possibly a pinion bearing...???
Old Mar 11, 2010 | 05:30 PM
noneckrex's Avatar
driving to northern kentucky this evening i heard a weird noise coming from the rear end of my 97 4Runner. It is continuous and sounds like it is coming from the axle. it is making the same sound as if you were inflating a large truck tire. (like how you can hear the air filling up inside the tire) i thought it may have been wheel bearing but when i move the wheel i dont hear anything... any thoughts?
Old Mar 12, 2010 | 06:00 AM
SkidPalace's Avatar
Check your rear diff fluid level/condition.
When was the last time you had it changed?
Old Mar 12, 2010 | 06:47 AM
hross14's Avatar
How miles do you have on the truck?
Old Mar 12, 2010 | 07:13 AM
STague's Avatar
Drive your rig for a bit and CAREFULLY feel around for something that is VERY HOT. My best guess about sounds like these is metal on metal contact which will generate a lot of heat.
Old Mar 12, 2010 | 05:27 PM
noneckrex's Avatar
i have 145k on this vehicle. i have owned it since beginning of february this year. i have yet to swap the fluid in the rear diff.
Old Mar 12, 2010 | 06:02 PM
BajaRunner's Avatar
Make sure you have your drive shaft lubed properly as well.
Old Mar 13, 2010 | 01:36 AM
mattbatson's Avatar
this is what happened to me.
Sounds like your problem.
I didnt have enough grease in the zerk fitting on the driveshaft slip joint...although I had always added grease to it whenever I was doing the uv joints and such.
Apparently it just takes a crap load of the stuff and it is easy to under lube it.
Old Mar 14, 2010 | 06:10 PM
noneckrex's Avatar
thanks... so far i have come to the conclusion that it is def coming from the rear axle... i will however lube the u joints just to be on the safe side. thanks
Old Mar 15, 2010 | 02:18 AM
mattbatson's Avatar
yeah, it was the slip joint on the driveshaft itself.
also, of course, you are aware of the common problem with the rear axle seals going on these...
Old Mar 15, 2010 | 12:58 PM
noneckrex's Avatar
the axle seals are already gone... my brake drums look like they have been caked with grease and oil.
Old Mar 16, 2010 | 06:42 AM
hross14's Avatar
At 145K i would put my money on the rear needing to be rebuilt.
Jack it up--put it on heavey duty jack stands and put it in gear--listen to the rear end with a hose or something and see if that is where the sound is coming from.
A bad diff will transmitt its noises all the way to the tranny--making it hard to nail down where it is coming from
Old Mar 16, 2010 | 01:04 PM
noneckrex's Avatar
went to autozone just seconds ago to get some rear diff oil and they do not carry and 90w... wtf? then when i asked the gentleman where i could obtain this type of oil he had no idea nor did anyone in the store.... any suggestions?
Old Mar 16, 2010 | 01:07 PM
noneckrex's Avatar
i plan on doing a rebuild this summer. i already have to replace both inner and outer axle seals on both sides....looks like some one pasted grease and oil in my rear drums... i will be replacing wheel cylinders along with all new drums, shoes, and hardware with the seals. i will however jack it up this weekend and try and figure out what is going on... thanks
Old Mar 17, 2010 | 05:47 AM
hross14's Avatar
Thats because most of the folks that work at autozone are retards--its a growing trend in parts houses across America.....and funny because i dont see how they havent been sued for not meeting OEM spec on parts??
IT USED TO BE--guys in the parts houses were retired wrench turners and knew a thang or two about a thang or two----.......
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
shooter86314
Jan 7, 2016 07:05 AM
Matthew Perez
Sep 28, 2015 05:43 PM
justdifferentials
Sep 5, 2015 06:52 PM
Squigglez
Sep 4, 2015 07:33 AM
