magnet18 1986 build thread
Old Jan 29, 2017 | 06:28 AM
magnet18's Avatar
Originally Posted by flg8r22
Wish I could take the credit for that, but it came from the factory with a fuel door release lever in the truck. Kind of a pain sometimes when I'd go to get gas and forget to open the fuel door.
Pretty sure they all came with both, inside pop and key, mine has both
Old Jan 29, 2017 | 09:35 AM
Biggerhammer's Avatar
I'm digging the white top. Mines black and the fiberglass is showing through in spots. I'm considering white bedliner on it.
Old Jan 29, 2017 | 01:48 PM
magnet18's Avatar
lol, I've been considering painting the top black to make it a bit more pickupy/less SUVy
Also, bedliner is usually rough, I'd think it would hold dirt
Old Jan 29, 2017 | 02:09 PM
Mine is painted black but with the fiberglass showing through I'm thinking it just gelcoat! There are a couple of bedliner types that can be applied almost smooth, a lumpy surface rather than a rough surface. Some even have the rubber "chips" that you add before mixing the liner.
So without the "texture" I think it would be able to be hosed off OK.
Old Jan 29, 2017 | 02:23 PM
  #25
magnet18's Avatar
New O2 sensor
anyone experienced going to tell me the carbon buildup is significant?
Old Jan 29, 2017 | 02:28 PM
  #26
magnet18's Avatar
Got the clear turn signals and running lights installed!
See here https://www.yotatech.com/forums/f116/turn-signal-wiring-298786/ for some minor related wiring fun
Now i really need a matching chrome grille
Old Jan 29, 2017 | 03:08 PM
  #27
Co_94_PU's Avatar
New O2 sensor
Is that "New O² sensor?" As I do I need one, I have one or this is my new one?
​​​​​​​They are relatively inexpensive when sourced from the web, if you're concerned it's fouled just go for the replacement.
Mine is a little more crusty on the inside, and very much more muddy on the outside. My concerns for mine is currently the outside air intake could be plugged more so than the sensor surface on the exhaust side. Internally there is a the roidium/zirconia platinum contraption which is much less prone to collect carbon than the shell. Making me running a little richer than it should, but I haven't really driven much since the plugs got cleaned.
Old Jan 29, 2017 | 03:36 PM
  #28
Where did you get the clear turn signals and running lights?
Old Jan 29, 2017 | 04:24 PM
  #29
magnet18's Avatar
new O2 sensor as in this is the old one, you can see the new one bolted in in the background
Replaced it just cuz I'm at a almost 200k tune up
Just checking to make sure the carbon buildup is nothing to be worried about
Old Jan 29, 2017 | 04:26 PM
  #30
magnet18's Avatar
ebay, I'll try to post the link when I get home
Turn signals and tail lights are great, running lights are from a second gen, they don't 100% line up with the grille unfortunately, didn't know that would happen
Old Jan 29, 2017 | 07:43 PM
  #31
magnet18's Avatar
http://www.ebay.com/itm/1987-1988-TO...dYM2Cy&vxp=mtr
Note that, for some reason, the running lights trim sticks out more than the headlight surrounds. Not sure if a 2wd 87 had a different grille than a 86 4wd, but I would like to find a grille that matches either way
Old Jan 30, 2017 | 07:36 AM
  #32
TrafficTechII's Avatar
Nice ride!
I found the best way to deal with rust it to remove it.
I tried the POR and wasn't very happy with the results.
https://www.yotatech.com/forums/f116...pickup-296569/
Old Jan 30, 2017 | 07:26 PM
  #33
space-junk's Avatar
Same here. Dunno why they did both.
Old Jan 31, 2017 | 10:58 AM
  #34
jakey poo's Avatar
The build up on your old O2 is significantly less than on my old one. You could barely see the holes in the one I replaced
Old Jan 31, 2017 | 06:17 PM
  #35
magnet18's Avatar
Good to hear!
Originally Posted by TrafficTechII
Nice ride!
Nice! You're doing a great job with that truck. Did you do the paint yourself?
Old Feb 2, 2017 | 01:44 PM
  #36
jakey poo's Avatar
I found a pic of my old O2 so that you can see how good yours actually looked lol
Old Feb 3, 2017 | 04:48 PM
  #37
magnet18's Avatar
Lol, looks like you were burning a tad rich?
Old Feb 6, 2017 | 10:05 AM
  #38
jakey poo's Avatar
More than a tad I would say! She runs like a top now. New O2, TPS, Knock sensor, no EGR stuff, newer style TB and intake, she purrs.
Old Feb 6, 2017 | 02:58 PM
  #39
magnet18's Avatar
Nice, my EGR port is capped, I've been looking at removing the rest of the EGR and smog stuff.
(truck is from california, I am not)
What TB and intake did you put on?
Old Feb 6, 2017 | 03:39 PM
  #40
jakey poo's Avatar
I believe it was off of a '93, slightly different intake and the AUX air valve is deleted
