Twistedyota's '87 4Runner Build thread
Old Jul 24, 2011 | 07:24 PM
  #361
Dutchbelly's Avatar
Just checking in. Looking forward to seeing how you work that bed frame into a soft top frame. Cheers!
Old Jul 24, 2011 | 08:50 PM
  #362
twistedyota's Avatar
i want to do something like this:
https://www.yotatech.com/forums/f88/...der-way-92914/
but instead of flat bars i will use the angle iron and put snaps on it.
also i want to see if i can figure a way to make it foldable so it doesnt take a lot of space when not in use.
Old Jul 24, 2011 | 08:55 PM
  #363
87hillbillyoter's Avatar
those jag seats are sweet! lookin good
Old Jul 25, 2011 | 06:09 PM
  #364
got the rivets cut and brackets cut off 3 out of the 4 angle iron, not sur when i will get back to it with work, and now having gas money to see my daughter.
Old Jul 26, 2011 | 01:08 AM
  #365
Terrys87's Avatar
Those trucks look good setting by each other. Hope your finger get better soon. I allergic to pain, but it comes with the territiory I guess when working on these. Wishing you the best on your top.
Old Jul 29, 2011 | 10:49 PM
  #366
got the C-channe i mentioned earlier to make my bumper for free since i wired the trailer.
i also got 2 hinges and 2 locks tht will go on the bumper also. to make 2 lock boxes to hold chains and rope. so it wont be in the back anymore.
will post pictures later.
so now i have the
SAS, soft top, bumper, and what ever else i think of to do.
but no time, work during the week and tomarrow im helping a friend in need with his yota then going to the drag races and sunday im seeing my daughter. then next weekend is my daughters 1st birthday party. turnin 1 on the 8th =).
Old Aug 1, 2011 | 01:36 PM
  #367
Z's Confederate Toy's Avatar
Exciting!! Sounds like you got some work ahead of ya!
Old Aug 1, 2011 | 05:47 PM
  #368
Dutchbelly's Avatar
Good luck Twisted- Looking forward to seeing more progress pics.
Old Aug 6, 2011 | 09:58 PM
  #369
So i found a guy on craigslist tht was parting out a 89 4runner. a thought in the back of my head was to maybe get the whole thing, but he wanted 2 much for it, so i didnt get it but i got some parts.
got my pass. taillight assy.:
got a windor regulator/crank for the pass. door on the berry, this is what the one on the berry looked like:
the hole ripped open so when rolling it up the spring would get tight and make it skip teeth.
also got a heater face plate with 2 small holes in it, and a dome light cover. all for $30. pretty good.
and here is the hinges and locks for my bumper:
and i fix 4 all 4runner guys,
on the pass. door the front door handle always seems to stop working when they get old, causing you to use the rear most door handle.
this is because the linkage wears out over time.
I had something written up but when it gets posted it becomes moved around so you can tell. but i basically bent the linkage to make it tighter
now it opens evey single time. on the first time.
Old Aug 9, 2011 | 04:01 PM
  #370
Dutchbelly's Avatar
Nice deal on the parts. I know you've been looking for that tail light assembly for a while now.
Old Aug 9, 2011 | 07:50 PM
  #371
so the berry has had a misfire for 3-4months now. i havent done anything because i had no money. but now with my job i have some money. so i looked at all my plugs and they looked good, looked at my wires they are getting old but still good, looked at my cap and it had some build up on the points. so i ordered a new cap and rotor.
installed the cap and rotor today and still no change. swap wires from the scav and still nothing, and all my injectors are pulsing properly.
the wierd thing is tht it isnt a constant mis-fire. is like an uneven one and it doesnt seem to change at higher rpms, like a regular mis would increase as the rpm's increase.
so im at a stand still.
Old Aug 11, 2011 | 09:27 AM
  #372
still working on the misfire. not trying to hard because it isnt tht bad and i have been busy. but last night i picked up a small air compressor tht has a 2.2gal tank tht may go on my truck when i do the OBA. also came with a small hose and a fitting so im getting parts for tht.
but the really good news is, i may be getting a Dana 44 and a 12 bolt rear for free. so maybe a full width swap is in the future. i have 2 trucks so maybe 2 swaps? 1 toyota SAS and 1 full width SAS. we will see.
Old Aug 11, 2011 | 09:30 AM
  #373
I like that SAS and full width idea. That'll be a fun build to watch
Old Aug 12, 2011 | 11:13 PM
  #374
i got the 1/2 axles front and back sitting in the berry, all i need is a bolt to hold the carrier pin in and a c-clip for one rear axle shaft and i should be good. well besides for cleaning it all up.
right now im waiting on a part so i can build my toyota axcle then i will work on these ones.
Old Aug 13, 2011 | 03:38 AM
  #375
Terrys87's Avatar
Hello Twisted.. Great deal on parts. Glad you got a tail light cover. Those are getting hard to find unless you go new. Knew you were looking for awhile.
On your misfire, have you checked your injector connections? I had that problem. They get really brittle. Try running it and wiggle each injector connection and see if it starts cutting out.
I have been gone for 2 weeks so have got some catching up to do.
Old Aug 14, 2011 | 08:33 PM
  #376
drove my friends 81 home for him, and their are a couple of things i got to say. 33's withe the stock 4.11 (i think) suck, and his truck made me relize how much body roll mine has and how much i dont like it.
Old Aug 17, 2011 | 02:43 AM
  #377
defrag4's Avatar
hey dude, just read your whole thread, scav and my truck have the same paint/decal scheme.
pretty awesome rigging up all that random junk into parts for your truck
ive got a miss on mine as well, did cap, rotors, plugs, wires, and fuel filter. went away for 3 days then came back...now its gone again wtf
any way to test the injectors to see if they are firing properly?
Old Aug 17, 2011 | 04:55 PM
  #378
thanks, as for the testing not sur. the only way i know is to send them out.
Old Aug 18, 2011 | 04:11 PM
  #379
Terrys87's Avatar
Did you try wiggling your injector wires and see if it cut out any? I dont know how to test injectors either. Just trying to offer a little support. I know what it is like to be in your situation. Sometimes someone else idea helps get you out of a rut.
I havent really noticed body roll. Have you done something that might cause a little more roll then usual? Mine may be as bad but not having another to compare to, I havent noticed.
Old Aug 18, 2011 | 04:45 PM
  #380
i havent done anything since the one day on my miss fire. im getting 19.5mpg so it it isnt bothering me to much considering i havent had enough time to try anything.
as for the body roll i think its just because of the springs being totaly flat and my rear shocks are probably shot. but it does give a smoothish ride. in my buddies truck when going around corners the truck was still and i was the one leaning in the corners.
besides for tht. i havent touched my trucks at all. did a lil research on full width swaps. but between work and seing my daughter and helping friends and fsamily on the weekend havent had time. maybe this weekend i will put together my toy axle. maybe haha
