Is this the daytime running light switch? *pic*
That is it. Unplug it and no more DRLs. I recently plugged mine back in because when I hooked up my PIAA driving lights they did not behave properly with it unplugged. Anyone have any ideas/knowledge about this?
Mason Dixon, where in Huntsville are you?
From: Far western Kentucky (transplanted from central PA)
My plug for the DRL's are in between the battery and the fender. It's a gray connector. I had mine unplugged a few years back with no problems but ended up plugging them back in.
i recently installed a hi/lo hid kit on my 2000 4runner. i'm not sure if all the kits are the same but the way mine wires in it plugs into the factory headlight harness on the dr/batt side and then runs from that side to the pass side headlamp leaving the pass side headlamp harness unplugged. i tried unplugging the resistor box, tried removing the drl fuse, and still the drl's remain on. what other options do i have? anyone else had this problem or know how to solve it? i really want to stay away from cutting wires.
yea i tried unplugging that box and it didnt help i think it is becuase of the hi/lo hid kit i installed.the way mine wires in it plugs into the factory headlight harness on the dr/batt side and then runs from that side to the pass side headlamp leaving the pass side headlamp harness unplugged. not sure why this would matter but unplugging that box has no effect. there is a seperate relay that wires in with the hid kit because of the plunging bulb that adjusts where the light goes when you put the high beams on.
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
