rustED's 86' V8-Runner Build-up Thread
Old Nov 6, 2014 | 05:41 PM
  #1281
nvwiggins's Avatar
Originally Posted by rustED
I pulled the stock Toyota electric fuel pump out of the gas tank, and swapped in the fuel pickup tube/screen out of my 85' Toyota parts truck, and I'm just running a mechanical fuel pump that was on the 302 when I got it, I'm assuming it's just a stock mechanical pump.
Ah I see, I think I need a slightly higher volume pump, it only really happens under a load like going over a hill trying to maintain a set speed but the motor will stutter unless I back off. It's not a huge problem it just seems as if the motor is being intermittently starved of fuel. Or I suppose I could quite trying to pull hills at 75-80...
Old Nov 6, 2014 | 05:51 PM
  #1282
rustED's Avatar
That would make sense, what kind of fuel pump are you currently using?.....its nice being able to pull hills!
Old Nov 6, 2014 | 06:07 PM
  #1283
nvwiggins's Avatar
I just got the stock toyota Bosch replacement
Old Nov 7, 2014 | 07:07 AM
  #1284
rustED's Avatar
Cross one more thing off the list!
TO-DO LIST
***DONE***Replace the passenger side exhaust manifold
***DONE***Install new GlowShift gauges
***DONE***Build a new locking center console
***DONE***Install AllPro Offroad rear suspension
***DONE***Build a winch mount and installed winch
***DONE***Fix the ground wire so my back window works
-Build a frame reinforcement plate for winch mount
***DONE***Install power steering pump/fab up custom brackets to work with the 302
-Install a rear sump oil pan
-Install new CFR aluminum radiator, shroud, 14" electric fan(already have most the parts)-modify core support and hood latch
-Grease U-joints, front and rear shackles
-Change oil & filter
NEW TO-DO LIST:
-Fix intermittent start problem... (again)...GRrrr!
-Fix horn
-Replace driverside window regulator
-install GlowShift Tachometer
-install CB (looking at Uniden BearCat 980SSB) http://www.uniden.com/cb-radios/bear...vt/bearcat980g
-New mufflers/run new exhaust pipes from the mufflers out the back
-Build rear bumper/tire carrier/hi-lift jack mount
-Build some 1/2 doors
-DIY soft topper
-Sliders
-Restore interior: recover seats (already have the canvas fabric), new carpet, repair or replace dashpad, repaint cargo area side panels, upgrade stereo/speakers, LED interior lights, replace dash lights with LEDs
WISH LIST
-Lockers
-New bigger winch, and build a front plate bumper
-Rear disc brake conversion
-T-case E-brake conversion
-Install 4.7 T-case gears & twin stick
-Hydro assist steering
...more stuff as I think of it!
Old Nov 7, 2014 | 07:17 AM
  #1285
rustED's Avatar
Right on, shouldn't be to bad of a fix, one little hiccup isn't to bad after all the work you've done!
Old Nov 7, 2014 | 01:21 PM
  #1286
kornhuskerwizard's Avatar
My 2cents on the aluminum radiator,with my old 5.0 I had a Ron Davis aluminum radiator with a flex alite electric fan,loved it.got it all from speedway.
Old Nov 7, 2014 | 07:09 PM
  #1287
rustED's Avatar
QUOTE=
kornhuskerwizard;52234096]My 2cents on the aluminum radiator,with my old 5.0 I had a Ron Davis aluminum radiator with a flex alite electric fan,loved it.got it all from speedway.[/QUOTE]
Thanks for the input Chris, but I already bought this one a few months back from CFR Performance along with the shroud and 14" fan. I just need to buy a radiator cap, and a universal mounting bracket. This will most likely be my next project for the 4runner.
Old Nov 7, 2014 | 07:33 PM
  #1288
Terrys87's Avatar
Great to hear you got power steering again. Being without it will make you more appreciative of it every time you use it now. It is always nice getting to cross out a To Do list.
