Timing Belt replacement parts and tools Q
#82
I use the design member bugs1961 came up with. It's simple and with a 2' long leg it gives plenty of holding power.
Ok, I'm off for the night... Alarm is set for 215am. :-)
#83
I believe they put the two piece together with a rubber to protect the harmonic balancer assembly from damage of over torquing. That's just my thought.
#89
#90
I thought it worked but I have reason to doubt it now...
And for reference, I found another thread similar to what happened to mine: Broken Crank Pulley.
#91
Thankfully, it's only one night a month that I go in to work at this crazy time. Awake at 155am....yawn. So much for waking up to the alarm clock.
#92
#93
#94
Yep...and I found another one with the same issue where you also chimed in!
Now, based on reading from those threads and from mine, I came up with my own conclusion that those failures were caused by the SST bolts/pins not long enough to reach the pulley holes way past the rubber damper for proper support. Due to old age, I bet the rubber inside got brittle, deteriorated, or whatever!
#96
Interesting bit on harmonic balancers from Dorman.
#97
Good Reading
With regards to the rubber, it is then possible it can wear, deteriorate and fail due to age, and usage? Well, to answer my question, I guess so!
voiddweller
19
May 2, 2016 09:10 PM
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
crazypaint
Jun 23, 2015 03:27 AM
infinityisfive
Jun 16, 2015 06:51 PM
