Twistedyota's '87 4Runner Build thread
Old Mar 16, 2011 | 12:53 AM
  #121
space-junk's Avatar
Hit up Tofer on here... He's got an OBA system he made from his AC compressor and can prolly provide some insight...
Old Mar 16, 2011 | 01:15 AM
  #122
twistedyota's Avatar
thanks i just sent him a pm
Old Mar 16, 2011 | 04:59 AM
  #123
xxxtreme22r's Avatar
I don't know too much about the OBA stuff, but looking into a way to lubricate the compressor might be needed. Pretty sure they are normally lubricated by Freon in the system. Might be able to use something like an inline tool oiler on the intake side of the compressor.
Gonna keep an eye on this as this is one of those useful things I would like to eventually do.
Old Mar 16, 2011 | 09:46 AM
  #124
Tofer's Avatar
Sponsor
i got your PM last ngiht.. i'll reply here once i have a minute to write out everything.
Old Mar 16, 2011 | 09:52 AM
  #125
Lumpy's Avatar
I plan on doing the same thing one of these days. I don't need the A/C in the runner so might as well do something useful with it. I plan on putting the tanks in/above the underneath spare tire spot. I have an old compressor that I'm going to use for the pressure regulator and pressure shutoff switch as well.
Old Mar 16, 2011 | 09:55 AM
  #126
No A/C on mine, should make it a little simpler for me. Nothing to remove just add.
Old Mar 16, 2011 | 05:40 PM
  #127
Terrys87's Avatar
I have a few minutes and got to do some catching up. Ouch on your bumper, hate to see that happen, but its not to bad of a repair, I have a custom bumper similiar to yours.
I got to do the same thing to my 4rnr as the back seats and floor boards are full of parts and tools. I like the factory striping on SCAV. I have been looking into putting some stripes on my wife truck and eventually on my 88. At first I figured it would cost quite a bit but looking into it there are several places that can produce similar stripes fairly reasonable. Will be glad to get to that point.
I have subscribed to your build and a few others and it really puts the fire in me to get after mine. Especially after seeing you getting to play in the mud with yours. Im looking forward to that day.
Old Mar 16, 2011 | 06:30 PM
  #128
take your time and thanks
yea it kinda sux about the bumper but i dont regret it, we had a blast tht night, and i straighted it the most of the wasy with sum chains and a concret pole.
ive been watching ur thread and cant wait to see it in action
Old Mar 16, 2011 | 07:03 PM
  #129
vacuumed the inside of the dash compartment srry no pics, depending on how things go tomarrow and the weather i may tape up some of the elecrical lines (stock and mod) to make it a little neater.
aslo i finally read what the deck light mod was, and i may look in to doing tht as well. seems pretty simple
Old Mar 16, 2011 | 07:22 PM
  #130
Tofer's Avatar
Sponsor
https://www.yotatech.com/forums/f31/.../#post51683279
Old Mar 16, 2011 | 07:41 PM
  #131
sweet thanks alot, now to save some money and wait till i get the engine back in
Old Mar 19, 2011 | 07:58 AM
  #132
Terrys87's Avatar
I know about the saving some money part, that is a downer. Im going to be on a tight budget this month, but the good thing on these is there is always something that needs done for free or cheap. A gallon of Bondo is $15 and will keep me plenty busy for a while. Elbow grease is free.
So in a way it is a good thing to get the pesky little things you might would rather not do, Done.
Here is wishing you luck.
Old Mar 20, 2011 | 06:09 PM
  #133
i hear u on tht, just waiting for the weather to get a little nicer here
Old Mar 23, 2011 | 11:03 AM
  #134
so im thinking about welding my rear 3rd
Old Mar 23, 2011 | 08:11 PM
  #135
so i got some work done today.
first off give some history. when i got the truck the rear window switch didnt work due to it being seized withe dirt goo and what ever else. thts why i dont have the original center consol. i threw it out with all 3 switchs being stuck. and then finding out my rear compartment comp. was bad. so instead of spending $200+ i found the wires tht went in to the computer tht ran my back window and cut andspliced into them then ran some wire to my dash with a mercedesbenz window switch.
so today i decided to cut the zip ties holding the wires together and taping them up neater. here u can see me half way through
here is an after pic along with my rear speaker wire
since i plan on using this truck and using it hard i decided it would be good to trry and keep all electical plugs as high off the floor as possible just for when i play in deep mud/water so i taped my plug up and tiptied it as high as i could.
thts much better then laying on the floor behind the kick panel
then i had to add sum wire to the rear window switch becaus before it ran the same way but under the steering column behind the lower dash to the bezel on the right hand side of the dash under the gauge cluster where the cruise control is on some models.
now it runs striaght up from the floor next to the wiring harnnes to the back of the dash, out of sight out mind.
and a picture of just the cluster and part of the dash on
and since i am trying tto prevent water from hitting any electrical i moved my ecu
ima wait to screw it in until i put the dash back together to make sur the wires will reach.
on a side note, this is my removable pins for my door
2 bolts i found in a bucket at the fam's shop, tht i bent. the only things with these is i had to remove the plastic inserts tht were used with the original pins.
Old Mar 24, 2011 | 01:15 PM
  #136
Terrys87's Avatar
You have really gotten things done. My back glass doesnt work either. I know the motor works and I have replaced my swithces. I havent really havent been working on the window problem to hard just yet. But may look at your way of doing this. I might have to get a few tips and pics of this from you later. Electric is not a strong point with me.
Great job.
Old Mar 24, 2011 | 06:54 PM
  #137
Great job.
id get more done if it wasnt pouring down rain for the last month. but if u need anything just tell me and ill do the best i can
Old Mar 24, 2011 | 10:58 PM
  #138
future SAS info
just looking around and i came across this
links
http://www.4crawler.com/4x4/4R_suspension-III.shtml
http://web.archive.org/web/199911132...asch/page3.htm
Old Mar 26, 2011 | 04:20 AM
  #139
Terrys87's Avatar
I hear you on the weather. We had a few nice days and I made the most of them that I could, but it has turned cold again and I was really getting into spring. I lived in San Diego and I do miss the weather you have out there. Plus you dont have to deal with rust in Cali. You also have a lot better selection of Toyotas out there.
Wish I could help you on the Solid Axle Swap. Never done a swap. Looks like you are headed in the right direction.
Old Mar 26, 2011 | 09:21 PM
  #140
did the front brakes on the yota, they were about 2/3 the way down but i was getting a super annoying squek everytime i stoped or slowed down. so for 20 bucks it isnt bad to change them.
i also took my pass. hub apart and cleaned all the mud and water out of it the was making it hard to luck and un-lock. srry no pics
