irab88's 1993 PickUp Build-Up Thread
Old Jul 29, 2012 | 05:47 PM
  #1961
irab88's Avatar
my w56 sensor fit. i had to put it on before the "mount" went on. i did have to clearance the rear mount to fit in the tunnel (pics later), but the stock crossmember and mount fits the front crawl-box with no modifications.
this was "halftime" before i got the r151f in.
http://www.youtube.com/watch?v=JWJsJWS1su4
Old Jul 29, 2012 | 09:02 PM
  #1962
ChefYota4x4's Avatar
Wow, exciting update! Great work and quick like, to boot! Stoked for ya, Ian... you're gonna love this modification/upgrade!
Old Jul 30, 2012 | 06:21 AM
  #1963
4ever4running's Avatar
X2!! I'm excited to see how the new tranny fits into the old location.
Old Jul 30, 2012 | 09:41 AM
  #1964
irab88's Avatar
it fits by the skin of my teeth and a bit of hammering. i still have to clearance the tranny tunnel to fit, but it's snug where it is.
now for a few "after" pics from this morning. i was headed out the door, so i used my phone camera...
here you can see how close it is. i had to notch out the top right corner of the rear mount
front drive shaft to crossmember clearance looks tight, but i don't mind cutting it up to gain some wiggle room
i was able to use the w56 reverse sensor on the r151f with no issues. also, i thought this was interesting, the drain plug on the r151 is on the side, not facing down. huh.
the short shifter kit presses up into the floor a bit in the front. gonna hafta trim that out a little.
interior is a mess, but you can see the shifter in place, in 4th gear. plenty of room for levers underneath and to the sides. i can also change the angle if i need to.
and my set of knobs, yet to be cleaned up and relabeled
(5-spd, hi-n-lo x2, 4wd-2wd)
Old Jul 30, 2012 | 09:59 AM
  #1965
irab88's Avatar
also of interest to anyone else doing this swap: i am using the late-model 22r-e clutch (1993-1995) with no fitment issues
Old Jul 30, 2012 | 11:16 AM
  #1966
Wow, exciting! Will you need a custom boot/cover kit? You said 'It's risen", which I can see in that pic... Curious what you're planning.
Looks SOLID! Could the trans shift a lil bit with torque and play drums on the under chassis up front?
Old Jul 30, 2012 | 02:26 PM
  #1967
irab88's Avatar
kind of. the front half will be stock. the back half will have the standard 3-lever boot supplied with normal tripple-stick kits
yeah, just the transmission shifter base is up about an inch because of the short-shifter kit. that's the only thing touching the trans tunnel
...and when it does, i'll take out the hammer and "modify" the tunnel. i don't think it'll be an issue anywhere the old trans was. we'll see.
Old Jul 31, 2012 | 06:10 AM
  #1968
irab88's Avatar
driveline should be done by thursday, shifters here before the weekend. if everything shows up soon enough, i can be cruisin' this weekend.
Old Jul 31, 2012 | 11:59 AM
  #1969
irab88's Avatar
oh yeah, and i now own the truck
Old Jul 31, 2012 | 12:19 PM
  #1970
WOW, .... the second to last comment was great news... the last???? HOLY CRAPULA, you must be stoked!
Old Jul 31, 2012 | 04:19 PM
  #1971
R.DesJardin's Avatar
And I get that about owning the truck, back in the day(early '80's) I wheeled, modified and raced a truck that was years from being paid off.
Old Jul 31, 2012 | 04:40 PM
  #1972
irab88's Avatar
heh, i just mean the title was signed over last night. kind of a graduating/new job gift. even though a good chunk of the truck was already mine
Old Aug 1, 2012 | 10:34 AM
  #1973
irab88's Avatar
drive shafts are done. i'll pick those up tomorrow morning
Old Aug 1, 2012 | 11:28 AM
  #1974
Doitzel_Kaiser's Avatar
wow this build has come a long long way. Keep it up!
Old Aug 1, 2012 | 11:58 AM
  #1975
Wow, nice to have guys doing work in REASONABLE time, eh? Good news!
Old Aug 2, 2012 | 05:57 AM
  #1976
irab88's Avatar
Old Aug 2, 2012 | 06:10 AM
  #1977
Resto-noob's Avatar
Congrats on the paperwork-graduating and ownership.
Just wanted to thank you on posting the link (ages ago) for those U bolts. I took your advice and painted them, too.
Old Aug 2, 2012 | 09:19 AM
  #1978
irab88's Avatar
thanks, and no problem
also:
Originally Posted by USPS
Priority Mail® - Out for Delivery - August 02, 2012, 8:49 am - ALEXANDRIA, VA 22309
Old Aug 2, 2012 | 01:59 PM
  #1979
OOOOOOOOOH, close!
Old Aug 2, 2012 | 02:40 PM
  #1980
irab88's Avatar
too close. i have all the parts, just waiting on the time to put it all together...
