Z's Confederate Toy's 1987 Pickup Build-Up Thread
Old Mar 17, 2010 | 10:42 PM
Z's Confederate Toy's Avatar
Z's Confederate Toy's 1987 Rock Rat Build
I got this '87 on Monday for $900. It has power steering, A/C, and cruise control. It needed brakes, and a water pump. Once dug into it the inner and outer bearings needed replaced along with the inner axle seals. We went ahead and did the spark plugs, cap and rotor, plug wiress, oil change (synthetic), all new coolant, and a Optima Red Top. Here are some pics:
I like the "real way" of spelling Toyota
The cruise control unit, has anyone ever seen this? I have never come across it.
Driver side view
New driver side rotor and bearings (bearings not visible...duh)
The cruise control knob
Driver side rust in bed, not bad at all compared to my '85
Tailgate, it does not open, dunno why. I will investigate tomorrow
The passenger side spindle, will finish tomorrow. after I help my buddy fix his Jeep
I have to go see the Toyota dealership to get some parts the local parts store does not have:
The six hub bolts
Outer hub gasket x2
Hub c-clip x2
Caliper mounting bolts x2
The kid I got it from did not know how to take stuff apart at all!!!
Old Mar 17, 2010 | 11:53 PM
yotaman85's Avatar
looking good man, keep it up and you'll be golden in no time.
Old Mar 19, 2010 | 07:52 PM
I got her running tonight!!! The brakes are bled, rims torqued, the heater control switch has been replaced. Took it for a test drive around the neighborhood, there is a grinding sound in the rear (I think the right read rim is rubbing the drum), the idle needs to be advanced (it dies when coasting), I think it needs new shocks. Otherwise, it is great! While I was bleeding the breaks I was looking around and noticed the frackin left rear shock is missing the shaft, I'm pretty much thinking its not supposed to be like that.
Old Mar 19, 2010 | 08:11 PM
87hillbillyoter's Avatar
nice truck man. i got an 87 just like it, cept the cruise control knob just hangs there... but anyways, i like your truck
Old Mar 19, 2010 | 09:28 PM
Mine isnt hooked up, the last guy un-hooked it.
Old Mar 19, 2010 | 09:41 PM
toyomoto's Avatar
i'd like to see that left rear shock! or what is left of it! haha!
Old Mar 20, 2010 | 05:36 PM
The broken shock
Another shot of the broken shock
The truck finally out of the garage
We got like 8-10 inches of snow in the "blizzard" yesterday.
Can anyone spot the deer in the 3rd pic? There were actually 5.
Old Mar 20, 2010 | 06:03 PM
slacker's Avatar
cruse control is NOT stock .. but an add in ..
just to let you know ..
and yep .. rear deer spotted
Old Mar 20, 2010 | 06:06 PM
BackGateYota92's Avatar
ha i think i see two deer. lol nice truck btw
Old Mar 20, 2010 | 07:38 PM
Thanks on the CC info. We get deer in the yard almost every day out here.
Old Mar 22, 2010 | 07:07 PM
Took the truck for the first real drive, runs amazing. Two things though, it backfires when I let off the gas and there is a grinding noise somewhere. I checked the the temperature of the rear axle shafts, the drums the rims, the diffy, and I also checked the front diffy and the rotors. Nothing was overly hot, the only thing I could think thats left is a worn out U-joint or drive shaft. Seemed to get good mileage, plenty of power, tight tranny, 4wd works smoothly. Now to get tires, shocks, CB antennas, new stereo deck, basically the cosmetic stuff. I am thinking about an SAS though, my dad beggs to differ that IFS is better than solid.
Old Mar 23, 2010 | 08:50 AM
graduatedpine's Avatar
Nice find, this truck is gonna be fun!
Old Mar 23, 2010 | 09:10 AM
ha tell your dad to check his sources haha
Old Mar 23, 2010 | 07:00 PM
I asked him why he thought that and he said "Why would Toyota switch from solid to independent if it wasnt better". I said what ever old man. I decided to do a SAS, but mat not go Toyota, Im thinking about using a Dana 30 out of a Early Bronco (since I have it just laying around).
Was attempting to get to Denver to pick up smore parts but since the blower motor is out the windshield was fogging up quicker than I could wipe it off. Since I couldn't see I just went back home. Before I did though, I couldn't help to play around in the parking lot!!! (the pictures are from my phone , thats why they are sideways)
Old Mar 23, 2010 | 10:07 PM
kayakken's Avatar
mmmm chicken and dumplings mre yum
nice truck good find
Old Mar 24, 2010 | 01:42 AM
Dgfriend707's Avatar
subscribed!
Old Mar 24, 2010 | 07:40 AM
Twas good, I could live on MRE's if I had to!
Old Mar 24, 2010 | 08:02 AM
broncrider's Avatar
thats a good looking truck for 900. good progress. with the grinding grab your drive shaft and see if the pinion has come lose. had that happen to my one ton ford. pinion came lose. started as a little noise. then one day it just went bad. lost the hole inner bearing. just an idea.
Old Mar 24, 2010 | 08:06 AM
Ok, I'll check it out thanks.
Does anyone know where to get a a cheaper Weber conversion kit for the 22r? Which one would I use? I am also going to do an EGR delete kit, since I live in the mountains where emissions are not necessary.
I'm thinking about painting the truck OD or snow camo.
Old Mar 24, 2010 | 10:25 AM
kayakken's Avatar
I got a case of them just in case things go bad
2012 ya know
I will get all kinds of toy parts for 2 bottles of water and gallons of gas for a mre
but to stay on topic what are you doing next on your truck
Ken
