CBO's 87 4runner build
Old Sep 30, 2015 | 03:16 PM
  #61
Terrys87's Avatar
You have been getting some serious work done, great job. I had the same spots inside my axle housing and the guy that helped me rebuild my axle said it is nothing to worry about.
Old Oct 5, 2015 | 04:53 AM
  #62
crashburnoveride's Avatar
Got carried away with the cutoff wheel on some rust holes and did some patching.
The floor pan is still terrible but at least the big hole is gone. shooting for its maiden voyage November 20-22 at Tuttle.
Old Oct 5, 2015 | 08:36 AM
  #63
Gizler00's Avatar
Very nice Pat!! Once you get going, its not hard to keep up the momentum. Looks great.
Did you throw the AFM on yet?
Old Oct 5, 2015 | 05:30 PM
  #64
Sure did. Thanks yet again. She runs now.
Old Oct 7, 2015 | 07:09 AM
  #65
Spartan locker 3rd going into the runner.
Each one of these old Toyota's that I take 3rd's out of the E brake cables never want to come off. No amount of liquid wrench and bfh swinging works. So my awesome work around is cutting the e-brake cables. Haha who needs one when u have a manual transmission?
Old Oct 22, 2015 | 04:09 AM
  #66
Did some garage therapy yesterday. Getting the xfr case mount put together. It's 3/8 steel. Welded a plate on the back for peace of mind.
Stay tuned for the slowest new dad build on YT! 😉
Old Oct 22, 2015 | 04:26 AM
  #67
kelvinb's Avatar
Son of a..... I made about 6 of those t case braces. I don't know if I told you but I would of given you one for free. Truck need one!?
Old Oct 22, 2015 | 04:29 AM
  #68
Oh well this one is clocked 10 degrees to match my adapter. I actually sold the truck last weekend.
Old Oct 22, 2015 | 04:31 AM
  #69
kelvinb's Avatar
I think this one would of worked. It's basically just a cut out of the center and you weld on the braces as needed. Either way awesome job.
Old Oct 22, 2015 | 04:44 AM
  #70
I'll always take a compliment from a professional welder. Ha. I shake too much for prettier welds and my wire surges, its not a smooth feed. Oh well.
Old Oct 22, 2015 | 05:39 AM
  #71
kelvinb's Avatar
Surges as in the wire pushed back into the gun when you're welding? Without seeing/hearing it you can try 3 things.
1. Hold the gun closer to the puddle
2. Turn the wire speed down
3. Turn amperage up.
Try each one individually.
Old Oct 22, 2015 | 07:28 AM
  #72
Gizler00's Avatar
Very nice Dude.
Kelvin..... We need to make some more of those when I get the New CNC setup!!
Old Oct 24, 2015 | 05:51 PM
  #73
Xfr-case mount almost done. Just needs the mounting points burned on. And I pulled the driveshaft apart... wtf? I thought it had more slack than that!
Old Oct 25, 2015 | 01:27 PM
  #74
Gizler00's Avatar
Haha. They are pretty easy to pull apart if they have seen a life of getting regular Lube. I had one that needed heated with a torch to almost cherry red before we could beat it off with a hammer.
Old Oct 25, 2015 | 01:35 PM
  #75
That sounds dangerous. Teens, don't try that at home.
Driver's fender is getting finished today. Will post pics later.
Old Oct 25, 2015 | 01:39 PM
  #76
Gizler00's Avatar
HAHAHAHAHAAHA!!
You are making good progress on this thing Buddy!!!
I am trying to order some OME springs for my rig. I thought abotu All Pro but decided for what I use the runner for OME would be best .
We NEED to do a little trip to ashland at that place where we can camp and fish. Ill bring the boys. They would love it.
Old Oct 25, 2015 | 05:37 PM
  #77
That is definitely a need. All you gotta do is ask when bud. We'll plan something.
Fender work. (Small garage problems)
Old Nov 4, 2015 | 05:50 AM
  #78
So I wrote out a post a few days ago and then the post failed. So long story short, tcase is out. Its dirty af.
Im kinda freaking out cuz I have 2 weeks to get a bunch of work done before a wheeling trip but other things keep taking my time. Had to fix my hottub before freezing temps and a pipe decided to leak in my basement. Hopefully after work I can get some runner work done.
Old Nov 4, 2015 | 09:32 AM
  #79
kelvinb's Avatar
Very nice Dude.
i have quite a few files. a lot of them i googled and still might be available, either way i agree. i want to make some rear brake caliper brackets!
Old Nov 5, 2015 | 06:11 PM
  #80
Drilled the hole for the extra shifter and the crawl box is bolted in.
