Where is the rear liftgate lamp switch?
Old May 21, 2003 | 05:40 AM
SLC Punk's Avatar
I have noticed that when my rear liftgate opens the cargo lamp isn't turning on. Yes it is on the "door" setting, but I can't find the switch that would signal when the liftgate is open. This problem is intermittent...
Old May 21, 2003 | 06:31 AM
beachtaco's Avatar
i have the same problem but could never find one.
Old May 21, 2003 | 06:36 AM
keisur's Avatar
this is just a guess, is it maybe in that latch mechanism? I didn't check when i had the panel off bbut I don't recall seeing a rubber button switch dealy around the edges either.
Old May 21, 2003 | 06:40 AM
SLC Punk's Avatar
I was also thinking that. My other thought is that there may be a "mercury switch" like some hood lights use.. I guess I will have to pull the panel and check it out.
Old May 21, 2003 | 06:55 AM
Erc's Avatar
Erc
It is part of latch mechanism. When I have the light in door position with gate open and push inside the mechanism by hand, the light goes out.
Old May 21, 2003 | 07:01 AM
TDiddy's Avatar
Yes, its in the door latch.
Old May 21, 2003 | 07:53 AM
SLC Punk's Avatar
Thanks!
Old Jun 1, 2003 | 08:27 PM
Oscar's Avatar
Anybody solve this problem yet?
I too had the same problem, so today I decided to spray some WD40 into the latch mechanism hoping that it would free up something inside. Well it worked, the light turned on right away.
Hope this helps.
Old Jan 31, 2010 | 06:04 PM
tommytuttle's Avatar
What kind of switch is it.. does it just get seized up.
I'm now having a problem with my electric locks.. like a bad ground or soemthing I wonder if this can all be related to corrosion in the tailgate?
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
colinmil
Jul 6, 2015 04:03 PM
