e-locker compatibility
Old Apr 16, 2018 | 09:50 AM
fierohink's Avatar
I have a '99 4Runner with v6/auto/e-locker that I need to have rebuilt. What are my options for direct replacement? Years for 4Rs and Tacos. V6 only? Auto only? I'm not worried about ratio because I can run 2wd until mine comes back.
Old Apr 16, 2018 | 11:14 AM
fierohink's Avatar
Basically I need to know if an e-locked 3rd from an ‘03 Taco axle code B03A will directly bolt into my e-locked rear ‘99 4R housing axle code A04A?
Old Apr 17, 2018 | 09:02 AM
ZUK's Avatar
ZUK
If you trust the axle codes then one is a 7.5" ring gear and the other is an 8".....they don't interchange.
an option......I can rebuild your 3rd.
Ken
Old Apr 17, 2018 | 09:46 AM
fierohink's Avatar
Zuk!!! I’m trying to get something usable so I can ship MY 3rd to you. No truck or a rental for 3 weeks isn’t feasible.
With your expertise, would the B-code 3rd fit and run for 500 miles (40 miles at a time) in my A-code axle housing?
Old Apr 17, 2018 | 10:40 AM
fierohink's Avatar
The confusion I'm running into is the conflicting information on the internet and nobody having hard numbers.
This page decodes a 2001 Tacoma with axle code B04A as an 8" with 4.56:
http://www.lcengineering.com/LCTechP...ARJANUARY.html
But the same company decodes A's as 8" and B's as 7.5"
http://www.lcengineering.com/LCTechP...OYOTATECH.html
Old Apr 17, 2018 | 12:35 PM
fierohink's Avatar
Or can I pull the 3rd and DS and syran/duct tape the housing shut and run around in front wheel drive?
Old Apr 17, 2018 | 10:32 PM
Kolton5543's Avatar
To start with the syran wrap question, no. The axle shafts are supported by the carrier. Doing this will promptly destroy the rear wheel bearings. If I was in your position, instead of trying to find another e-locked third to use as a temporary replament I would look for another assembled open housing for a 3rd gen runner. It would cost less than a e-locked third and be much easier to find. Plus its close to the same amount of work the swap out. The only real down fall is finding a place to store it afterwards. A third is much easier to shelve than an entire axle.
Old Apr 18, 2018 | 06:44 AM
fierohink's Avatar
Kolton you genius. All this time I’ve been trying to make a used 3rd fit my housing, when I had a non-locked housing with a trashed 3rd in my driveway.
“Shoot the hostage” -Jack Traven (Speed)
Brandon13
May 17, 2017 09:14 PM
ranma21
Mar 30, 2011 07:24 PM
808nickh
Jul 26, 2010 11:02 PM
george16
Mar 18, 2004 06:45 PM
jataga
Oct 30, 2003 04:01 AM
