Timing Belt replacement parts and tools Q
Old Jul 1, 2013 | 07:41 PM
  #81
kball's Avatar
Back on page 3. Post 50
Old Jul 1, 2013 | 07:45 PM
  #82
rworegon's Avatar
I use the design member bugs1961 came up with. It's simple and with a 2' long leg it gives plenty of holding power.
Ok, I'm off for the night... Alarm is set for 215am. :-)
Old Jul 1, 2013 | 07:48 PM
  #83
Gt4r97's Avatar
Originally Posted by kball
I used this tool and as you can see it doesn't go in the holes very deep.
Yep..I can see it! I think my FABed SST goes deeper inside the hole compare to this. But then, I was using a 4-foot floor jack as an extension to my breaker bar and I think I exerted far more torque that is needed.
I believe they put the two piece together with a rubber to protect the harmonic balancer assembly from damage of over torquing. That's just my thought.
Old Jul 1, 2013 | 07:51 PM
  #84
Gt4r97's Avatar
Got it, Thanks, K!
Old Jul 1, 2013 | 07:52 PM
  #85
kball's Avatar
LOL, floor jack plus breaker bar = break 4runner.
I'm sure the designers made it the way they did to dampen as much vibration as they could. And to make a way to take it off....
  #86
kball's Avatar
RW, 2:15am? I'd have been in bed an hour ago!
Old Jul 1, 2013 | 07:58 PM
  #87
Gt4r97's Avatar
LOL...go K! Sorry for delaying you bedtime man! But why 2:15am, is only 9pm here(PST)?
Old Jul 1, 2013 | 08:00 PM
  #88
kball's Avatar
no no I meant if I had to get up at 215 like RW I'd have gone to bed a long time ago.
Old Jul 1, 2013 | 09:22 PM
  #89
Gt4r97's Avatar
Yeah, I hear you man. I know how it is..used to work those hours too.
Well, updates on how things goes will come soon. Thanks again!
Old Jul 1, 2013 | 09:28 PM
  #90
Gt4r97's Avatar
Originally Posted by rworegon
I use the design member bugs1964 came up with. It's simple and with a 2' long leg it gives plenty of holding power.
Here's my SST version:
I thought it worked but I have reason to doubt it now...
And for reference, I found another thread similar to what happened to mine: Broken Crank Pulley.
Old Jul 2, 2013 | 12:56 AM
  #91
rworegon's Avatar
Thankfully, it's only one night a month that I go in to work at this crazy time. Awake at 155am....yawn. So much for waking up to the alarm clock.
Old Jul 2, 2013 | 07:21 AM
  #92
Gt4r97's Avatar
Well, just like you, yawning at work right now. Went to bed late/spent hours reading around the forum last night!
Old Jul 2, 2013 | 08:05 AM
  #93
rworegon's Avatar
And, I chimed in on that thread too.
Old Jul 2, 2013 | 08:21 AM
  #94
Gt4r97's Avatar
Yep...and I found another one with the same issue where you also chimed in!
Now, based on reading from those threads and from mine, I came up with my own conclusion that those failures were caused by the SST bolts/pins not long enough to reach the pulley holes way past the rubber damper for proper support. Due to old age, I bet the rubber inside got brittle, deteriorated, or whatever!
Old Jul 2, 2013 | 08:30 AM
  #95
stophammertime's Avatar
This is one job I hope to never tackle again. Not bad once you know how to do it, but still not fun. Have fun.
Old Jul 2, 2013 | 06:54 PM
  #96
rworegon's Avatar
Interesting bit on harmonic balancers from Dorman.
Old Jul 3, 2013 | 05:36 AM
  #97
Gt4r97's Avatar
Good Reading
It really is, RW*. But I was thinking, what about the URD product(s)? I thought those are one-piece lightweight pulley instead of two-pc. being joined by a rubber. So those defeats the purpose of the conventional harmonic balancer?
With regards to the rubber, it is then possible it can wear, deteriorate and fail due to age, and usage? Well, to answer my question, I guess so!
Old Jul 3, 2013 | 10:06 AM
  #98
rworegon's Avatar
Sorry....I have no experience with the URD pulley.
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
marcusSRG
Jun 27, 2015 07:13 AM
crazypaint
Jun 23, 2015 03:27 AM
infinityisfive
Jun 16, 2015 06:51 PM
