the dragons 88 runner buildup/rebuild
Old May 8, 2013 | 04:06 PM
  #641
junk4u's Avatar
Nice Work, enjoying reading the work in progress...
Old May 8, 2013 | 09:07 PM
  #642
Cyberhorn The Dragon's Avatar
Originally Posted by Terrys87
24 hours later and the hole came back in my gum. My dental surgeon is just going to be thrilled when I call him tomorrow. I thought I felt it getting weak. Yeah!!! grrr...
awww da*&% it terry :-( dang it all
i spent hours at the dr office an hospital gettin tests done an having to re -relate my entire history of medical procedures they had to 'refresh' my files details part of a every so many years check..bleh...:-P
Old May 8, 2013 | 09:10 PM
  #643
thank ya junk
Old May 8, 2013 | 11:47 PM
  #644
ChefYota4x4's Avatar
Just checking in..... ANXIOUS! hahaha. On the road Redrum Status "coming soon"! hahaha.
Old May 8, 2013 | 11:54 PM
  #645
what'r ya anxious about mark? lol my surgery one of dozens ive been through is on the 16th id like to get my tail gate reassembled before then but probably not kris wants to patch the rust hole under the gate which does make sense (darn it) lol
Old May 9, 2013 | 04:58 PM
  #646
not a lot today got the skid plate painted and stopped by the DMV an filed for her titial 44 bucks it'll be nother 50ish for plates which ill do next month
Old May 10, 2013 | 10:00 PM
  #647
WOOT parts came in thank you terry! um but i didnt need the mud dauber wasps them nearly ready to buzz grubs went down the garbage disposal LOL
anyhow the rear handle arrived ive disassembled it all steel parts are in a smaller bucket sized electrolysis tank an already after just 3 hours are nearly totally rust free the one license plate light had some scaly rust i took it touched it an it all fell right off
do like electrolysis!
polished up the plastic an the rubber bits the clear covers for the lights all sparkling clean my lock ready to go in i think i might touch up the Toyota on it couple scuffs on the white letters
kris said he wants to fix the rust holes under the tailgate hinges then after paint the tailgate with its final coat this weekend YAY
i might get my tail gate back together before im sidelined for several weeks from the surgery on thursday the 16th hole in mah foot has gotten a bit bigger but like a nurse at the hospital said sometimes the lesser wound has to be ignored for overall health an my blood pressure is better now that ive been active walking around doing things just hate the danged if i do danged if i dont effect
Old May 10, 2013 | 11:28 PM
  #648
GOOD POST!!!! ^^^^ Great news! Great to hear! Glad the BP is under control.... And best wishes on the Surgery!!!!!!!
Old May 11, 2013 | 08:14 PM
  #649
O M G
what a day! oi! dragon is covered in rust dust welding an grinding dust some paint dust a bit of duraglass dust too an im beat
SO gona say this wow.... be right back have to edit pictures an load um to imagebucket
Old May 11, 2013 | 08:40 PM
  #650
OK so i went out an started cleaning my parts out of electrolysis had to leave one of the stand offs in there for a bit longer
an heres what scaley rust can do ow..but its okay the electrolysis leaves NO rust left to continue the damage so i cleaned them up put some tape inside to make a smooth surface an fiberglass bondo'd the holes smoothing the outside off nicely
primer, paint an oooh sexy shiney sealed metal no more rust...
touched up the toyota letters so quick sanding after masking tape
painted an left to bake in the warm sun oh more of the lights housings gettin warm in the sun all day as the silver inside is high temp paint needs a bit of warm to set up good
all ready to reassemble
BUT WAIT
theres MORE!
Old May 11, 2013 | 08:46 PM
  #651
MORE? THE HELL YOU SAY !!!!! Hehehe
Great work!
