3.4 Engine Design and INFO--NEEDS A STICKY
Old Mar 18, 2010 | 09:38 AM
hross14's Avatar
Folks--here is a great piece of info on the 3.4 and it design and operation.
This should be a sticky for folks to read--
http://www.mr2.com/files/mr2/techinf...a/3vzVS5vz.pdf
Old Mar 18, 2010 | 09:59 AM
HazMat's Avatar
Lots of great info and good illustrations in there. Good find. Thanks for sharing
Old Mar 18, 2010 | 12:13 PM
Elton's Avatar
x2 great info
Old Mar 18, 2010 | 12:28 PM
DailyDrive's Avatar
Well that explains why this engine needs dual-electrode spark plugs. Doesn't explain why everyone else would not use them too, if they work as described.
Old Mar 18, 2010 | 01:00 PM
mt_goat's Avatar
Yes, great info.
Old Mar 18, 2010 | 03:21 PM
Beto's Avatar
Nice find, I saved a copy.
Seems a little funny in a few spots though...did they say better fuel economy? Ha, it's a very thirsty engine for the HP. The ignitor coil description reads along the lines of "...allowing it to be light weight and compact...", no matter how much I like these engines I can't help but read that as "...allowing it to be made cheaply..." - makes be want to replace the whole setup after seeing the driver's side plugs on way-too-many of these engines...
Old Mar 18, 2010 | 03:28 PM
b0n3mast3r's Avatar
what these 5VZ–FE use 91 gas
Old Mar 18, 2010 | 03:36 PM
Beto's Avatar
It says so, but that's not the number on the pump. It says 91 RON - meaning Research Octane Number. The number on the pump is an average of RON and MON (Motor Octane Number) - if you look at the fine print it'll usually say "(RON+MON)/2". The MON is usually 8 or 10 points lower than the RON, bringing the average down. So the "regular" gas at 87 or 88 octane actually has a RON about 4 to 5 points higher than 87 or 88.
Hope I'm clear, but read this if you want http://en.wikipedia.org/wiki/Octane_rating
Old Mar 18, 2010 | 03:45 PM
Matt16's Avatar
quote: "3.4–liter, 24–valve DOHC engine based on the acclaimed 3VZ–E engine."
hmm, about that "acclaimed" 3VZ-E...
Old Mar 23, 2010 | 10:13 AM
hross14's Avatar
Bumpity
Old Mar 23, 2010 | 10:33 AM
mt_goat's Avatar
Very interesting, thanks. So if I read right from that chart 91-92 RON = 87 at the US pump.
Old Mar 23, 2010 | 11:32 AM
rimpainter.com's Avatar
I came across this link the other day when someone asked about the two capped brass connector thingies on the 5VZFE throttle body and what they're for. Awesome link!
So, does anyone know? I bet a tech at a dealership would know (but they might be a bit busy right now).
Old Mar 23, 2010 | 11:41 AM
TonkaYota's Avatar
awesome link! ty for the info!!!
Old Oct 13, 2013 | 08:44 AM
t100 noob's Avatar
Hey need a tech question answered. So the black vacuum box with the power steering line and some other line going to it I'm guessing the idler line. I redid my intake and diconected those lines from the box and put breather filters on them. They're drawing air from the intake anyways. There's no harm in this correct? Ps. It makes a cool
Sucking sound now when I turn.
XtraCab
Apr 12, 2020 05:25 AM
Road Bull
Oct 10, 2015 04:55 PM
nick9455649
Sep 11, 2015 05:10 PM
mengquis
Jul 13, 2015 10:39 AM
TokyoD23
Jul 12, 2015 06:01 AM
