E-Locker or ARB locker...Which is better & Why?
Old Oct 26, 2003 | 11:47 AM
jataga's Avatar
Does anyone have experience with either of these lockers? I'm trying to figure out a couple of things:
Which locker is better and why?
How much for all the parts of each setup?
Have you or a friend had either locker break down and if so, what part broke?
Thanks!
Old Oct 26, 2003 | 11:51 AM
Tacoma Dude's Avatar
First, welcome to YT!
People here are great and you'll learn a lot!
Not that I have any first hand experience but I've heard from a few people that the E-locker is better as the ARB air locker is dependent on the compressor which will sooner or later crap out because of the constant strain of maintaining the air flow.
That's what I've heard though, I don't have any experience to back this up.
Old Oct 26, 2003 | 12:20 PM
OneTrickToy's Avatar
E-locker. The ARB requires constant air to keep the locker engaged. With the E-locker, it is run off of a pulse. It doesn't need constant electricity to run. A pulse engages it. It will stay that way even if the wires get cut.
Old Oct 26, 2003 | 12:26 PM
Flygtenstein's Avatar
I replied to the other thread as well.
I have dual ARB's and love it.
ARB rear thirds bolt right in, e-locker thirds require modifications.
My ARB compressor is no where near "crapping out" after running the lockers for the last 18 months or so. The lockers require constant air pressure to remain activated, but the compressor has a tank so it does not run the whole time.
ARB's engage and disengage quicker.
Cost becomes a wash if you are regearing.
Old Oct 26, 2003 | 01:51 PM
X-AWDriver's Avatar
Are there any aftermarket E-lockers for the 4Runners that are pretty much the same as the OEM one from Toyota or can you buy the stock one? How much does the average install cost?
Old Oct 26, 2003 | 05:10 PM
Mojo_Risin's Avatar
OEM is the only option as far as E-lockers. You can get them used for about 1/2 the price. That's what I did. (www.car-part.com). I had Offroad Solutions (in Lakewood) install mine - cost me about $650 for them to wire it, modify the housing and install it. You could save about $200 off that price if you wire it yourself.
I went the used e-locker route versus an ARB because of the price. But if you got a new 3rd with e-locker your about the same as far as money.
John
Old Oct 26, 2003 | 05:35 PM
jataga's Avatar
John
How much did you get the used e-locker for? did the 650 include the wire? did the wiring harnest and wire come with the e-locker?
thanks for the information!!
Old Oct 26, 2003 | 07:05 PM
joez's Avatar
what about the electrac? limited slip when unlocked, and fully locked when engaged. that is what i would buy.
Old Oct 26, 2003 | 07:10 PM
914runner's Avatar
joez-I dont think the electrac is out yet for the toyota 8" .
I would get an ARB so I have an excuse to get a air compressor too
Old Oct 26, 2003 | 07:20 PM
Darren's Avatar
This was linked on a virtually identical thread earlier this year:
http://www.pirate4x4.com/forum/showt...ARB+vs+elocker
Old Oct 26, 2003 | 07:24 PM
RTdawgs's Avatar
john -
search www.car-part.com for 96-00 4Runners with the e-locker. search carriers with diff lock and whatever gear ratio you want. you can swap the rear third with the modifications. for the front you can buy a 3rd with the ARB and gears set up and just swap that in. at least this is how i would do it.
marc z got 4.88s and ARBs put in a month ago from patrick at 4x4customs near his house. paul is getting 4.88s and ARBs put in (maybe he already has them) too. so try to get a hold of them.
Old Oct 26, 2003 | 07:45 PM
I forget if it is Electrac or the Eaton E-locker, but one of them got sued by Toyota because the locker they were marketing would be fundamentally identical to the stock Toy e-locker. Because of this, there will never be one of those, I want to say the Eaton one, available for a Toy.
Old Oct 26, 2003 | 08:32 PM
Mojo_Risin's Avatar
I got mine used for $325 - shipped to my door. No it didn't come with the wiring harness.
I'm still curious if anyone has tried Inchworm Gear's "E-Locker control Kit" for $75
"The electric locker control kit contains everything you need to engage and disengage your new electric locker. The switch, wires, relays, resistors, connectors, and zip ties are all included. It's also complete with instructions so you can install it."
--From Inchworm's website... www.inchwormgear.com
That seems like a fairly inexpensive way to wire it up.
John
Old Oct 26, 2003 | 09:22 PM
WolfpackTLC's Avatar
ARB... hands down. It's a stronger carrier. For serious wheeling everybody knows that you choose between a Detroit and an ARB. Nothing else can replace the carrier w/ anything stronger except for a spool.
Old Oct 27, 2003 | 04:18 AM
Arnold's Avatar
ARB because they make a cool sound when you disengage 'em.
Old Oct 27, 2003 | 04:26 AM
jataga's Avatar
Ha! That could be a deciding factor.
Old Oct 27, 2003 | 12:07 PM
INsr5runner's Avatar
is the inchworm E-locker just the OEM one?
Old Oct 27, 2003 | 07:54 PM
Shane's Avatar
Yes. Jim sells new e-locker diffs for a decent price and can regear them for you. His service is excellent.
As for the $75 kit, you can get everything you need to build a crude control system for around $20. In my opinion if you're gonna spend that much for the electronics you might as well go all the way and use the stock ECUs, they work very well and give you some basic diagnostics info through the indicator light.
Old Oct 29, 2003 | 07:01 PM
runnerboy97's Avatar
How bout a good place to find used elocker, cause they are probably cheaper. I didnt see any decent priced one on car-part.com
Old Oct 30, 2003 | 04:01 AM
transalper's Avatar
I just did a search and found a bunch of e-locker diffs on car-part. Try searching for "carrier." Here's one:1997 Carrier Toyota 4Runner Axl, w/diff lock, 4.30 ratio- A04A N30634 $300.18 LKQ - Midwest Auto Parts USA-NE(Omaha) E-mail 1-800-456-9683
Go for it!
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
choppe777
May 16, 2016 08:00 AM
zz_denis
Sep 6, 2015 03:43 PM
justdifferentials
Sep 5, 2015 06:52 PM
