Z's Confederate Toy's 1987 Pickup Build-Up Thread
Old Aug 23, 2011 | 06:44 AM
  #861
xxxtreme22r's Avatar
the three ports on top of the carb aren't for A/C they are for HAC (High Altitude Compensation) Yes they get plugged if you don't have that system.
See those three plugs? I have also seen some people attach a vacuum hose on top of one or more of those plugs just to plug another line.
Old Aug 23, 2011 | 07:32 AM
  #862
csuviper's Avatar
Yea there were like 3-4 plugs with vacuum hoses. All hoses had a home. It really confused me but that makes sense. Don't know what else was plugged. I actually have a spare carb. The carb that is on the truck now doesn't even have the third port (long one just under the top one in the pic). It was built without it.
Will I pass emissions in Colorado without the HAC?
You should jump over to my build thread so we don't keep cluttering up Z's build.
Old Aug 23, 2011 | 10:47 AM
  #863
4x4YOTA's Avatar
That green is really bright in the engine bay... Hope you get it running tonight
Old Aug 23, 2011 | 01:14 PM
  #864
Z's Confederate Toy's Avatar
Its all ready to fire all I need is to run to the parts store and get some oil. I forgot it the last time I was there.
Old Aug 23, 2011 | 01:17 PM
  #865
csuviper's Avatar
Right on, good work. Feels good to be there, huh?
Old Aug 23, 2011 | 01:34 PM
  #866
ChefYota4x4's Avatar
What my 2nd girlfriend said after seizing her 87 Fiero Turbo(her first mistake! lol)..... We all said, "Did you ever check the oil?" Her response...... "What? .... it had oil when I bought it!" hehehe,
Anxiously awaiting the 'START YOUR ENGINESSSSSSSS!' MOMENT!
Old Aug 23, 2011 | 06:45 PM
  #867
Time for a test drive!!!!!!!!!!!!!
Old Aug 23, 2011 | 08:12 PM
  #868
I made it out of the driveway and down the street to the intersection. It ran out of gas with like an 8th tank. I think the timing might be off not really sure tho. Now it wont start at all.
Old Aug 23, 2011 | 08:15 PM
  #869
csuviper's Avatar
Bummer. You have a timing gun right?
Its 8 before top dead center.
Old Aug 23, 2011 | 08:25 PM
  #870
You rap on the tank to be sure it's not totally empty(faulty gauge?)
Sorry to hear that, man! Stock timing is 5*BTDC and with most any CAM, like my 261 from Engnbldr, it's 8*BTDC.
Keep us updated as to all you're trying/rule out, .....don't wanna waste your time with stuff you've already tried/already know to try.
Old Aug 23, 2011 | 08:28 PM
  #871
Yeah Ive got a timing light. I havnt thrown it on there yet I jus stabbed dizzy about where it should be. I think its a tooth off
Old Aug 23, 2011 | 08:30 PM
  #872
I put 3 gal in it before I tried it and 5 after it died
Old Aug 23, 2011 | 08:38 PM
  #873
You know the rule with Dizzy install, right?
Just for the heck of it...>>> lol>>>>
1. Get to TDC on Compression Stroke
2. Insert Dizzy with Rotor pointing at 12'o'Clock on the dot
3. As it slides in, it will fall back on the gear to 10PM or so(#1 on the Rotor/point position)
4. If you have to verify it VISUALLY, .... pull the cover and make sure the dimple in the Dizzy Gear is JUST before the cam gear, counterclockwise.
Not sure why it would stall after 5 minutes due to only that... but I guess it's possible. Stall, sure, maybe, but not start again? Not sure on that, Zach.
Old Aug 23, 2011 | 08:59 PM
  #874
I think that where I went wrong. Pretty sure its a tooth off. Its got me stumped but Im doin some research
Old Aug 24, 2011 | 09:34 AM
  #875
I think its the fuel pump or a clog in the line. The carb sight glass has no fuel in it. I unhooked the line from the pump to the carb and no gas when I crank it over. Also replaced the fuel pump with a OEM one so thats out of the equation. I am gonna do one more test before I replace the pump.
Old Aug 24, 2011 | 10:19 AM
  #876
Watching .... ... baited breath!
Old Aug 24, 2011 | 06:25 PM
  #877
One replaced pump and a 4 hour, nightmare testdrive later... Its getting enough fuel to the carb to idle and move for about 40 ft before it dies. When I look at the sight glass the gas drips once then about a second and a half goes by before another drip. It doesnt flood in like it should. Idk what the prob is. Maybe a clog in the tank?
Old Aug 24, 2011 | 06:41 PM
  #878
Mixed the fuel lines up? Fuel filter? forget the fuel pump spacer?
Old Aug 24, 2011 | 06:46 PM
  #879
I got the lines like the 85, I just replaced the filter, and I got the spacer on there
Old Aug 24, 2011 | 07:27 PM
  #880
so you got 3 lines hooked to the fuel system? Vent, return and supply? Not familiar with the 85 setup, so I don't know if it's different then the 87.
