dual batteries w/out isolator
Old Feb 24, 2007 | 02:45 PM
dfoxengr's Avatar
first off ill get it out of the way that i hate wiring, and dont uderstand much, which is why im ME, not EE.
ive read a lot of writeups but all of them seem complicated and expensive.
anyways, i want the simplest setup for dual batteries, and im wondering why i cant just wire 2 in parallel with a disconnect for the piggyback so i can run it independantly of the main.
i dont want a starter only battery which is what im reading most people do this for.
ill have one in stock location, and another in my bed box(which will have my converter and compressor and aux outlets wired to it)
i can then leave the disconnect out for normal use, and when i need a recharge on the aux., or a jump-start ill just stick in the disconnect in and go.
also planning on a higher output alternator at the same time.
what would be the downsides of this method?
Old Feb 24, 2007 | 03:06 PM
4Crawler's Avatar
Sure, that will work. No different that using a solenoid like I use on mine. A solenoid is nothing more than an electrically controlled switch.
Old Feb 24, 2007 | 04:12 PM
tc's Avatar
tc
When I did the competition car audio thing, we never used isolators due to the voltage drop across them. Wired all the batteries in parallel.
It is CRITICAL to have a fuse on the wire to the back within 18" of the front battery, and I would use BIG wire, like 1/0.
Old Feb 24, 2007 | 05:03 PM
dfoxengr's Avatar
so its not looking like there are any downsides. thats great, makes my life tons simpler. and yes ill use some big wire. thanks for the tip.
and what size fuse 100A? i have no idea about lots of this stuff.
ill also probably upgrade the stock alternator wiring as well.
another ?. if i were to just have to use the duals as a stick welder, could i unground them from the chassis and hook up my leads to the aux one, both in parallel and only connected to eachother, and not burn anything up?
thanks again.
Old Feb 24, 2007 | 07:18 PM
tc's Avatar
tc
You'll want to connect them in series for welding I think.
And you're looking at a 300 - 500A fuse - whatever the CCA of the battery is and what size wire you use.
Old Feb 26, 2007 | 08:47 AM
4Crawler's Avatar
Yep, series for welding, I have both my batteries "floating" so when I unplug them from the vehicle, both + and - terminals are not connected to anything. Then I can plug in some jumper cable extensions and tie the + to - on one set to get 24 volts. I find that it is very hard to strike an arc w/ 24 volts, so usually end up needing another battery (in series) to jump to 36 volts for good welding:
- http://www.4crawler.com/4x4/CheapTri....shtml#Welding
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Longbed 90
Oct 19, 2015 11:05 AM
Daenerysdad
Oct 1, 2015 07:33 PM
JPV
Sep 28, 2015 03:15 PM
toyotasaurus
Sep 24, 2015 03:30 PM
