the dragons 88 runner buildup/rebuild
Old Apr 18, 2015 | 09:51 PM
  #1161
Cyberhorn The Dragon's Avatar
ok the greaseable shackles and polyurathane bushings good pairing not easy on a rust plauged truck
got her up on jack stands which were inside some old rims for a few extra inches of height i didnt want to pull the wheels holding the axle on the jack i started working the drivers side being next to the exhaust the top nut fought me all the way off save the last thread breaker bar 1/5th a turn at a time even oiled an such it fought ugh squeak! squeak! pant pant
working area drivers side
bushings removed not cleaned yet what a pain in the tail getting the shackle out had to use C clamps an slide hammer to get um out
old versus new old 19mm to remove nuts new is 22mm to install really the only diference tween them an the new being greaseable
eaten away its worse around the other side
drivers side bushings outer side cracks splits
inner side the right pair are from the spring left from the body mount
cleaned up then primer an paint ran out of both at that point
info on how to, not looking forward to the front eyes likely have to burn them out the kit does come with new steel sleeves
front eye bushings an sleeves
pressing bushings in to frame mount
installed after the spring bolt decided to come out of the brace had to press it into the bushing and bracket at the same time ugh...
an more to come the passenger side!
Old Apr 18, 2015 | 10:00 PM
  #1162
oh an the extra fix it i have to do still
came off when using slide hammer to get the shackle off DAMN ratzinfrazin *&#$%#^ aggggghhhhh
Old Apr 18, 2015 | 10:18 PM
  #1163
an now folks the continuation of the project
the passenger side surprised me the nuts came off without a fight thought Heyyy maybe catch a break ...yeah stupid of me to think that
wouldnt slide out of the bushings god did i have to fight it
annnnnd thats why the bushings were frozen on due to corrosion i had to shove them through the body mount to get it off
comparing the old to new bushings
somewhat cleaned
using this brush inside the holes Juuust fits you can see where its polishing itself on the mounts
annnd it fought me being installed too at this point i thought i had it noooope it shoved the inner bushing out an i had to start all over taking the shackle out an reinstalling the bushing after trimming a small bit of damage to the bushing off
and with my dinner getting cold FINALLY i got it tourqed the nuts to 65 ft-lbs the book says to go 50 -75 so let um go a bit then ill retourqe them
the pile of tools needed for this an im not even done yet collapses
Old Apr 19, 2015 | 07:10 AM
  #1164
Terrys87's Avatar
It is looking better with the new bushings. You are right, those can be a pain to get out. The bolts on your shackle are in better shape then some I have seen. I have seen them so corroded that they are half the size.
Old Apr 19, 2015 | 10:16 AM
  #1165
oh you saw the good side of the passenger one terry if i had turned it up the thickness along that is less than half its the one that fell out of the bracket back when i did the yuk mod we put a bit of weld on it to hold it in
Old Aug 9, 2015 | 12:05 AM
  #1166
hey all well doc has had me off my feet with a cast up to the knee to help the foot heal an it is helping just a pain to drive with it on an not exactly legal...
got to work on the AC today though due to the compressor type the hose terry sent me it was wrong an not long enough by almost 6 inches
but we hope we got the original fixed with a shop in town installing hydrolic connections in the middle of the line good for 1K psi they should be able to hold a 130 max the adjustable idle up valve though works thank ya terry the VSV we found out failed we hooked up the two lines to each other an look at that the adjustment on the valve worked idling up the engine so the ac compressor ran while just idling with out the VSV working it idles down where the compressor stops working an so does the ac
got on ebay an bought a newer vsv from a t100 will wire that in when it arrives got it for 11 bucks
drover the runner round the mile an whoa the ac blew COLD felt awesome too first vehicle since i lost my 88 nissan that had AC in it havent done much anything else just trying to get the foot healed
Old Aug 9, 2015 | 06:08 AM
  #1167
Terrys87's Avatar
Hope your foot heals this time. It has been an ongoing issue for you. Great to hear you got your ac working. I tried to call back. I will be up all night tonight if you want to give a holler.
