kornhusker wizards 89 4runner build thread
Old Apr 14, 2013 | 11:25 AM
  #241
Gizler00's Avatar
Heres the link chris. Im still looking for more pics.
http://www.pirate4x4.com/forum/toyot...ing-a340h.html
Old Apr 14, 2013 | 11:28 AM
  #242
Gizler00's Avatar
I found this in that thread also.
Just like already said the converter goes on the trans first. Spin it clockwise as you gently push on it and it will line up the input converter spines with the input spines and drop into place. If I remember right it should have 3 steps going in. When the whole mess is assembled there should be between 1/8 and 3/8" space between the converter and flexplate.
Old Apr 14, 2013 | 11:31 AM
  #243
Gizler00's Avatar
Heres the stuff on the spacer
The spacers and flexplate I sent you came directly off of an 86 runner that a friend pulled, then into my truck with the aw4/a340 behind a 22re so I know they were right. Starting with the crank it goes thick spacer, flexplate then thin spacer. From the sounds of it you have that order backwards.
__________________
Old Apr 14, 2013 | 11:34 AM
  #244
kornhuskerwizard's Avatar
From the pic of the engine on the hoist, it looks as if the bevel is kicking the flywheel back which is how i have mine...That means i might not have the torque converter in all the way but im sure it was.
manual says converter to housing lip distance is 16.6mm. guess i shoulda done some reading and measuring.
Old Apr 14, 2013 | 11:37 AM
  #245
from crank back i have...thick spacer,flexplate,skinny spacer, that would be correct??
Old Apr 14, 2013 | 11:43 AM
  #246
Hope my pump is not destroyed. Im sure i have the spacers correct, pretty sure flywheel is on correct, now im wondering if torque converter was not seated in pump but i hope so.Either way its coming back apart.
Old Apr 14, 2013 | 11:49 AM
  #247
jason in tn's Avatar
Never dealt with a toyota auto, but I know on other getting that converter set can be tricky. Sorry I'm no help.
Old Apr 14, 2013 | 11:54 AM
  #248
bone collector's Avatar
bummer man. keep plugging away it will be done soon
Old Apr 14, 2013 | 12:00 PM
  #249
Gizler00's Avatar
Sounds like your spacers are correct. Maybe just try like we talked. Hoist engine and pull back enough to see if the TC can seat further in.
Old Apr 14, 2013 | 01:02 PM
  #250
Well i pulled the engine back out, and i put slight pressure on the torque converter while spinning it and it fell back in a considerable amount. So i didnt have it seated all the way in the pump. I tightened the bellhousing bolts all the way down by hand, but tight all the way around. Hopefully i didnt mess the pump up. i didnt here any carnage going together so i put it back together and am hoping for the best!!
Old Apr 14, 2013 | 01:16 PM
  #251
best of luck
Old Apr 14, 2013 | 01:52 PM
  #252
kelvinb's Avatar
congrats on getting it all done. dont forget to fill it with oil and coolant. get more of that loud mouth soup and crank it up
Old Apr 14, 2013 | 01:54 PM
  #253
Gizler00's Avatar
Awesome man. The maiden voyage is in the near future!!!
Old Apr 14, 2013 | 02:31 PM
  #254
All the bellhousing bolts,tranny dipstick,wire harness for tranny,exhaust, is back in place. Installed the 6 torque converter bolts with blue loctite and installed, I am worn out over having to pull the engine again so im calling it quits FOR TODAY...MUHAHAHAHAHAH!!!!
Old Apr 14, 2013 | 02:54 PM
  #255
thefishguy77's Avatar
There is no jack a** award unless you do it twice. Just once is a learning award. Keep up the good work.
Old Apr 14, 2013 | 04:41 PM
  #256
Terrys87's Avatar
Never done an auto myself on a Toyota but sounds like yo got it made this time. That having to go back and redo things is a pain in the rear but it does happen. Atleast the bolts are easier this time around.
Old Apr 14, 2013 | 05:28 PM
  #257
Yep, alot easier the second time...but still urks me i had to pull it again. I just hope the transmission is ok. I will plan on getting the rust out of the fuel tank and ordering a fuel pump and sending injectors to be tested next.In between now and then i can dial in tps sensor on throttlebody, fix wiring harness that mice chewed on(not bad),alignment, wheel spacers for front tire rubbage,etc...
Old Apr 14, 2013 | 06:03 PM
  #258
Gizler00's Avatar
Nice man. A little bit or hillbilly ingenuity helped speed up the process for you.
Old Apr 15, 2013 | 09:23 AM
  #259
Yea my hillbillly ingenuity comes from alot of hankiii and davidallencoe blasting out my speakers in my garage for prolonged intervals.
Picked up the rock truck and trailer for my work today at inland truck parts in lincoln, and i asked the dude if they do alignments on lifted trucks, he says ya what do you have and how big of lift, i said a toyota with a mild front and rear lift and he said a normal toyota is $75, but thats no lift, he says depending on my suspension components theyre shop labor rate is $93 an hour.I replaced upper and lower balljoints, shocks are decent, only thing they might say needs replacing is tierods, but they seem ok.
Anyone think i need to mess with my torsion bars?? I never have before so im assuming theyre at the stock location. It sets pretty level so im thinking dont mess with them.
I wish i could find a shop thats familiar with these trucks and lifts, but havent found anyone yet.
Also ive mentioned this before but didnt get a response on qaulity or info on airtex fuel pumps?? Or what would be a decent brand??Terry i know you suggested a ebay one maybe for around $30?? I dont want to replace it down the road so will try and get a reliable one.
Tonight i will see if the spacers i have fix my rubbage on the sr5 wheel with the 17s.
Old Apr 15, 2013 | 10:50 AM
  #260
Gizler00's Avatar
Love me some David allen Coe!! I could ask my buddy who is the General Manager of Rhoden Auto Center about the alignment. I think they charge 49$ for an alignment. But you would have to drive it up here to CB.
I cant help you on the Airtex Pump.
