Please educate me about the LockRight locker
I paid $215.00 for a Lockright delvered but not including install.
I found a used E-locker for $500.00 and I had to have it regeared for $395.00. You still need a wiring harness $40.00. Then you have to build a control circuit $20.00. I still have to modify my axle housing.
Total $1000.00+
Here's a link to Mike Carters write up.
Andy
Total $1000.00+
Andy
I'll chime in on my locker.
I run the Toyota (TRD) factory electric locker from a '97 4Runner Limited. I got it for $300 including shipping from a Tennesee junkyard I found through Car-Part.com
I spent $22 on components for my home made controller following Mike Carter's design. So I got a selectable locker for $322.
The install is well documented so I didn't bother writing one myself. It was a lot of work but none of the work required a great deal of skill, just patience.
I have heard testimony about the Lock-Right, not much of it was favorable. People say they are loud. The ratchet mechanism will occaisionally give off a loud bang and people will tell you your truck is busted. They say it will turn heads for the wrong reasons. On Ice or snow you never know when it will decide to lock and sent you into a potential spin.
Did your E-locker come with the wiring harness? That's another $40.00 from dealer.
Andy
uhhuh jx. The design of the lockrite isnt a good one. I would hate to be in a technical situation with that diff. If you were on a steep incline where you need a soft touch and that diff decided to ratchet. It would be game over. (its not really ratcheting its basically slipping into notches repeatedly)
Im curious about something though. In canada everything that goes on the market has to go through an approval process where the product is tested over and over again in different real world situations to determine if its a safe product. Only until its proven safe will it be allowed to go on the market.(usually) I cant see that lockrite making it in Canada. It looks like an engineering accident waiting to happen. Does the U.S. have a similar testing facility ?
#25
Andy
Andy
#27
Has anyone installed a Lockright in the front axle of a 1998 or one with the same axle? If so, how does it drive when in 4wd and 2wd? How's the steering effected when in 4wd and 2wd? Any problems? Is the install as easy as the rear sounds like it is?
Chris
Chris
#28
The Lock-Right replaces the spider gears, not the whole carrier, that is why it is weaker.
What it does is a common trait of all auto lockers. They click, bang, lock and unlock sometimes without any rhyme or reason. The Lock-Right and similar lockers have a reputation for clicking more, full Detroits less.
As for a Lock-Right in the front of a 98, it will click and ratchet in 2wd and steering will be heavy when it is under load. When I lock my front ARB in 2wd with the hubs locked, essentially what you would have, the wheel feels heavier, but not unbearably so.
In 4wd, steering will be tough, almost not an option.
#30
I had a lockrite in a '52 dodge m-37 that I ran mostly off-road with 18.5"x44"s, and I have to say I had no issues with it at all. It performed flawlessly. They have been bad-mouthed as being weak, but I have never heard of one breaking...anyone else?
The method of operation is basically like a ratchet. One wheel can turn faster than the other, but it delivers power to the wheel turning slower. Yes, they can hang up, and I wouldn't run one in the front on the street in winter for that reason...but otherwise, I wouldn't hesitate, unless I was building an all-out off-road rig with big tires and big HP, and even then, I would consider it...
Just my $.02.
John
Just my $.02.
John
#31
Originally posted by ravencr
Zedex,
What's a better design then?
Chris
Zedex,
Chris
I think any locker that gives you the choice between full lock and differential is a good one.
#32
Obviously either the e-locker or ARB are better designs, but they also cost 3-4 times what a lockright costs. They better be better for that kind of money. Are there any lockers in the same price range as the lockright that are better quality?
Chris
Chris
#33
yup ravencr. You get what you pay for. I myself would sooner have a clutch limited slip diff. If it needs to slip it will but will slip smoothly. Not ratchet....There may be a way to put bigger springs in a limited slip or modify it so the slip pressure is higher. Not too shur.
My truck came with an e locker . It sure is nice. Absolutely silent. If you can find a used one of those you sure would be a happy camper.
#35
Okay, I'm going to describe my locker.... can someone try and tell me which one they think it is?
It auto locks/unlocks.
Every once in a while it will pop/lock.
It doesn't rachet, at least I never hear any clicking or feel it.
Wouldn't even know there was one on pavement, except for tight tight turns, sometimes during parking, and on occasion if I gas it during a turn it will engage. What I notice is a little chirping and sometimes a little bit of hop.
I have a gravel driveway. When I make a turn, the inside tire will chew up the gravel.
Is this a regular detroit locker? Just a little curious. I love my locker. I'm planning on getting a lockright for the front pretty soon.
ashamsuddin
17
Jul 22, 2024 03:59 AM
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
