Jason in tn's 1986 4Runner Build-Up Thread
Old Apr 17, 2013 | 04:08 AM
  #1161
Terrys87's Avatar
After pulling the dash, soon you will be pulling heater cores,wiring harnesses, and heater control switches. lol... While you still have a chance, practice on those two trucks on taking the dash apart. It will give you alot of confidence in yours when you have to replace your core. Even if it is awhile before you change your core, alot of it will come back to you when you do it and I could remind you over the phone on what you do if you forget.
Old Apr 17, 2013 | 11:11 AM
  #1162
ChefYota4x4's Avatar
Sorry u had to bone out b4 getting to certain things! Great work and find tho!
Old Apr 17, 2013 | 12:35 PM
  #1163
jason in tn's Avatar
My job is frustrating at times for sure. But the penetrating oil needs time to work so ehh it all works out lol.
Old Apr 17, 2013 | 01:01 PM
  #1164
Cool, I hear ya. Well, ....drive safely!
Old May 24, 2013 | 05:04 PM
  #1165
Terrys87's Avatar
Just posting some info for ya..
https://www.yotatech.com/forums/f129...ard-air-75748/
Look at turborich post for a little more info...
https://www.yotatech.com/forums/f116...d-mods-183608/
Old May 24, 2013 | 05:27 PM
  #1166
Cyberhorn The Dragon's Avatar
interesting stuff on the junkyard mods terry thank ya
Old May 26, 2013 | 03:12 PM
  #1167
thanks for the info terry, I will be digging into that idea soon. Dragon terry is always a source for good info.
Ok quick udate, since I finally got my 3rd gen out of the shop and most of the projects for it finnished up for the time being I decided to spend some time on this od girl.
I still havent got he fuel ssue sorted out I jst kinda putered around on it, It was ealy nice to just tinke and not feel any presure to really get anything done. I got the fresh air door asembly swaped out that was a big relief. I wanted to swap dash pads out with the 84 pickup I had I pulled oth pads awhile back, the one out of the 84 had a few cracks but was way better than the one I had, I picked up a vynal reair kit at autozone and fixed the cracks it worked really well I will post up some pics asap. I started painting some of the dash parts its looking really good. I also started to do my sterio install. like I said just kinda oofed around but still managed to get a few things done. I will get some pics up soon. thanks for checking in.
Old May 26, 2013 | 06:40 PM
  #1168
good to hear you got time to work on her how well that vinyl repair stuff work? only on hard dash or can it fix like a tear in the side panels
Old May 26, 2013 | 07:02 PM
  #1169
hey cyberhorn, Im really happy with the results of the vinyl repair, I think it would work great on door panels or any vinyl surface. It has a little tool that you have heat up and it kinda bonds everything back together, it also came with 2 or 3 plates to put a pattern back in the surface. I will get some pics up of it as soon as i can.
Old May 26, 2013 | 07:14 PM
  #1170
awesome look forward to seeing them
Old May 26, 2013 | 11:33 PM
  #1171
Pics! Soon! Jonesing! Haha
Old May 27, 2013 | 12:18 AM
  #1172
Terrys87's Avatar
Here is the plug wires you were asking about. http://www.ebay.com/itm/250854901322...84.m1438.l2649
Old Jun 1, 2013 | 04:35 PM
  #1173
Size:  104.6 KBThis is the kit I used to repair my cracked dash pad
There are some pattern pieces but the pic won't up load, any way you heat this tool up lay the matching pattern over the repair run this tool over it and that gives you you texture back.
Update. I have not been able to remove the supply line from the tank, the last thing I want to do is break it so I decided to try the next best thing. I pulled the drain plug out of the tank, drained the gas out and filled and drained with water several times, then and viniger per Terrys advice I'm letting it soak I hope this does the trick.
Some of the orange gas I drained out
Old Jun 1, 2013 | 05:21 PM
  #1174
well good news thats about how bad my gas looked from sitting for a year+ gas should be clearish faintly yellow
the vinegar is slow so dont rush it too much slosh the truck every so often LOL
how much the kit cost ya jason? 8-9 bucks?
Old Jun 2, 2013 | 04:05 PM
  #1175
I poured the viniger and headed back to work so giving it a few days won't be an issue Lol.
the repair kit ifI remember was under 10 bucks.
Old Jun 2, 2013 | 06:34 PM
  #1176
kornhuskerwizard's Avatar
I did the rusty tank issue at its finest, vinegar vinegar vinegar. slosh slosh slosh. sucked big time. But it paid off in the end, i also used a hotsy too. By the way nice pics on ur dash repair!!
Old Jun 2, 2013 | 07:14 PM
  #1177
thanks for checking in kornhuskerwizard. Im a bit frustrated it has taken me so long to get this thing in the shop and start this, I should have just drained the gas while it was sitting outside and added the vivger then. I might actually have had it running again by now. the interior revivale is going well, so far Im really happy with the results. maybe soon I will have both my runners RUNNING at the same time and I can pick which one I want to drive instead of them decideing for me lol.
Old Jun 3, 2013 | 12:36 AM
  #1178
Terrys87's Avatar
Your runner might not know what to think when it gets some clean fuel in her stomach. Looking forward to seeing your dash put back together and how the tires look on her. From the previous picture it gives it a whole new personality.
Old Jun 3, 2013 | 09:00 PM
  #1179
Well terry that makes 2 of us buddy.
I got most of the dash painted and reassembled, also spent a little time working on the cigarette lighter working at least now I can charge my phone. I have to finish up my sterio install before the rest of the dash can go together and I will have that finished up soon.
Old Jun 3, 2013 | 09:07 PM
  #1180
Terry and I did some tire swapping awhile back I traded him a set of 31/10.5 for his 31/10.5 mud terrains, finally got them mounted up. I don't intend to wheel this truck but I really like the more aggressive stance.
