?? about clutch master cylinder..
I was wondering if there is a master cylinder mod I could do. I replaced my CMC about 2years ago an it just failed, I replaced it with another one and the pedal feel is real hard. I was wondering if I could swap in a CMC from another year Toy. I was going through the Beck-Arnly book at work and it looks like Toyota used the same CMC for a bunch of years. I have done the swap on a nissan break MC to get better pedal feel but what can i do for my 'yota?
what kind of clutch are you using if you have one with a stiffer pressure plate that would make the pedal hard. if you have the book at work you should know if you can use one from another year.
Ok maybe I should rephrase the question. Is there a better CMC that I can use that is proven to work in a toyota app? Something with a bigger bore? Something from a heavy-duty application?
Troy
YIKES thats a REALLY hard clutch....as far as i can remeber atleast
basicly liek said above you need a stronger master and slave cyl...or maybe bleed\fill it perfectly.
im about to do a whole clutch job to my new MR2...im gonna drop the tranny...which is a huge PITA because the motor is sideways...new master and slave cyl also
should be fun...not
should be fun...not
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
