starting problems?
Old Feb 10, 2004 | 06:36 PM
grafix43's Avatar
Unhappy starting problems?
hey guys i was just courious as to why like every 1 out of say 10 or maybe even 15 times, the truck wont start up unless i give it some gas.... like i said it doesnt happen that often, just occassionally which is weird to me... its a 22 re motor, auto trans.... ive heard it could be cause the thrrottle body needs cleaning, and i did clean it somehwat the other day but i didnt do the full method with the carb cleaner and toothbrush... any other gueses? lemme know - steve
Old Feb 10, 2004 | 06:51 PM
MTL_4runner's Avatar
Sounds like a leaky cold start injector flooding the motor.
Is it tougher to start it after a long time sitting?
Old Feb 10, 2004 | 07:20 PM
grafix43's Avatar
no when it didnt run for 2 days it started fine.... then like i drove and 30 mins later when i tried to start it it wouldnt without gas.... so what else could it be?
Old Feb 10, 2004 | 07:26 PM
That definately souds like a leaky injector.
You giving it gas (actually you are giving the engine air) to burn the extra fuel puddling in the intake.
Old Feb 10, 2004 | 07:30 PM
Fink's Avatar
Sounds like the CSI...I had the same problem. Actually my problem was that the CSI wire had been cut so it wasn't workin at all!
Fink
grafix43's Avatar
so whats my solution? buy new injectors? 1 injector? get them cleaned? - any price estimates would be great also
Old Feb 10, 2004 | 07:31 PM
grafix43's Avatar
Fink
csi = cold start injector? how do i check it? and how much is it ?
Old Feb 10, 2004 | 07:43 PM
There is no good way to check it out, it is usually a "replace it" type of item.
make sure to check all wiring as was mentioned (verify with a multimeter) to ensure operation.
Old Feb 10, 2004 | 11:11 PM
I have the exact same problem, but it happens when I don't start the engine for 2 or more days. What could it be?
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