Old Aug 9, 2015 | 12:58 PM
  #1168
itd be the most excellent thing of all time for my life for the foot to heal
the ac we shall see really hoping we got it with that line repair i have to go out an check it today see if it works still since its sat over night
Old Aug 13, 2015 | 12:37 AM
  #1169
the T100 VSV arrived today so heres how to quite easily adapt it since the original is near impossible to find an the t100 part was only 11 bucks
so here we have the failed VSV on the left an the replacement on the right i did test it via a 12v DC power brick it clicked nice an loud the original didnt top wire is live so + an the bottom connector is the switched negative an when the AC switch is turned off an on it turns this valve off an on as well
so removed the bracket as i still want to bolt the VSV to the valve cover i need the tab an some of the old bracket
so after a bit of grinding off the excess bits an bending it up i drilled the small hole for a very tiny screw that i found one that fit after being trimmed down to less than 3/8 of an inch
heres the T100 VSV now attached to the tab from the old one
an here it is on the engine now i got it with a pigtail of the T100 harness an id recommend it in my case i put a couple male spade terminals on it so they plug into the factory harness plug i could have cut the original harness an put the new in but ehh i taped it all up nice an neat after this so it can be water proof an wont flap around
this is the idle adjustment valve if its working when the VSV is activated it allows more air into the engine bypassing the throttle plate causing a controlled increase in engine rpms which keeps the AC compressor on as it will cycle off at normal idle rpms but not around 1K rpms the white adjuster is how you adjust the AC idle and also works with the power steering if its loading the engine down
Old Aug 24, 2015 | 09:36 AM
  #1170
Peevedkitten's Avatar
Just amazing!
Dragon, I read this thread over the weekend while taking breaks working on my '95. You're an absolute inspiration! You really saved that runner from the scrap heap. It's not a flashy off the wall SAS mega trail build, but the quality and attention to detail is just top notch! I really look forward to watching it progress from this point forward.
Subscribed!
Old Aug 24, 2015 | 09:45 AM
  #1171
thank you Peevedkitten an welcome to yotatech
well ive rebuilt her on a very limited budget an i am quite proud of it
if you want good reading any of terry87 threads are a great source for info he is the toyota wizard
Old Aug 24, 2015 | 01:58 PM
  #1172
Terrys87's Avatar
Thanks for the compliment Cyberhorn. Glad to see you were able to come up with some newer replacement parts.
Old Nov 6, 2015 | 09:14 PM
  #1173
so havent done a lot to the runner just driving a bit foot in a cast the wound is healing slowly an ill take any of that
i did have to goto a local pickapart looking for a seat hinge for a 92 dodge ram 350 but they didnt have it BUT they did have an 88 3.0 sr5 with AUTO hubs (never seen that before) sunroof an such no rear heat though
she was in sorry shape already torn apart but little no body damage i was seriously looking at her rear body metal but id have to hual a generator an sawsall out there to get it ugh not with my foot
i did get off her the rear mud guard that goes along the rear of the body for 3 bucks all but one clip in perfect shape so the trip wasnt a total loss but god my leg an foot ache now trudging up n down rows over heavy gravel (fist sized chunks) in a cast
Old Nov 6, 2015 | 11:47 PM
  #1174
Terrys87's Avatar
When I got your text I was not sure if you were up or not. I wonder if you could rent a tool from a tool rent place that would be possible to get the quarter panels off. Not sure if I have seen auto hubs on a first gen before. They are great when they work right or if you have them locked before you get stuck.
Great to hear your foot is starting to heal. You think it is going to heal completely this time? Before your and my experience I really never heard about injuries not healing. My tooth has never healed and doc just said to live with it.
