the dragons 88 runner buildup/rebuild
Old Jul 7, 2013 | 05:55 PM
  #761
Cyberhorn The Dragon's Avatar
well i just splurged on myself i got ...(that sounds terrible sorry all) i just got the martin crawler shifter seat an ball end for the stick
their running a sale so figured id snag them while the gettings good found out my trans is the one with the square top seal the passenger seat cables are in epic new condition gona lube things while in there an put back together till parts arrive
Products on order:
1 x Heavy Duty Shift Lever Socket - $7.49
SKU: MCTM-532
Transmission: All other common Toyota Applications
1 x Heavy Duty Shift Lever Ball Seats - $12.49
SKU: MCTM-521
Application: 1985-88 W56 EFI Setups (Red)
Old Jul 7, 2013 | 07:18 PM
  #762
so heres some pictures for mark
pulled pass seat to get to the last screw holding the center on (it was in wrong) >..<
i vacuumed after i was done
cleaned up the door sill someone previous to me got paint on it
then heres the part i was digging in to see the square rubber seal which some are round others are the square that changes the size an color of the transmission shifter seat from martin crawler im doing this as got a lot of slop going to 3rd gear from second gotta hunt for it a bit this should help
Old Jul 7, 2013 | 11:45 PM
  #763
Terrys87's Avatar
The third picture down, under that clear/black cover is where the contacts are. I updated my 88 thread link to show the .22 shell as well. If your Combo Switch doesnt show any burnt wires, I would say it is just the contacts needing cleaned. Do Not try and bang on the shaft to get the steering wheel off. It will bulge easily. I seen a friend of mine trying to avoid renting the tool to take it off and you wont be able to get the nut back on that holds the steering wheel. Parts stores rent the tool for free.
Pull the steering wheel and there are 4 screws that hold the assembly on to the column, and then the combo switch comes off and you have 2? screws that hold the cover on. A finger nail file or fine sandpaper will clean them up nicely. It only takes 3 or 4 light brushes to get the contacts clean and working again. I have fixed several of the switches and never have had to replace one.
I did try using my 86 on to the 88 and something didnt quite work right. Cant recall what it was. If you do replace the combo switch, if I recall right, there is a part number down at the end of the wire harness where it connect to the rest of the column and you need to match it up as there are several different switches out there and they will work, but some functions dont work correctly.
I went to work on my Light Switch and Wiper delay. I plugged my old one in and the wiper delay worked. But not bright lights. I then tried to combine the 2 and was going to have cut wire and splice and didnt want to go that route.
MORE INFO>>> https://www.yotatech.com/forums/f116...icator-229946/
The Light Assembly I had before was from an 86 and it has another plug my 88 didnt have. I figured it was for some option mine didnt have so didnt think much about it. The white plug is what I am talking about on an 86 in this picture.
Today I got to looking at it (the white plug) and it runs to the wiper handle and I am guessing it is to the delay in the handle. So I then decided to see what I could do about my original Light assembly.
I took the Steering Wheel off. I have had mine off before and have it snug but not so tight I need a Steering Wheel Puller. If you havent had it off, dont bang on it as it will bulge the Steering shaft. Go rent a puller from the parts store. It is free.
You will need to drop the lower plastic panel and I diconnect the dimmer switch and just let it lay on the floor. Remove the Steering Wheel and the covers to the steering column.
There are 4 screws that hold the Light Switch Assembly on. They are recessed. Then disconnect the black clip that keeps all of the wire bundeled to the column and 2 screws that hold the blue connectors to the black tabs /clip.
Once I had it off, I had to take 2 screw out that hold the hazard light switch to the assembly, and set it out of the way. I then had to remove the clear plastic cover so as I could use my wife finger nail file (yeah.. she liked that idea) and went over the little copper tips on the copper layers. Just a couple of times to help make a good clean contact. Then I hit with some WD-40.
Here is a good picture of the contacts that need cleaned and more info if someone needs it.
https://www.yotatech.com/forums/f116...t-work-100088/
Put it back togther and everything works great. The 86 and 88 Light assemblys do have different part numbers on them and they interchanged and it got me thru. But it is nice having everything working as it should.
I did take my passenger kick panel off and didnt see a relay box there. Not saying it isnt, I just didnt want to pull the ECM and since I was able to test with a good wiper delay switch, I didnt need to go that far into it.
Found another link to a headlight problem I just wanted to add.
Here is how I fix my horn issue.
Got the horn to working. I used a .22 shell to make the contact to the steering wheel. I found this on Yotatech and like it better then how I used to fix my horns. I have it listed on my 88 4Runners build thread for more details about getting the horn to work on the first page. Will add this info at a later time.
Combo switch is around $40 at the boneyard here if you can find one. I just cleaned the contacts with some 1500 grit sand paper. Have it listed on the 88 runner build thread as well.
