yotarob2005's 1986 4Runner Build-Up Thread
Old Mar 24, 2010 | 05:05 AM
  #121
92 TOY's Avatar
hahahahaha
still...it's progress.
Old Mar 24, 2010 | 07:52 AM
  #122
yotarob2005's Avatar
I got 2 thing I need marked off my list today. To my suprise the heli-coil kit that I ordered to fix the hole in the bottom of the exhaust manifold came in on UPS this morning & my buddy here at work brought me his timing light to borrow for when I get this thing started.
Old Mar 24, 2010 | 10:30 AM
  #123
Drilled out the holes in my exhaust manifold on my lunch break & got the thread inserts installed. A couple of new studs & nut & this bad boy is good as new. No more exhaust leak. I bought some black VHT "flame proof" header paint that is rated for up to 2000 deg. that I am going to paint it with before I put it back on.
Old Mar 24, 2010 | 12:30 PM
  #124
My87Runner's Avatar
looking good
Old Mar 24, 2010 | 12:31 PM
  #125
My87Runner's Avatar
wiring is fun huh
Old Mar 24, 2010 | 12:57 PM
  #126
Originally Posted by YotaR
looking good
Thanks, getting close!
wiring is fun huh
Very glad that the wiring is mostlly behind me
Old Mar 24, 2010 | 08:40 PM
  #127
Help
OK all of the vacuum lines are connected, all of the electrical connectors are plugged in. I have 2 problems. First is something to do with my starter. When I turned the motor over with a wrench on the crank pulley, I heard a noise that made me think of 2 gears meshing together. By no means a violent or bad sounding noise. I listened & felt around while I was turning the crank pulley & tracked it down to my starter. I loosened the started bolts & turn the motor over & the noise is gone. Tighten them back up & it makes the noise again. I have heard of shimming starters before, What is the deal?????
Second I have a left over bracket that I can't find a home for. I'm sure that I will feel stupid once somebody points it out for me, but I looked & looked & looked & don't see any place for it??? Here is a pic of the bracket.
Old Mar 25, 2010 | 01:57 AM
  #128
92 TOY's Avatar
I'm thinking power steering bracket...let me check...
Old Mar 25, 2010 | 02:18 AM
  #129
92 TOY's Avatar
NOPE!
mines laying in a box, unlabeled.....a/c????
Old Mar 25, 2010 | 02:50 AM
  #130
92 TOY's Avatar
OUCH...can't find, will keep looking for ya.
Old Mar 25, 2010 | 02:57 AM
  #131
92 TOY's Avatar
try OLHARLEYMAN's thread....posts #41 and 44
https://www.yotatech.com/forums/f116...41/index2.html
Old Mar 25, 2010 | 02:59 AM
  #132
92 TOY's Avatar
looks like alternator bracket
Old Mar 25, 2010 | 04:37 AM
  #133
That's it 92 TOY, thanks a bunch man!!!
  #134
Now what is the deal with my starter???
Old Mar 25, 2010 | 04:38 AM
  #135
92 TOY's Avatar
No clue man.......sorry....gotta hit up the troops for that one.
Old Mar 25, 2010 | 04:39 AM
  #136
92 TOY's Avatar
had quite a few WTF? moments while looking for that part......I'm sure I was going to ask that down the road too.
Old Mar 25, 2010 | 05:42 AM
  #137
I asked a couple of guys here at work, just general shade tree type mechanics, and they both asked me the same question...."did you put the flex plate on backwards" ....Well I sure hope not! I don't think I put it on backwards, I only had it iff for a couple of minutes while I changed my rear main seal. It I have to take that back apart I am going to be livid!! Some body please tell me that it could be something else.
Old Mar 25, 2010 | 06:14 AM
  #138
92 TOY's Avatar
bump.....
Old Mar 25, 2010 | 06:20 AM
  #139
Not sure if I am going to be shot for this but I started another thread in the newbie tech section regarding the starter problem, hopefully it will get a little more attention.
https://www.yotatech.com/forums/f120...kwards-207950/
Old Mar 25, 2010 | 06:25 AM
  #140
92 TOY's Avatar
I saw it.
I know there's sometimes some consternation about asking the same question in more than one thread, but this is one of those times where it's of an urgent nature. I don't think there will be an issue.
threads with more than a few posts are kinda a turn-off for me anyway....lot's of reading to catch-up on to finally arrive at the current situation.....so I could see a new thread catching more attention rather than an established one....like mine for example...I ramble alot in mine.
here's hoping you get an answer quickly.