Old Nov 7, 2015 | 06:44 PM
  #1175
im not even sure how the 88 auto hubs might work terry are they electrical? vaccum? i was just looking the thing over an was.. wait where are the hubs? smooth plate on there looked closer it said 'automatic hubs toyota' i know her pumpkins were gone trans was open at the shifter damn shame that water dribbling down into it ruining it lot of the interior was there carpeted door pockets all in red
Old Nov 9, 2015 | 03:12 AM
  #1176
Terrys87's Avatar
I have never worked on auto hubs and have only seen a few of them. As I understand they are vacuum operated. Guess they work great if there is not any leaks from what I have read. I know of a truck I wish that I could of gotten the interior out of but by the time I found it the interior was ruined. That can be some hard stuff to find in cloth.
Old Jan 19, 2016 | 06:45 PM
  #1177
well reloading pictures to the fisrt posts of my thread as imageshack went commercial FU bums grrrr
an friday got quite the scare its been majorly cold even so much as freezing the horse water tank 24+ inches deep even with the heater!
got a call early in the am room mate was sick an couldnt stay the day could i come get him yeah so i drive out get breakfast an head on down the road well to turn on to as theres two ways into twin falls an coming off 60 mph i had to slow to least 20-30 mph ...hit breaks had pedal an
nothing
oh crap pump breaks had pedal plenty of it but nothing was going on! zip ziltch
i was OOOOOOOHHH OOoooOO an made the turn down shifting an rear tires chirping making diamonds where they shouldnt be ill tell you!
went over a series of train tracks an brakes started to work i pulled off an stopped was WHAT in the BLEEP! checked fluid fine vac line fine looked at the backs of the wheel cylenders see if i was leaking fluid no..tentatively made the trip but nothing happened like it again
so sunday bled the brakes have plenty of pad on all 4 passenger rear isnt holding the e brake very well but drivers is fluid drained was clear an no bubbles only fluid from the pass rear had any color an very minor no problems at all bleeding things
dont know what caused the issue
Old Jan 19, 2016 | 11:38 PM
  #1178
Terrys87's Avatar
You have not experienced life until trying to drive with no brakes, lol, I know what that is like, not a good thing when they go unexpectedly. On my 85, the master cylinder would work but under heavy pressure they would fail. My bet would be the master cylinder is half way working.
Really pay attention if you go and swap rear slave cylinders. The parts stores can give you the wrong ones and you will have a similar experience that you just had. They will work and then the piston can pop out and then not brakes again and this time you will lose fluid.
The 84-88 trucks on the rear slaves use different sized cylinders. They will bolt up and the metal lines will connect like it should but if you get the wrong slave cylinder, the piston can pop out. I am betting your master cylinder is failing and causing the issue.
If all goes as planned, I am going to try and tear my old transmission down and see what is causing the ball bearing in the blender noise. It would be nice if it is something that could be simple to fix but am not holding my breath on that.
Old Jan 19, 2016 | 11:41 PM
  #1179
worked fine when we bled the brakes an its only couple years old
Old Apr 5, 2016 | 02:47 PM
  #1180
so just an update foot is healing truck isnt couple weeks ago it blew the main weld on the exhaust collector part of the pipe went from quiet purr to full open pipe engine stumbled a bit roaring to high hell WOW that 4 cyl is LOUD had a sheriff spin round as he passed me as it happened an followed for a bit but he didnt pull me over yay
got appointment with exhaust shop to weld it back up tomorrow seen a HUGE decrease in MPG due to the o2 sensor not getting its proper airflow i did get it back up on the collector an a pipe clamp up there to hold it via a bracket on the trans which clearly was meant for a clamp but never got one sigh..one of the costs of getting a truck someone else took apart you dont know where things go or might need to go
might have a minor leak in the cooling system but dont see anything just a tiny bit of smell so who knows nothing else to report shes been reliable an dependable any temp any weather couldnt ask for more
will likely finally get onto the rear fenders this summer repair them in fiberglass
