Fixin' the CV
Old Aug 20, 2003 | 10:01 PM
Robinhood150's Avatar
CV rebuild kit
Well I'm sitting here in the middle of my living room cleaning and rebuilding my axle. It's a good thing the wife is sleeping. The manual says to use 9.6-9.9 ounces of the brown grease in the inner tripod joint. 9.9 ounces is the whole tube and I just wanted to make sure I'm suppose to squirt the whole thing in there.
Old Aug 21, 2003 | 05:34 AM
david in germany's Avatar
david in germany
about to do mine too (when I get the hub nut socket) but I have Q too. white on the outside and brown on the inside? Why?
sooo confusing.
David
Old Aug 21, 2003 | 05:35 AM
Reldnew's Avatar
I've always used the whole tube and never had a problem.
Old Aug 21, 2003 | 05:58 AM
Highland Runner's Avatar
The grease is different because the joints are different. The inside joint is a tulip joint with 3 little bearings. The outside is a standard cv with large balls that roll in groves.
Old Aug 21, 2003 | 06:27 AM
Talking nevermind
almost made a "ball" joke
lol
David
Old Aug 21, 2003 | 06:30 AM
I know. At least all our trucks have the same size "balls".
Old Aug 21, 2003 | 06:36 AM
TDiddy's Avatar
Steve, I hope you took pics of that! Sarah would put me in the hospital if I ever tried something like that.
David and Highland Runner, click here.
Old Aug 21, 2003 | 07:20 AM
Wow, I think the cops would pull you over for having those nuts on your truck.
Old Aug 21, 2003 | 08:05 AM
MTL_4runner's Avatar
Ok enuf with the lubricant and ball jokes...
Old Aug 21, 2003 | 10:21 AM
Stump1883's Avatar
Okay guys I got a serisous queston for ya here. Not that I don't enjoy a good nut joke like everyone else but this has been on my mind for awhile now. There is a sound coming from what seems like the front of my truck, it sounds like a dime being rattled in a glass jar, tink, tink, tink kinda sound. Now I know my inner CV boot has seperate from the axel all together but would that sound be a hit that I need to replace the whole shaft or just add the new boots and greese to both inner and outer? I have been told that I don't need to replace the axel shaft unless I hear sounds, but would that be a sound from the axel be worn out or coudl I get away with just cleaning up the shaft really good and adding new boots? Thanks, and now that I'm done and if someone could answer my question, I just inadvertenly(sp) added another punch line for someone, shaft, to go along with balls and lube. So have at it.
Old Aug 21, 2003 | 10:24 AM
SLC Punk's Avatar
Is your CV boot torn? If so then I would replace the whole axle. The grease has fallen out and dirt has already contaminated the joint. That's why you are getting the "clicking" sound when turning.
If the boot is just cracked, you MAY be able to just change the boot, only if the joint doesn't show any signs of wear.
My guess is that if you are getting a sound (clicking when turning) then your joint is toast, and it would be best to get a new axle.
Old Aug 21, 2003 | 10:26 AM
SLC Punk's Avatar
Re: CV rebuild kit
I used the whole tube when I replaced the boots on my Celica. No problems here.
Old Aug 21, 2003 | 10:28 AM
Stump1883's Avatar
Thanks for the speedy response.
That is what I was afraid of, it's not just when turning it's all the time, it goes away after you get going but I think that's just b/c of the wind sounds and engine noise. So now I will have to shell out another $100 or so and find some more free time than I thought.
Old Aug 21, 2003 | 10:36 AM
SLC Punk's Avatar
Most people only realize it when they are turning sharp (like into a parking space). I think the sound also has to do with how much stress you put on the joint itself (turning sharp puts the most stress on it. When you drive fast, you don't turn that sharp, so you don't notice the sound as much)
Replacing the axle is a heck of a lot easier than installing new boots. All you do is pull the old axle out, put the new one in, and return the old axle to get your core deposit back.
Replacing the boot, you have to take the axle out, take the inner boot and joint off, take the old outer boot off, put the new outer boot on, put the new inner boot on, put the inner joint back on, don't forget the grease! Very messy!!
Old Aug 21, 2003 | 10:37 AM
Stump1883's Avatar
Anyone have a write up or knoe of one about how to replace the front axel and CV boots, I'm pretty mechanically inclinded but I have never done CV or drivetrain work, so a write up would be appreciated. Thanks agian.
Old Aug 21, 2003 | 11:04 AM
Hey! this is my thread! J/K
When I was searching last night I came across at least 1 writeup. Search for CV boot.
Old Aug 21, 2003 | 11:20 AM
hey
some of us like to lube our shafts!!! and the mesyer the better
but some times you just have to break down and get the shaft.....
Old Aug 21, 2003 | 12:11 PM
wimpywade94's Avatar
actually my friend has a set on his 89 pickup, its red and it has blue balls.....cops never said anything to him when we got pulled over....his girlfriend on the other hand hates them!
later
wade
Old Aug 21, 2003 | 12:42 PM
SLC Punk's Avatar
Re: hey
Oh ya, the worst thing you could do is run dry!
Yotard
195
Jan 20, 2020 02:30 PM
HaydenConQueso
Mar 20, 2015 06:28 AM
beck85
Mar 15, 2010 05:44 PM
