habanero's 1996 4Runner Build-Up Thread
Old Feb 5, 2016 | 05:38 PM
  #2721
habanero's Avatar
There are 7 screws to take the cover off. 1 in the middle, 1 at the top ground, 4 on the peripheral, 1 at the top opposite the ground..
The screw in the middle has a nut on it, down in the hole in the back. Don’t lose it.
here’s the back...the nut will likely fall out and need to be put back in when it’s time to put the motor back together
There is also a nut on the screw at the top opposite the ground. It can also fall out.
I used a screwdriver to carefully pry the thing apart, they use an ooey gooey gasket to seal it. Try not to get that seal stuff on everything, it'll be handy when it's time to close back up.
Old Feb 5, 2016 | 05:39 PM
  #2722
habanero's Avatar
If there are broken antenna bits you should be able to remove the ring sitting on top of the gears and find them.
In these pics I’ve cleaned off the grease in there so you can see what’s going on when I do the anatomy part. You should see a lot of whitish grease.
Clean out the broken bits and stick it all back together. Bolt the antenna back into the truck, plug the connector back together. The mast should be at the hole in the fender. Stick your antenna mast track with the teeth facing towards the front of the truck down into the antenna shaft. Have someone turn the radio off and if you got it in there right the antenna will suck down in and you can guide it to the proper spot. Cool.
Put on the antenna bezel, then screw the antenna bezel nut onto the antenna shaft threads. Make sure you catch the threads and get the nut screwed onto the shaft. That’s the only thing holding your antenna mast in.
Tada!
(your antenna motor will have the actual motor still attached...I was taking pics in anticipation of the anatomy of an antenna posts coming up)
Old Feb 5, 2016 | 06:43 PM
  #2723
habanero's Avatar
And let's dig deeper. This is not a part of the antenna mast replace! More a pictorial on what-all's in there. The largest diameter gear in my antenna motor has some wear. It's not bad, but my hubby found me a busted up motor out of an '02 so I'm gonna do some redecorating. Why not?
Anatomy of a power antenna
Exploded view:
motor
Brushes (being held against springs with toothpicks)
Old Feb 5, 2016 | 06:48 PM
  #2724
habanero's Avatar
Little white plastic bit
goes here where the bottom of the auger screw is
Like so with the motor installed
There are 2 nuts that fit down in place holding the motor cover on.
They'll run off if you don't keep an eye on them
install the motor cover with the words on front. Put it on backwards and your antenna will do opposite what it's supposed to.
Old Feb 5, 2016 | 06:51 PM
  #2725
habanero's Avatar
The plastic sleeve is what the antenna mast shaft fits into. It only goes on one way, obvious because of the screw hole vs the screw hole in the case
and the ground
Old Feb 5, 2016 | 06:54 PM
  #2726
habanero's Avatar
Once motor is installed (not in this pic, but you should be able to see the auger), add the first gear.
The next gears are part of an assembly that fits over the first one
You may have to turn the first gear a little til the teeth mesh and the assembly drops in place
Again, the auger screw should be in place before this happens.
Old Feb 5, 2016 | 07:00 PM
  #2727
habanero's Avatar
This is the larger gear assembly
If the c-shaped part of the gear on your left is broken the antenna motor could run longer than it's supposed to. More often than not it's because of an aftermarket mast track that is too small in diameter, but if it's not that then look here.
They fit together a certain way
like so
Old Feb 5, 2016 | 07:02 PM
  #2728
habanero's Avatar
and it fits into the housing
like so
Then the ring sits on top with the lipped side up
Old Feb 5, 2016 | 07:07 PM
  #2729
habanero's Avatar
There are 4 nuts, 2 on the motor cover, one in the center at the back and one at the top right. They are all on a mission to disappear.
and here is where the ground wire goes
I took my pics after cleaning off the grease for better clarity, then replaced the hardened white grease from toyota with plastic safe white lithium grease. Fairly generous amount of it, but not stuffed to the gills.
And there you go. A whole lot of pics for the heck of it.
Old Feb 6, 2016 | 03:42 AM
  #2730
jason in tn's Avatar
Glad you were able to avoid being banged up Hab, my wife's tundra wasn't so lucky .
Great wright up on the antenna as well, you have a knack for really being able to explain things.
Old Feb 6, 2016 | 03:56 AM
  #2731
habanero's Avatar
Oh, sorry to hear, Jason! Hopefully getting back on the road won't be/ wasn't too much trouble.
Thanks! If the how-tos help someone then it's worth the hassle of trying to get it all pictured and written down with some semblance to making sense.
Old Feb 6, 2016 | 07:05 AM
  #2732
rworegon's Avatar
G' morning Hab! I don't have the power antenna, but if I did it would all be very easy to do with what you show and explain. Well done!
Ski day Friday and tomorrow. Whoohoo!
Old Feb 6, 2016 | 07:13 AM
  #2733
habanero's Avatar
Good morning rw! Woohoo! Bike ride day!! Glad you get to do some skittering around on your planks, seems like your snow hasn't been cooperating much this year.
Old Feb 6, 2016 | 12:17 PM
  #2734
rworegon's Avatar
Snow has been good. Work and illness have been bug-a-boo this season. Hope weather was great for biking day!
Old Feb 6, 2016 | 06:22 PM
  #2735
habanero's Avatar
'Twas excellent. Chose to ride in Columbia, IL. Flat 30 mile ride for the 2nd tandem ride of the year. I'm in shape, sorta potato shaped. 18mph winds all the way out turned into a helpful push all the way back to the truck.
Ah, I was thinking it was lack of snow keeping you off the mountain. I'm guessing you are feeling better with two slidey days in a weekend.
Old Feb 8, 2016 | 04:25 PM
  #2736
habanero's Avatar
Catching up on my Toyota Trucks and Trails podcast...
http://toyotatrucksandtrails.com/episode-two-2/
Also have been enjoying the posts on the FB page.
I hear another project is headed my way from New Zealand thanks to my husbandio. He sure know how to spoil his woman.
Old Feb 8, 2016 | 05:30 PM
  #2737
rworegon's Avatar
Spoiled? You? Never admit it! lol
Old Feb 9, 2016 | 05:44 AM
  #2738
habanero's Avatar
I pay my dues....
Still.....
If it ever warms up again this is going in the 96...
Old Feb 14, 2016 | 02:35 PM
  #2739
Gearhead4's Avatar
I like your
Build
Old Feb 14, 2016 | 03:49 PM
  #2740
habanero's Avatar
Originally Posted by Gearhead4
I like your
Build
Thanks! Sure appreciate the input.
