RAD4Runner's 1986 4Runner dlx Build-up
Old Jan 13, 2014 | 03:29 PM
  #401
Philbert's Avatar
Hey Ray - sorry I missed your earlier response - been traveling a lot lately.
I always thought the T stat opened at 180* - not sure what the 195* reference is to but now I'm interested and will Google it
Well, I guess I was wrong:
http://www.lceperformance.com/2-Stag...-p/1032081.htm
Old Jan 13, 2014 | 06:01 PM
  #402
RAD4Runner's Avatar
Replacement Wiper arm TIP
Originally Posted by Philbert
Welcome back, Phil! Yeah, I like that 2-stage thermostat, but it's supposed to be replaced once the cold-coolant shuts first stage up, and second stage latches and stays open. If that's true, when exactly that happens is one more thing to watch out for.
Re: Wiper Arm TIP
Guys, the plastic tip that holds the pin where wiper blade mounts on to wiper arm on my rear wiper finally broke.
That tip looks like this:
It simply slides over the end of the wiper arm and is screwed down. I like simple assemblies and accessible fasteners!
It looks like this removed and disassembled:
Only the very tip that holds the pin is broken:
I looked online, but most sell only the arm (which I do not need), without that TIP that I need - LOL!
Does anyone know a place that carries it?
I want to either
  1. Buy brand-new, instead of same 27-YO that's about to break, too,
  2. Find one from interchangeable newer model.
  3. OR fabricate one myself out of aluminum. Pro: it will last forever, Con: will cost me too many man-hours compared to buying new one.
Do you guys now of where to buy?
Or are you aware of any later model that's interchangeable?
TIA,
Ray
Old Jan 14, 2014 | 12:32 AM
  #403
ChefYota4x4's Avatar
Hey buddy, I have one sitting on my workbench in the garage right now. I took it off a 2nd Gen 4runner which is exactly the same. I suppose you could get on up into 95 and still be ok? Gotta be the same darn back window as the 90 or so? I know that's not new but think about it this way... A lot of the stuff that I have on my truck now is in better shape and some of the crap on the 2005-2010 I am seeing at the yard that is a little more at pick your part.... (Yes, I went in there for some CRV stuff and just to look into what it would cost to grab a 1GR-FE or 2UZ-FE equipped rig...TOO FREAKIN MUCH, that's how much! lol)
Old Jan 14, 2014 | 07:57 AM
  #404
coryc85's Avatar
Ray - I believe I have the wiper piece sitting in my garage also. It's from 1988, but you are welcome to have it for free, altho mine is in Florida.
Also, on your SR5 rim question I saw this post on Marlin about different versions of the SR5 alloys: http://board.marlincrawler.com/index.php?topic=89087.0
Old Jan 14, 2014 | 08:02 AM
  #405
Philbert's Avatar
I think Mark could build a truck with all the spare parts he has lol
I haven't had that part on my 87 4runner since I bought it in 2002
Old Jan 14, 2014 | 09:31 PM
  #406
RAD4Runner's Avatar
Thanks a lot, guys!
Cory, I like that post and info; the stock 2nd gen rim will give me a moderate/subtle extension beyond fender flare; A little more than stock but less than my current steel rims.
Phil,
LOL! Yep, you are right!
Mark,
No rush on the wiper arm tip; it's summertime here in SD- LOL!
Re: CSI timer, after I twisted the connector, it's working well again (Ta-Da-Vroom!). Epoxy or whatever molding is holding the connector to the metal body of the switch seems to have broke. Will try to se if I can repair after I replace with yours.
Regards,
Ray
Old Jan 20, 2014 | 08:45 PM
  #407
RAD4Runner's Avatar
Back to Stock Alloy Rims!
Stock Alloy Rims from 2nd Gen 4Runner now installed. Thanks for your help with the decision to go stock, guys!
Before:
After:
Now tires are just about even with the fender flares. Not sticking out too much, but does not look recessed into wheel well / goofy-looking like a Land Rover Discovery
Weight:
Old Steels weigh 24 pounds each
Stock Alloy wheels weigh 20 pounds each.
Now need to sell the old steels.
I wonder how much would be fair asking price. $50 for all four?
Here are pics with the old Steels installed
(I'll post pics with stock rims later)
Old rims were made by Bordem NE in Brazil
Apparently Bordem had been bought by hayes-lemmerz
Quality Inspection sticker says, "Pacific Wheels, Long Beach CA"
Tires installed on old steel rims stuck out beyond fender flare by about 1.75" in front:
Tire stuck out by about 3/4 inches in back:
Old Jan 20, 2014 | 09:04 PM
  #408
diableri's Avatar
Looks good man!
