97 ltd rear is sagging.
Old Aug 20, 2003 | 07:52 PM
halza's Avatar
Cool 97 ltd rear is sagging.
I know that the 3gen runners are not supposed to sag, but mine does a little, even though I have no weight on it, is it posible to bring the rear up about an inch installing longer shocks?
Old Aug 20, 2003 | 08:40 PM
calg3's Avatar
No, longer shocks will not help at all. You need better springs. You can order Downey or OME or PP rear springs that will fix the sag. Do you still have the stcok shocks under there? Look at this website for a lot of good information:
www.wheelersoffroad.com
Old Aug 21, 2003 | 06:26 AM
rimpainter.com's Avatar
There is a recall on the 3rd gens also.
If its a 4x4 you will get: New rear springs and bumpstops.
2x4: New rear bumpstops.
Call the dealer with you VIN and see if you are eligible. You should be.
Old Aug 21, 2003 | 06:41 AM
rwmorrisonjr's Avatar
From: Home: Aurora, CO; Work: The People's Republic of Denver
Is there a TSB number and the years effected by the recall?
Old Aug 21, 2003 | 06:47 AM
bamachem's Avatar
after getting the recall performed, then order a set of TRD air suspension bags to level it out and soften the ride. do a search on here for more info. they are only about $40.
Old Aug 21, 2003 | 06:50 AM
Post
This will answer everything you need to know.
It will take a minute to load the PDF so be patient.
Old Aug 21, 2003 | 07:03 AM
Thanks, looks like it only effects early 3rd gen 4Runners. Guess I'll have to get those Bilsteins after all!
Old Aug 21, 2003 | 10:48 AM
SLC Punk's Avatar
Halza, I had the same problem with my '97. Mine sagged so bad, it would bottom out when I had 2 people in the back seats. I replaced them with Performance Products springs (this was before the recall was announced). These springs are a lot stronger than stock. I have never bottomed out even with my rig full of camping supplies and pulling my 18' boat.
Old Aug 21, 2003 | 11:30 AM
halza's Avatar
Thanks a lot for the info, I actually had the recall springs installed not long ago, I will try the TRD bags and see what happens.
Old Aug 21, 2003 | 11:33 AM
halza's Avatar
Where can I find this trd suspension bags? any website I can visit? thank you very much.
Old Aug 21, 2003 | 11:36 AM
If they did the recall in the past 12 months, you should have the springs replaced under warranty. I would push the issue.
okamikai
Apr 30, 2018 10:19 PM
kirkrunner
Jul 27, 2015 07:59 PM
SMOD
Jul 27, 2015 01:45 PM
Athansinis
Jul 27, 2015 08:38 AM
icentropy
Jul 14, 2015 10:23 AM
