Twistedyota's '87 4Runner Build thread
Old Mar 31, 2011 | 03:22 AM
  #141
Terrys87's Avatar
I just did the brakes on my wifes truck and it was the first time for me on a Toyota 4x4. A friend of mine said it was a about the easiet thing you could do. I was on my way to work when I heard it start squealing and didnt have time to go back home. Just used a C-clamp. That is a really nice setup.
Soon as we get some decent weather, hubs is on the list. Some hubs spin nicely and others are hard. Its been awhile on since I have done hub work. Seems like it is not that bad of a job to do.
Did you have to do any work with the tracks in your back hatch? Mine seem to be binding. Trying to work up the courage to tear everything apart and redo it. Just afraid I might get in over my head but want it working right.
Old Apr 4, 2011 | 10:27 PM
  #142
twistedyota's Avatar
i havent done any thing to my truck lately
but i got a pair of used rear shocks off a ford ranger. tht compress great but rebound slowly. im gonna put them on the grey one sometime because my current shocks are maxed out with the install of the coils, and these shocks are about 4-6in longer i believe. not sur until i take them out.
terrry: as far as the back i havent had to do anywork to my tracks.
Old Apr 5, 2011 | 06:29 PM
  #143
engine work
i think im going to send my head out and have it cleaned, pessure checked and if its good resurface for about 130.
Old Apr 6, 2011 | 08:55 PM
  #144
Exclamation head!
so i helped a friend work on his 82or83?(cant remember) truck today. he bought the truck and the head was bad(dont remember what was wrong with it) but when i got their he had tried to put a 22re head on the 22r. and was told on here tht he was stupid for trying it and tht they are differant heights by 7mm so he bought a 22r head to put on it.
but back to me, since i helped him he is selling the 22re head to me for real cheap. so hopefully ill have my grey runner running soon. YAY!!!!
Old Apr 7, 2011 | 03:17 AM
  #145
Terrys87's Avatar
Glad to hear you are getting the head. I would still have it checked. The machine shop I use charges $35, to make sure it is level and no cracks. Maybe soon you will have it running. The weather is getting nicer so hopefully we all can make a little progress.
Dont know why somebody would call him stupid for putting the wrong head on if he didnt know about the change in engines. Im not sure exactly what year they changed, but it wont work.
So how you coming along on the SAS? Still aquiring parts?
Old Apr 7, 2011 | 11:27 AM
  #146
he already had the head cleaned, pressure checked and resurfaced. so its all good.
as for the SAS i either need to find a front housing tht is not bent or try to straighten mine.
Old Apr 8, 2011 | 05:45 PM
  #147
so a while back i decided to use a ceramic skull as my shifter nob, in i liked it except the fact tht all i did was wrap sum electrical tape around the shifter and slide it on, easy install but it also ment it could come off and the worst time it came off was when i was sliding off a road down a hill when i went to down shift. so i decided to fix this the other day
here is a nut grinded down to fit in the skull
and here is it test fitted in the skull
now the bad news:
i took the skull and smacked it down so the bolt would hit to push the nut in farther, well the hole in the skull was tapered so it cracked the skull in half
but i put some jb weld on it and put it together now i just have to hope it lasts.
now on to the good stuff
i got around to cleaning a few engine parts
after using a wire brush
after a cleaning in the solvent tank
and all painted
i have to do a few touch-ups but its a good 5-10ft paint job
and 2 brackets and the fuel rail done up also.
Old Apr 10, 2011 | 03:17 AM
  #148
Terrys87's Avatar
A shifter knob sliding off at the worong time can be a bad thing. I tried to do my covers like yours and Chefs, and just could get the same reuslts that you two have gotten. Its looking good.
Maybe a suggestion. I got from Yotarob, is to put clear coat when done. It helps to clean up easier. It comes in a spray can.
Cleaning parts is a step closer to getting it put back together and running. Looking forward to it.
Old Apr 10, 2011 | 06:15 AM
  #149
87hillbillyoter's Avatar
valve cover looks awesome man! i might have to do mine now! i know once i start though theres no stopping ill probably end up pulling the engine and rebuilding it.... haha
Old Apr 10, 2011 | 09:42 AM
  #150
i plan on putting a clear coat on, i just have to do some touch ups to it before i do the clear.
do it anyways haha.
Old Apr 10, 2011 | 10:07 AM
  #151
so i got more stuff done yesterday, all i have to do is clean the block and head then paint it, then next week i will put it together and hopefully install it.
my workstation
a spare lower intake i have
i should have taken a picture when all the parts were painted.
Old Apr 10, 2011 | 10:38 AM
  #152
irab88's Avatar
nice! i might be doing some of the same stuff
Old Apr 12, 2011 | 06:07 AM
  #153
lets see a pic of all the parts painted!
Old Apr 12, 2011 | 05:54 PM
  #154
tht will come soon, im starting to rebuild the engine so you will see all the purdy parts in one spot=)
Old Apr 14, 2011 | 10:42 PM
  #155
havent done much, i changed my timing cover gasket today along with bolting the head down, tomarrow will be brackets and lower intake.
Old Apr 15, 2011 | 05:25 AM
  #156
Terrys87's Avatar
Even after having the head bolted down, it still seems to take a while to get everything back together.
Painted parts just make the job look a lot better and when you get it running its still nice to have looking good when working on it in the future.
Hoping you get a chance to get it together and running soon. looking good.
Old Apr 16, 2011 | 05:41 PM
  #157
got it running today, ran in to some problems but nothing to bad, i have pictures and will post them when i get more time. yay
Old Apr 16, 2011 | 06:39 PM
  #158
irab88's Avatar
good to hear, man. weekend well spent!
Old Apr 16, 2011 | 08:46 PM
  #159
4runFreak's Avatar
g;ad to have the scav back? look forward to the pics. good job twisted!
Old Apr 16, 2011 | 09:08 PM
  #160
so i had a whole thing a couple of paragraphs long about all tht happened but my comp froze abd it all got deleted so here is pictures
after cleaning the block
after paint
assembling
upper intake setting on just so you can see what it looks like
my work area
lots of spare parts from the old 22RE and the 22R.