Old Jul 8, 2013 | 12:14 AM
  #764
thank ya terry we've got several pullers so no worries there
thank you for the info! oh wise sage of toyota lore an skills i bow to your knowledge
Old Jul 10, 2013 | 02:15 PM
  #765
4 in speakers arrived an so since after tomorrow im gona be sidelined again i jumped right in well right off i found out the drivers side POS speaker jammed in there was shorted out when i removed it the rear speakers came on LOUD i about jumped outa my scales
the wires were uncovered an just twisted together so i sodiered them an applied electrical tape
heres that one all bent an messed up POS and the new pyle 2 way going into that spot MUCH better fit!
and amazon says it wont fit BAH what the bleep do they know PROOF ive got it fits!
then the other side oh look a replacement speaker...with duct tape...oi vey....
all installed MUCH better sound quality i can actually hear the music an feel a bit of the bass
my dash is all fit back together LIKE it should be YAY im a happy jammin dragon
Old Jul 10, 2013 | 02:22 PM
  #766
ChefYota4x4's Avatar
I'm totally confused... Did someone ship you that speaker with duck tape on it? Or should I say mailing tape? I can't tell... I'll take your word for it.
Way more importantly I would like to mention that all my best is going with you to your appointment man! I'm sorry you gotta go through this but I hope it comes to some type of progress when it comes to your quality of life!!!
Old Jul 10, 2013 | 03:01 PM
  #767
nope the one with duct tape on it was in my passenger side speaker hole it fit but the tape was making it sound like P00
thank ya mark yeah the tension an worry i have been through surgeries so many times its not funny i know more than the nurses most time but i need this thing done an healed
Old Jul 12, 2013 | 06:36 AM
  #768
Terrys87's Avatar
The speaker looks as if belongs in there. The duct tape speaker is fully showing up in the picture, but from what I have seen from POs, I wouldnt be suprised.
Old Jul 12, 2013 | 07:10 AM
  #769
bbrideau's Avatar
hey now don't knock the duct tape speaker, if it works it works!
can't say i've ever seen that kinda "fix" before
Old Jul 12, 2013 | 10:34 AM
  #770
Hope ur doing alright: No unbearable pain and such! More so, WE WANT RESOLUTION FOR THE WOUNDED DRAGON!
Old Jul 12, 2013 | 12:36 PM
  #771
well heres the list
got a 5inch long 3 inch wide swath of my right thigh worth of surgical road rash the wound vac is on the foot and the thigh hurts like road rash from when ive wrecked my bike as a kid. its also under a plastic wound seal so blood kinda floats around in there...kinda a cool bubble effect lol
the person who put the wound vac on dont know diddly on how to do it we fixed it here at home so it wont hurt the new graft or the foot and also fixed the leaks an clogs... like i said we sometimes know more than the professionals
my 6x9 speakers came in haven't opened the box yet too look at um the 4in came with grills, wire, screw an panel clips i hope the 6x9 do as well need the grills to protect them in the back
my martin crawler trans bits are to be delivered today an i get to chew at the bit an wait to go put um in LOL
and my luck of getting body metal again falls through, a partout in Louisiana fell through the dad backed his tractor over the pile of body parts... so no used passenger fender for dragon...
still no luck on the rear body metal lookin at yota fiberglass but the god high price for 1 panel is painful an i need both sides in the rear
Old Jul 12, 2013 | 12:38 PM
  #772
not knockin the tape it just dont work for speakers LOL
Old Jul 12, 2013 | 12:59 PM
  #773
Wow, sounds like....... not so much fun! Lol. ... Glad you're home alright!
Old Jul 12, 2013 | 01:56 PM
  #774
nope no fun i cant work on my truck lol no pain today so im fine i know the nurses yesterday were all are you sure you dont need anything for pain no its not really that bad
one nurse though i liked her lol kinda was the soo can we talk more?
Old Jul 12, 2013 | 02:11 PM
  #775
shifter parts arrived
chewing bit now also mind the drool LOL
Old Jul 14, 2013 | 05:31 PM
  #776
Terrys87's Avatar
That makes a big difference on the shifter throw and an easy fix. I couldnt believe the difference the first time.
Old Jul 14, 2013 | 07:00 PM
  #777
im lookin forward to puttin it in ill tell ya
Old Jul 14, 2013 | 09:27 PM
  #778
Redeth005's Avatar
I remember when I put my Marlin Crawler ones in. Huge difference. Just make sure the one that goes on the shifter is on really good or else it'll get stuck inside your tranny like mine was lol. I had one heck of a time trying to take it back out hahaha
Old Jul 14, 2013 | 10:15 PM
  #779
what glue it on? i thought it snapped on the end
Old Jul 14, 2013 | 10:20 PM
  #780
Redeth005's Avatar
Exactly! Thats what I thought but apparently it wasn't completely snapped in. Lol
