. I guess I don't get who is telling you that you can't get rancho's.
Check out this thread and scroll down to about the 4th post.
https://www.yotatech.com/forums/f116/ball-joint-spacer-cruiser-coil-longer-shock-p-n-thread-41616/
Old Oct 4, 2006 | 09:06 AM
curly_c's Avatar
https://www.yotatech.com/forums/showthread.php?t=41616
ok, so thats good to know about the rear. i can get either rancho 5000s or 9000s. now i just got to figure out the front, i dont see why i couldnt use the same rancho front shocks, the front is not going to be lifted higher than the back. ill have to go down to central 4wd and talk to them so they can look at my truck and see whats best. thanks for the help.
btw, if i was to order ranchos off of say, 4wheelparts.com how would i make sure that they were 5009s and not some other number, i see that there are multiple rancho 5000 series.
Old Oct 4, 2006 | 09:13 AM
AH64ID's Avatar
You will be able to run "stock" leangth ranchos up front. They are for rigs with 0-1" of lift. They will fit your setup. The BJ spacers only allow for a higer ride stance and 1.5" more droop, they do not allow for a bigger tire. The shock that fits their POS 3" lift will work for you application as that lift too compress to the stock location. As far as the rear I had ranchos with my rear 4" on my 95 before the leaf swap that had 11" of travel.. so you should be able to find a decent replacment. Just check their part numbers for the appropriate size with the appropriate mounts. Dont forget for the rear with 3" of lift you will need a panhard drop bracket, and a brake LSPV bracket as well.
For the front its PN 5145 or 99145, the rear is the 5009 or 9009, the rears are 2" longer than stock, and have 3" more travel. I had 99234's on my 95 when I was running 4.5" rear springs, I never compressed them all the way, but the 5009's are a tad shorter and may work better for you.
Old Oct 4, 2006 | 05:20 PM
BeaterToyota's Avatar
I don't know the part number, but when I still had IFS and I had bj spacers I used Rancho shocks designed for the front end of stock Suzuki Samurais. These are about 2" longer than your stock front shocks, and they use the same mounting setup as your stock shocks. Perfect fit.
Old Oct 5, 2006 | 08:43 PM
curly_c's Avatar
sweet, yea i was reading about that on one of your other posts. sounds like a good idea. once i get my lift (taking forever) ill see how long a shock i need and go to central 4wd and look to see if they have anything like that. thanks for the help.
Old Oct 7, 2006 | 10:54 AM
curly_c's Avatar
its been over a week and i still havent got the lift, and ive emailed trdparts twice with nothin back, just venting here but if strap sees this maybe he can chime in and let me know if anything is going on.
Old Oct 7, 2006 | 12:10 PM
4Crawler's Avatar
I list a few mild lift shock choices on my web page:
- http://www.4crawler.com/4x4/ForSale/...cer.shtml#FAQ1
Sep 4, 2015 09:27 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
coffey50
Jul 28, 2015 10:55 AM
skoti89
Jul 6, 2015 07:45 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