Replacing the window regulator is easy to do. Just finding a good one can be the trick. My brother got one off of ebay and it has worked great for him so far. It was a new one and I am sure it is from Taiwan but so far no problems with it.
As far as the dash pad, I installed a perfect one in mine and it now has a hair line crack in it and you can see that the foam underneath is seprated already and just the vinyl is holding it together. I am about ready to try one of those covers that you can get off of ebay. Interior paint will do wonders on you interior.
Old Nov 9, 2014 | 05:44 PM
  #1289
rustED's Avatar
^Thanks Terry! I'm pretty excited to finally have the power steering finished up, it wasn't that hard to do. I don't know why I put it off for so long! It is definitely more enjoyable to drive!
^Yeah I really need to get one, I found one locally for $22 at the pick-N-pull where I got the parts for my wife's Durango. They were listed as new, so probably made in Taiwan as well, but as long it works!
^I was thinking of trying one of those dash pad covers as well. I don't think I have the patience to try to refurbish mine.
Old Nov 10, 2014 | 05:42 PM
  #1290
That radiator setup looks killer!!
Old Nov 10, 2014 | 11:15 PM
  #1291
rustED's Avatar
Thanks Chris, can't wait to get this thing installed!
Old Nov 11, 2014 | 12:05 AM
  #1292
rustED's Avatar
IT'S SNOWING!!!
Old Nov 11, 2014 | 05:47 PM
  #1293
I woke up to some snow myself!
Old Nov 12, 2014 | 06:29 AM
  #1294
Gizler00's Avatar
I have a dash pad cover thats practically new. You can HAVE it if you want!! Its yours ED. PM me your address and Ill send it.
Sorry I have not checked in in awhile. looks like you are getting a lot done.
Old Nov 12, 2014 | 06:30 AM
  #1295
Gizler00's Avatar
IT'S SNOWING!!!
That's a cool picture of your runner ED!
Old Nov 12, 2014 | 04:10 PM
  #1296
rustED's Avatar
Kids were kind of excited about it, me, not so much, lol.
Thanks alot Mark!!! PM's sent!
No worries buddy, I know you've been busy! Its nice having power steering finally, wish I had done it sooner! So far it's working great, the port I plugged off isn't leaking, so I'm pretty stoked!
Thanks man! I wish I had washed it before the temp dropped, all the mud puddles have freeze dried, lol!
I checked my anti-freeze with one of those cheap testers yesterday, and it said it was good for +5°.....PANIC MODE!, it got down to around 10° last night, so I had to run into town today and pic up some anti-freeze, drained the radiator, refilled it & ran the engine and heater to circulate, still got to let it cool and retest it in a little while, talk about procrastinating, lol!
Old Nov 16, 2014 | 06:19 PM
  #1297
Terrys87's Avatar
Seems like every year I get the antifreeze in at the last minute. My kids were excited to see snow today as well. They are hoping to get out of school. We just got a dusting. I have seen my snow for the year now, I am ready for spring. This is already starting to be a long winter already for most of the country. I hope it isn't not as long as last year.
Old Nov 17, 2014 | 05:32 PM
  #1298
X2...sweet pic
Old Nov 19, 2014 | 09:01 AM
  #1299
rustED's Avatar
We just got dusted as well, but it hasn't melted off yet due to the cold temps. I hear ya Terry, I'm ready for spring too, lol!
Since draining and refilling my radiator with anti-freeze, I now have a small drip coming from my drain plug. After setting overnight I caught a small amount in a bucket, same thing the next night. I wondering if I wrapped the threads on the plug with Teflon tape if that would help?...
X2...sweet pic
Thanks buddy!
Old Nov 19, 2014 | 05:40 PM
  #1300
Gizler00's Avatar
You might get away with using the Teflon tape. I have had decent luck with doing the same thing on other vehicles.
