Fuel Filter Replacement and Issues
Old May 23, 2004 | 09:22 AM
alltheway's Avatar
Hey I was wondering how many miles until you need to replace your fuel filter? And what are the symptoms associated with it. It seems to me that my Runner takes off ok and starts to accelerate ok but at about 3100 rpm is just sputters for about a 1/2 sec or a little more. Is this the fuel filter or something else associated with the vehicle. Thanks in advance.
Old May 23, 2004 | 09:43 AM
bike4miles's Avatar
Major hesitation is usually a sign of a bad fule filter but in your case, since it only happens at high rpms, I'm guessing that isn't the fule filter. Not sure though.
Old May 23, 2004 | 10:20 AM
humanoid's Avatar
Might need to clean your injectors? Drop in a can of BG 44K or any good fuel injector and give that a try. Maybe other members can give you other hints... hope it's a start though!
Old May 23, 2004 | 10:27 AM
Yoda's Avatar
Start with the filter, it's relatively cheap. I replace mine once a year (about 30K).
The aux tank on my cruiser is rusty, I changed it once each fillup if it even made it that far. I carried spares in the glovebox. Have since disconnected it.
Old May 23, 2004 | 10:51 AM
Sunday BBQ's Avatar
How do you go about changing the fuel filter? I've always wanted to change it but I never have know how to do it.
Old May 23, 2004 | 10:53 AM
alltheway's Avatar
The fuel filter is usually located near your gas tank on most 4Runners/Tacomas/Pickups.
Old May 23, 2004 | 11:08 AM
humanoid's Avatar
I beg to differ, the filter on Tacos are located on the inner portion of the frame on the driver's side.
SundayBBQ:
Not sure what engine you have but try taking a look at the link below and I hope it helps you some.
https://www.yotatech.com/~corey/tech...ter/churnd.htm
Old May 23, 2004 | 11:13 AM
pfdaxe's Avatar
The search function is a wonderful thing...
https://www.yotatech.com/forums/show...ht=fuel+filter
bigjstang
Jun 2, 2025 03:56 PM
Regency
20
Jan 3, 2020 07:43 PM
Jmiller1023
23
Aug 6, 2015 07:03 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
