?? about clutch master cylinder..
Old May 28, 2005 | 06:54 PM
LOCKnGO's Avatar
I was wondering if there is a master cylinder mod I could do. I replaced my CMC about 2years ago an it just failed, I replaced it with another one and the pedal feel is real hard. I was wondering if I could swap in a CMC from another year Toy. I was going through the Beck-Arnly book at work and it looks like Toyota used the same CMC for a bunch of years. I have done the swap on a nissan break MC to get better pedal feel but what can i do for my 'yota?
Old May 28, 2005 | 06:59 PM
DudeBud's Avatar
what kind of clutch are you using if you have one with a stiffer pressure plate that would make the pedal hard. if you have the book at work you should know if you can use one from another year.
Old May 28, 2005 | 07:18 PM
LOCKnGO's Avatar
I have a centerforce stage 2.
Ok maybe I should rephrase the question. Is there a better CMC that I can use that is proven to work in a toyota app? Something with a bigger bore? Something from a heavy-duty application?
Old May 29, 2005 | 06:02 AM
YotaJunky's Avatar
If your clutch MC failed on you in only 2 years, it's possible that air was still in your system. I just did both the MC and SC yesterday and bled it with a pressure bleeder. It works great and I noticed that the pedal is not stiff like the old MC that went out on me. The old MC gradually got stiffer and stiffer , squeaked and popped, and finally started leaking from the push rod about a few days ago. Swapping out the MC was easier than the SC. IMO, I would stick with OEM for proper fit and quality.
Troy
Old May 29, 2005 | 06:46 AM
89macrunner's Avatar
YIKES thats a REALLY hard clutch....as far as i can remeber atleast
basicly liek said above you need a stronger master and slave cyl...or maybe bleed\fill it perfectly.
im about to do a whole clutch job to my new MR2...im gonna drop the tranny...which is a huge PITA because the motor is sideways...new master and slave cyl also
should be fun...not
Old May 29, 2005 | 01:59 PM
4Crawler's Avatar
I replaced the MC in my '85 about 6 years ago with one from Toyota, been working fine ever since.
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
mxdw88
Sep 20, 2015 03:13 AM
Squigglez
Sep 4, 2015 07:33 AM
