Bolt to the frame sliders??
Old Feb 20, 2007 | 05:53 AM
J'S LTD 4RNR's Avatar
Does anyone know of a rock slider manufacturer that sells bolt on sliders? I believe Demello Offroad may have them, but not sure. I would like to also get some that are unfinished, so I can prime, paint, and install them myself.
Old Feb 20, 2007 | 06:30 AM
Bejiita's Avatar
Im interested also if anyone finds anything, I dont mind welding but I dont plan on keeping this vehicle my whole life so if/when I sell it Id like to return it close to stock.
Old Feb 20, 2007 | 06:39 AM
tulsa_97SR5's Avatar
4crawler has them
http://www.4crawler.com/4x4/ForSale/RockSliderZ.shtml
tons of options on design, and paint etc. Even has an option to make them air tanks as well.
Old Feb 20, 2007 | 06:42 AM
eric-the-red's Avatar
I just installed a pair last month, work great, look good and very easy to install.
Old Feb 20, 2007 | 03:10 PM
tc's Avatar
tc
I have 4Crawler sliderz, but I welded them on.
THE BEST bolt ons are CBI Fab though. SUPER easy to put on and pretty beefy. Not sure if they make them for preTacos though...
http://www.cbioffroadfab.com/index.php
Old Feb 20, 2007 | 04:21 PM
Sonofmayhem's Avatar
demello makes zem for za third+ gens
Old Feb 20, 2007 | 05:02 PM
olharleyman's Avatar
Wabfab
Old Feb 20, 2007 | 08:32 PM
Just Learning's Avatar
eric the red post some pics, did you put a mount through the frame?? im thinking of getting the 4 crawler rock sliders
Old Feb 20, 2007 | 08:47 PM
KyleT's Avatar
X2, i wish I knew that He made bolt on ones before I made mine, would have been a ton cheeper.
Old Feb 20, 2007 | 09:29 PM
Elton's Avatar
yea there site sucks
Old Feb 20, 2007 | 09:54 PM
KyleT's Avatar
e-mail steve, or pm him on ttora. STEVE@CBIOFFROADFAB.COM his ttora username is "rokbrkr"
Old Feb 21, 2007 | 05:01 PM
I just drilled holes and used Roger's self-tapping bolts to mount mine. If I have any problems with that then I'll get longer bolts and go through the frame. I'll post some pics on the weekend.
Old Feb 23, 2007 | 03:28 PM
Here's some pics of my sliders. These are 63" long, 4Crawler's normal 3rd gen ones are 66" but I thought I would have clearance problems with the fender flares. Turns out 66" would have fitted fine though.
Old Feb 24, 2007 | 02:01 AM
i like , i really like the square look, ive got some overtime coming up and i know what im getting- oh yeah
Old Feb 24, 2007 | 04:47 AM
waskillywabbit's Avatar
Originally Posted by olharleyman
Wabfab
I do not sell bolt on sliders except for the FJ Cruiser, but I am in Tuscaloosa, AL which is quite close to Nashville, TN if you are interested in getting some properly welded on or installed.
Old Feb 24, 2007 | 11:03 AM
4Crawler's Avatar
Also am working on a 3rd (or 5th) bolt-on option. This method uses threaded inserts that are pretty easy to install w/ simple hand tools. THreaded insert bolt to the left, self-tapping bolt to the right:
The threaded insert gives approx. 4 times the thread engagement that the self-tapping bolt does:
Still working on the cost for this installation option. Will include a returnable installation tool. Does require drilling holes in the frame slightly over 1/2" in dia.
The inserts will also be available as a retrofit to existing self-tapping bolt installed sliders if you want to get a stronger mount. Normally, only the bottom-most bolt holes use the threaded inserts.
Old Feb 24, 2007 | 11:10 AM
Ok then what do you call the set you sold me with the bolt on mounts?? Guess that I misunderstood what you sold me my bad
JustMike
Apr 21, 2016 07:08 PM
Sep 4, 2015 09:27 AM
priest16
15
Aug 6, 2015 07:43 AM
yourrealdad
Jul 21, 2015 11:13 AM
coryc85
Jul 6, 2015 04:07 AM
