Loud engine whine when cold?
I've been noticing this more and more as it gets colder outside.
Gets louder when:
A. Turning the steering wheel
B. Pressing the brakes.
Once the engine is warm, it goes away.
During the summer I noticed a slight sqeakiness before fully warmed up, but I figured it was the accessory belt. I don't know if the two are related.
I have a Flex-a-lite electric fan, original waterpump, original PS pump, original brake booster, timing belt changed last summer (maybe 15K ago?) along with the accessory belts. 18 months on the current plugs, wires, distrib cap/rotor.
Any thoughts?
Gets louder when:
Any thoughts?
whats the weather like? petroleum products mmight not freeze over until extreme temps, but they will thicken up if cold and when the systems try to use this thicker stuff, it may be putting extra stress on components to do
Originally Posted by 96LtdYota
its normal, so dont worry chebby.. everything moves slower in the cold..
Could the water pump sound like this?
Gets louder when:
Any thoughts?
Gets louder when:
Any thoughts?
VR
Repo
Originally Posted by superjoe83
you could try taking all the belts off one morning and see if the noise goes away or not, my bet is that it is you power steering pump or an idler pulley
Originally Posted by hilandfrog
I was wondering if you found out what it was and if you know of an additive you can put into the Power steering pump that will prevent the super cold start sound, perhaps marvel oil, or some sort of ETHO baised lub?? I know its been a few months for this post, but I have very simmular noises so, thanks for any advice in advance.
VR
Repo
VR
Repo
mengquis
Jul 13, 2015 10:39 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
