Budbuilt with 2" BL Question?
Old Oct 3, 2006 | 05:11 PM
crackerjack's Avatar
I know I'm gonna get yelled at...looked some for other threads, just short on time.
I've got my trk at shop for 2" body lift and ordered a transfer case skid from BUdbuilt. He asked me about BL and told him yes so he is gonna do something different? with skid plate.
I think because shifter will be in different place with cab higher?
He said something about changing motor mounts? too
Anyone know or can point me in right direction?
Old Oct 3, 2006 | 08:32 PM
914runner's Avatar
I think he was talking about a drivetrain lift.
Old Oct 4, 2006 | 02:45 AM
SAS'dToy's Avatar
Call him.
Old Oct 4, 2006 | 06:42 AM
BudBuilt's Avatar
Just gonna bend the crossmember so the trans and tcase sit an inch higher in the frame. Skid is the same, just the crossmember is bent less than "normal"
The shifter will sit 2" lower with the body lift. The drivetrain lift of 1" will get it to it's final resting place of 1" lower than stock.
No changes to the motor mounts for a 1" lift UNLESS YOU want to. Then see Roger Brown here http://www.4crawler.com/4x4/ForSale/MotorMount.shtml
Does that help? If not, just gimme a call and I can walk you thru it!
Bud
Old Oct 4, 2006 | 01:55 PM
SAS'dToy's Avatar
I called him for you
Old Oct 6, 2006 | 01:31 PM
No THX thats goin above and beyond. Performance BL is running behind on production so lookin at first of November b4 shipped to door. This is answering my questions so I need to lift drive train too...wait doesn't that raise Center of Gravity too. Making trk more roll over prone?
Old Oct 6, 2006 | 04:13 PM
faubrunner64's Avatar
yeah drive train lift is what you need i did a dt lift and it is awesome you achive alot better ground clearance!
Old Oct 6, 2006 | 04:36 PM
I didn't realize I'd need to do this, but I want all upgrades to be first class so I went to link posted above to research...Makes sense to raise "all the drive line"
Old Oct 6, 2006 | 07:48 PM
tc's Avatar
tc
Then cancel your order, and get the bodylift (and drivetrain lift) from 4Crawler. His customer service is at least as good as Bud's (which is saying something 'cuz Bud's is VERY good!)
Old Oct 7, 2006 | 01:04 PM
4Crawler's Avatar
A drivetrain lift is a good way to go, gets rid of that low hanging crossmember in the center of the vehicle. Get the BB crossmember made for 1" - 2" of lift and raise the engine if you want. Helps offset some of the body lift issues like radiator and shift lever interference:
http://www.4crawler.com/4x4/CheapTri...ft/index.shtml
Here is what a 2" DT lift does for under-truck clearance, stock:
2" lift:
Old Oct 7, 2006 | 07:35 PM
OK OK don't know about canceling my order how bout just spreading the money around hehe....no ya just can't have sum
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