Old May 11, 2013 | 09:15 PM
  #652
so! kris comes out an we start looking at the runner he says well if im gona fix the rust in the pockets under the tailgate hinges we best yank the bumper
we were both incredibly surprised how easy it came out!
showing the rust near the tail that needed to be cut out we were also both very pleased how solid the rear area is on both sides yes still lots of rot around the wheel arches but these areas are remarkably solid
after loosing the bumper, Kris joked hey look the springs arent flat no more LOL
the plastic sides all 4 bolts in each snapped off not one saved "sigh"
so i then went after the drivers side with a wirewheel as he got his mig welder set up the drivers side corner was caved in so we welded a washer on it several times in different spots to use the slide hammer to pull it out where it would be far better for duraglassing
some shots of the work minor patching an welding a body seam after cleaning the rust out of it
an then how bad the hidden rot was on the drivers side it all got cut out an then patched
from the outside:
from the inside under the tail gate hinge mounting point
patch being welded in
the corner the holes are from the weld being too good but we got the corner back out where it belongs kris filled the holes up an will fix some small pinholes that came open when i ground things flat an sanded the corner clean
heres the patch 4 1/4" x 2 1/2" 3/4 bend not a full 90 degree bend i did dang good making that patch for Kris to weld in polishes claws
after Kris called it a night i went on an using a torch with vice grips an Pen oil got all 8 broken off bolts out so we can put the side plastic back on later three of the pains in my ringgear! NOT ONE came loose without a heat wrenching then vice grips an cranking on them till they moved an then a 1/6th of a turn at a time they were twisted out fighting all the way
i am now officially tired an very dirty...
Old May 11, 2013 | 09:18 PM
  #653
Great work!
YEP lots more an still more to do tomorrow!
can our hero's save the valient skelrunner from its terrible rusting curse!?!?
tune in next time!
same runner time
same runner channel!
Old May 12, 2013 | 12:54 AM
  #654
Terrys87's Avatar
You are doing a great job in getting it straight again. Great work, that is what I like seeing.
I trying to export them dirt dobbers out of here so they leave my trucks alone. lol I was suprised to see they were still alive. Sorry about that. You got that tailgate piece looking great.
Old May 12, 2013 | 05:48 AM
  #655
Redeth005's Avatar
Wow that's one amazing job. I likr yoyr idea on the toyota lettering. That is pretty cool. Great welding skills William.
Old May 12, 2013 | 06:45 AM
  #656
kornhuskerwizard's Avatar
Great work!! Looking good!!
Old May 12, 2013 | 10:31 AM
  #657
:-D no worries terry it was fine an thank you though we arent using factory paint the rustolium royal red is a perfect match and its a tough paint also seals rust keeps it from getting oxygen which helps it make more rust
ill have to see if i can get some of our rock jackets to accept goin on a trip.... just kidding
Old May 12, 2013 | 10:35 AM
  #658
ahh thats not me welding! thats my roommate kris
my welding skills were all in a machine i loaded stainless tubing into with valve bodies then i did all the pressure testing an QA i know how but my hand welding is abysmal quality
the tailgate letters are painted from the factory its not molded plastic why not refresh them if their a bit scuffed
Old May 12, 2013 | 10:36 AM
  #659
thank ya KHW its all to keep her around for a good long while
Old May 12, 2013 | 06:12 PM
  #660
no paint today just took so much to fix the inside of the corner an then bodywork on just the corner
so on wit the show!
the hole just under the hinge mount up into the body thats the inner core behind the taillight an outside fender for your orientation
after much welding an grinding an cursing as holes would open back up is feexed!! corner is ALL steel parts are double thickness as they provided structural support an had rust in the layers we had to cut it out an replace it which is what took so much time
i put a coat of filler on an started filing it down i went over board a bit but thats due to the tiny rust dents an such on the side an the caved in part at the back
most of it all sanded off highs an lows all a lot smoother than they were
nother hit with filler an spot putty sanded primed TADA
coughs dust
yes the corner is part of the wheel arch an till we get replacement metal for that i really dont want to dig in an leave it wide open so stopped there
repairs to the passenger side much simpler cut out some rust in the seams an welded them shut patched a small hole below the hinge mount
now KIDS ID LIKE TO BRING YOUR ATTENTION TO A MAJOR PROBLEM
the world sees too much of this an its wrong an has to stop
SPRAY FOAM this was under my drivers side rock guard which i broke trying to get it off no worries i have a plan for that
JUST SAY "NO" to foam
bleh! took wirewheel to it FReeeippp!!! pOOF!
some rust bubbles under my rear carpet yay more rust
