Dunkin's 1990 4Runner 2DR Build-Up Thread
Old Mar 18, 2011 | 10:46 AM
  #101
Dunkin's Avatar
Originally Posted by 85toyman
Looking good, that KS racing bell housing looks nice tucked up in there. Did you go with the motor mount spacers so you wouldn't hit the steering rod/front diff, I don't remember if you put a body lift on? Does the hood close with the motor in there?
Yeah, I was having clearance issues with the center steering link hitting the oil pan, and with the left exhaust manifold contacting the steering shaft.
I did install a 2" body lift.
Now there is a ton of room for both. I originally left the A/C compressor in there, but even after the engine lift it still hit the steering coupler.
The hood closes just fine, and still has about an inch or more of room before contacting.
Old Mar 18, 2011 | 11:16 AM
  #102
85toyman's Avatar
I hoping that with a 1" diff spacer and a little clearancing/notching of the oil pan I can fit it without a body lift.
It looks like you have the LS oil filter location still, are you still able to pull the filter off and not hit the frame?
Old Mar 18, 2011 | 11:22 AM
  #103
Dunkin's Avatar
It's the SC oil filter housing. And yeah, I can get it on and off just fine.
Old Mar 19, 2011 | 02:17 PM
  #104
Dunkin's Avatar
Hell YESSSS!
She started on the first try! So much win!
http://www.youtube.com/watch?v=ueLQtW7Zm6g
Last edited by Dunkin; Mar 21, 2011 at 11:43 AM. Reason: Replaced the Photobucked vid with YouTube
Old Mar 19, 2011 | 04:00 PM
  #105
nvtoyota's Avatar
Great job
Old Mar 19, 2011 | 06:33 PM
  #106
2DoorRunner's Avatar
Hell yeah dude! That put a big smile on my face just watching
Old Mar 19, 2011 | 07:42 PM
  #107
SHAGGY21's Avatar
Sweeeeeeeeeeeet. I'm so jealous. I want my runner to be finished so bad.
Old Mar 19, 2011 | 10:04 PM
  #108
85toyman's Avatar
congrats man. Nicely done
Old Mar 19, 2011 | 11:26 PM
  #109
Dunkin's Avatar
Thanks guys. Talk about an exciting day.
I can't run it for very long, since I haven't had time to get the radiator modified. But, it doesn't seem to want to idle. Honestly, I only have a couple wires connected, so I didn't expect it to be perfect. Just the main ignition power wires at EB1 and EB2, and another down by the ECU. I also connected the tach wires, oil pressure (got a new sending unit for the 22RE, it threaded right in.) and water temp. I still need to get to the check engine light, 4WD light, the reverse lights and get rid of the old A/T lights.
Still a ton to do...
I was able to get out to a buddies house tonight who has a ton of driveshafts. I measured 47" 3/4 from flange to flange at 6 o'clock with the truck on the ground. My stock shaft was 43" fully compressed, front the A/T. We measured a few, and found one that was 47" 1/2 fully compresses. So, I got that in tonight, along with the tcase mount adapter. I dont like the way it fits, but its in there anyway. I'll get the tcase mount kit from NWOffRoad when she gets the SAS.
Oh, and I picked up an 88' V6 pickup power steering pressure hose. RMA was right. This hose fits perfect, and it has to be a 2nd gen V6 pressure hose. Much cleaner fit and no messing around. A couple tweaks on the hard lines to make it look like factory. It even clears the oil filter. Put some fluid in, and got the steering working, just like RMA said it would.
I'm going to take the radiator over to a place called Havlick's this week, and get that handled. Then the exhaust goes on. I'm still up in the air about the exhaust. I'm thinking a 2 1/4 y-pipe into a 3" cat and a 3" magnaflow muffler, or a flowmaster 50 series... What say you guys?
the bad news...
I think not rebuilding the starter is coming back to kick me square in the nut sack. It wouldn't crank a few times today. I frickin knew I was being cheap by leaving it alone. Damnit
Old Mar 19, 2011 | 11:40 PM
  #110
RMA's Avatar
RMA
way to go man .. hearing the sound of the motor starting took me back to when i first started mine .. feels great .. goosebumps great .
good luck with the rest man ..
ohh and nice find on that driveshaft .. saves a few bucks there..
and that freaking starter .. the maroon 4runner is doing the same thing right now .. my friends super pissed we didnt rebuild it when we had the engine on the floor.
Old Mar 20, 2011 | 07:28 PM
  #111
SHAGGY21's Avatar
so wait you used a auto tranny drive shaft?
Old Mar 20, 2011 | 08:13 PM
  #112
Dunkin's Avatar
I'm not sure what the shaft came out of. He had 30 of them behind his shop. The auto trans is longer than the R150, and the original shaft was too short.
Old Mar 24, 2011 | 10:07 PM
  #113
Dunkin's Avatar
Turns out a friend of mine is a hell of an aluminum guy. He made these necks out of billet round stock. Looking good!
I got to drive it out of the shop today too. The clutch is really light, but engages nice.
I temporarily fixed the idle by adjusting the throttle stop, but I'll get back into the wiring and get it right once this radiator is in.
Old Mar 25, 2011 | 04:17 PM
  #114
Dunkin's Avatar
A friend took a short video of the truck being moved from the parking lot into the shop.
http://www.youtube.com/watch?v=BVW22KdbHYM
Old Mar 25, 2011 | 04:21 PM
  #115
Hell yeah dude
Cant wait to see this thing in person!
Old Mar 25, 2011 | 05:24 PM
  #116
SHAGGY21's Avatar
Holly balls that's nice. I want mine so bad. What rear shaft did u use. Or did u mod yours
Old Mar 25, 2011 | 05:27 PM
  #117
Dunkin's Avatar
I found a factory one at a buddy's place. Measured 47 1/2" or something like that.
Depending on how you do your engine mounts, yours may be different.
Old Mar 25, 2011 | 06:58 PM
  #118
SHAGGY21's Avatar
Soooo? An auto drive shaft
Old Mar 25, 2011 | 09:13 PM
  #119
Dunkin's Avatar
I still don't know, lol. I guessing could google driveshaft lengths of all 2nd and 3rd gen configurations and tell ya what it came out of, for reference.
Although, it's doesn't quite matter. Your engine mounts may have the engine placed slightly more forward or rearward than mine.
Got the radiator back just a few minutes ago. Gonna go pop it in tomorrow morning. I'm gonna use a section of a Subaru hose for the upper and try to use most of the oem Lexus hose for the lower.
Old Mar 26, 2011 | 12:13 PM
  #120
Dunkin's Avatar
I installed the radiator this morning. Looks like there is a small pinhole leak at the lower radiator neck. I think I'll just fill it with some JBweld. (Shhh, don't tell anyone! lol)
The power steering was a flippin bitch to purge the air out of, but I thik I got it.
I couldn't resist a trip to the gas station to put some more in the tank. It was almost bone dry when I started the swap. Man it felt good to drive it again.
http://www.youtube.com/watch?v=ng3MFt1QE-Y
I can't wait to get some exhaust on it. Open header is just not my style... Plus, I'll feel a bit better about revving it with a bit more back pressure in the system.
It also looks like I can fit a 16" pusher fan in front of the radiator. I'll be ordering that today, along with a nice controller for the fan.
