Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
Toyota Fiberglass: 1983 Trekker Build-Up Thread
Old Sep 18, 2009 | 05:35 PM
  #641
slacker's Avatar
thanks !!!
Old Sep 18, 2009 | 08:47 PM
  #642
annoyingrob's Avatar
Corey's spent so much time on this build, once it's done he won't know what to do.
Old Sep 19, 2009 | 05:36 AM
  #643
kyle450rider's Avatar
This build is insane! You could make a documentary about this build.
Old Sep 20, 2009 | 05:32 PM
  #644
slacker's Avatar
you forgot to mention , the engine is built , ( ~ 400HP) ......... and , these pics ....
full custom tig'd frame ..
I have lots of work to do .. shop is PACKED .. and lots of things on the go .. thats why my projects always take so long !!! not that I'm complaining
Old Sep 21, 2009 | 07:12 AM
  #645
Right, I remember seeing that Supra truck years ago on BC4x4. I'm pretty excited about that one myself
Old Sep 23, 2009 | 12:19 AM
  #646
vwfastg60's Avatar
I bookmarked your thread on the trekker forums(was sent to me because your OCD like me) The build up is great and i cant wait to see your rig finished......BTW i think i saw you on custom tacos maybe? I was on there last year building my 86 2wd xtra cab and remember seeing the 2wd frame pic or something.
Old Sep 23, 2009 | 08:16 AM
  #647
just call me smithy's Avatar
great work cant wait to see it finished
Old Sep 23, 2009 | 04:27 PM
  #648
slacker's Avatar
yep .. kicked it out of the shop when I started the trekker , but I'm
" itchin' " to get back on it ... soon .
probabally best I usually hit that board first .
I have posted it on the 2WD board .. which I think is a tacos board .. but other then that , the picture could have been "copied" .. I duno . I need to start " lettering" all of my pictures
Thanks ..
Old Oct 8, 2009 | 04:43 PM
  #649
slacker's Avatar
sorry for the slow progress ...
but today I have a wee bit of an update .
started the drivers door panel , I have to re-pin the hinges , so I will be sure to post that as well .. (hopefully this weekend) but for now , this will have to do
started with removing the door and hinges
Next .. with the grinder "clipped" the edges
and off comes the skin .. there is a few spot welds , expecially for the vent window supports .. but easlily dealt with ..
New skin goes on .. and time to make it stick !!
I didnt have a mini rasp, have to go buy one .. so I called er' a day ..
Old Oct 9, 2009 | 04:23 PM
  #650
slacker's Avatar
got the flanges cleaned up today .. and got the POR15 on them
also "cleaned" up the inside , and got it POR15'd
trimmed up the holes for the handle and lock
and installed and ready to "bond"
Old Oct 10, 2009 | 03:21 PM
  #651
slacker's Avatar
ok continueing on ... In order to "attach" the fiber skin .. you need to scuff the panel , where it will contact the metal shell , for as the say in the industry "tooth" , meaning .. something for the epoxy to stick to
fiber panel
metal shell , back to bare steel .
The epoxy I use in my shop is 3M panel bonder .. it's expencive , but if done propperly , it will never come apart , and they guarentee it !!
so now .. epoxied .. and clamped .. just has to cure ..
Old Oct 10, 2009 | 03:39 PM
  #652
slacker's Avatar
so now the door is "curing " ...... time to address the hinges ..
lots of play , so time for some new hinge pins .
had the hinges sitting in a pot of deluted hydrofloic acid over night
so it make sandblasting a little easier and heres the works ..
had to cut the pin , and punch it out
next , I had to drill the old hinges to fit the new bushings
both sides have to be done because , the pin is a little larger . File the " burrs " and install the new bushings .. The pin also has to be trimmed , because it was to long .
I "plug" welded the bottom of the hinge , for safty .. and a little primer ... DONE
just have to wait for the epoxy to cure .. and I can mount the door
Old Oct 11, 2009 | 03:09 PM
  #653
slacker's Avatar
all excited , I went in this morn. to get the door mounted .. removed all the clamps , and connected up the door handle , bolted on the hinges .. and got the door back on
Marked the position of the mirror , drilled and "nutcerted"
and put the mirror back on
Very happy with the way it turned out .. when I trim the fiberglass panels , I always trim them LARGE .. so there is enough panel to make my own panel gaps . it's always easier to remove material , then to add it . So when I do the "final" body work , I will be able to sand down the door edges , to make perfect panel gaps
Old Oct 14, 2009 | 04:55 PM
  #654
slacker's Avatar
couple of things to add ...
got the center console drilled mounted , and also removed the dash , and 3 guages , and mounted them in the upper console .. also sent the r door mirror away for plastic chrome
I'll also be re-working the dash bezzle again .. hopefully for the last time
Old Oct 16, 2009 | 04:04 PM
  #655
slacker's Avatar
so as mentioned .. center console is now mounted .. got the gauges in .. also started to re-do the dash again !!! I think this dash has been the hardest thing of all .. you look at it all the time , and I'm trying to get the "best" aesthetic value I can ..
I hope this is the last time !!!
Old Oct 17, 2009 | 03:31 PM
  #656
slacker's Avatar
so .. done , well "rough in" anyway
I'm very pleased , and will be able to look at it for a long time .
I went with the /83 ashtrey , and the /99 lighted , cig lighter .
Old Oct 17, 2009 | 03:34 PM
  #657
toyospearo's Avatar
Looking good! I am lickin my chops to see it finished!
Old Oct 17, 2009 | 04:37 PM
  #658
slacker's Avatar
thanks bud .. I think this time .. 3rd time was the charm "
Old Oct 18, 2009 | 08:35 PM
  #659
didn't you say something like "I don't smoke, so there won't be an ash tray" earlier?
Old Oct 19, 2009 | 06:54 AM
  #660
slacker's Avatar
yep I did , and I dont smoke ... I didnt want to put it in ... but I guess as others have mentioned , it'll make a good "coin" holder