Old Jan 20, 2014 | 09:59 PM
  #409
RAD4Runner's Avatar
Fog Light Project
Thanks, diableri!
I'm also starting to to brainstorm/research my Fog Light Project. I want to keep openings/mounting location as stock as possible.
One favorite potential is current location of turn signals on bumper. My reasons for liking it:
  • I prefer low-profile rectangular shape that match stock features over circular shape.
  • Low enough for fog light application,
  • Will be protected from loose rocks/road/trail debris by the bumper itself, as compared to when mounting it as low as the valance.
  • Dimension of opening just about right for PIAA 2100's or the inexpensive Optilux's by Hella, or Wal-mart Radiant Effects / Blazers. I also like the low-profile foglights of early 2000's Xterra / Pathfinder. Need to see exact dimensions
Is this a simple and elegant fog light, or is this simple and elegant?
In order to make that opening available, I'll need to combine my turn signal with the marker. I like this option also, because that would put the front turn signal higher and at the corner for better visibility. I think best approach would be combining marker and turn signal into one 1157 fixture - Like 4Crawler had done.
Potential parts:
Dual-Intensity socket 1157 (BAY15D) from SuperbrightLED's
I'll use 1157 bulbs I have onhand to test the concept, then upgrade to 1157 LED Bulb from Superbright LED's when the incancesent 1157's burn out.
Old Jan 21, 2014 | 04:09 AM
  #410
coryc85's Avatar
Love the SR5 rims on there! Man, you've got me wanting a set.
Old Jan 21, 2014 | 03:21 PM
  #411
Nervo19's Avatar
I love the new tires. What model/size Goodyear are they? Do they give you much road noise.
Before I saw a bunch of people offered the wiper part I found it part 85196A for $7.25 from ToyotaPartsOverstock They have ton of new 1st gen parts. I just ordered $25.00 worth of parts from them and they came in three days.
http://www.toyotapartsoverstock.com/...chString=wiper
Old Jan 21, 2014 | 03:25 PM
  #412
LOVE Ruby Tuesday's new look! ...I never liked those other wheels much. Now? .... LOOKS GREAT! Congrats!
Old Jan 21, 2014 | 03:28 PM
  #413
Now,..... I know you like to keep ur looking a little shopping in other areas to prevent thieves... But now, she's looking more more flashy... So let's get going on rubbing out that pink top! Lol.....if anything its only going to protect the actual fiberglass beneath... maybe if you're able to stop by in the near future I'd gladly help you with any of that detailing! I've always been pretty decent at that. I have two orbitals as well!
Old Jan 21, 2014 | 08:46 PM
  #414
Grego92's Avatar
X2.....I like those alloy wheels....and another x2 get that oxidation taken care of!!! looks like Ruby is wearing a pink dress!
Old Jan 26, 2014 | 12:47 AM
  #415
Terrys87's Avatar
When you are younger, you couldn't wait to get rid of stock rims and throw on aftermarket. Now everyone does just the opposite. I had those same aftermarket rims as well one time. I like the stock rims better.
Old Jan 26, 2014 | 02:13 AM
  #416
RAD4Runner's Avatar
Rims and Polishing
Completely agree, guys. LOL!
Yes, Terry, I saw them on yours. I actually prefer them more classic 5-spoke ones but didn't bother looking for them.
I find the aluminum a little bit too shiny for my taste so I'll paint a graphite color like Grego did, when time permits.
Re: Polishing
I got the TR3 Resin Glaze. I tried it by itself, without any prep on little spots and it really works well.
However, I'd like to do a better job so I want to prep a little bit more with a minimally abrasive method. Which would be less abrasive, clay bar or rubbing compound? Any recommendation?
Also, on the Fiberglas top, I'd like to do the sanding prep work myself because
1) I want to be sure it's done well,
2) Sanding and priming only little spots can be done even without a painting facility/booth
3) it would simplify shopping for final coat painter - just need a urethane finish.
Would any primer at auto store work?
Any recommendations?
TIA, guys!
Old Jan 26, 2014 | 07:30 AM
  #417
Gizler00's Avatar
Looks great with the stock wheels!!
Old Jan 30, 2014 | 05:05 PM
  #418
RAD4Runner's Avatar
My Steel Rims On Craigslist
Hi guys,
I got my old steel/chrome rims on craigslist (here)
Do you think $80 is fair price for all four?
TIA,
Ray
Old Jan 31, 2014 | 02:19 AM
  #419
julsruls's Avatar
Id take them for that
Old Jan 31, 2014 | 08:47 AM
  #420
RAD4Runner's Avatar
Thanks, Julsruls.
I'd like to make sure my asking is reasonable.
Best regards,
Ray
