CBO's 87 4runner build
Old Sep 8, 2016 | 11:45 AM
  #201
crashburnoveride's Avatar
I drove the runner around the hood the other day. In 2hi I heard a bad sound coming from the transfer case region. Put it in 4hi and it stopped. So idk what thats about. Will have to test again. Hope its not all effed up in there. Also still getting a clunking sound from the front drivers area. Back when I cranked my torsion bars the drivers side "popped" even tho I turned it the same as the other side. So could my Tbar be broken? Wouldnt it be visibly sagging if it were broken? I wanted to wheel again in october and november, but if the tbars broken I might just start the sas. Which basically means it'd be down for a very long time cuz I'd have to do my chevy rear springs too. Ugh.
P.s. the internet is right. You cant steer worth a damn with a welded front! Haha, even hubs free you cant turn if you're in 4wd. Which was a surprise to me. It will be interestimg to wheel it.
Old Oct 12, 2016 | 10:23 AM
  #202
Hey guys. I'm getting ready for another trip to the offroad park in November so I clearanced the skid plate.
It amazed me that I had to trim so much to clear the double cardan because supposedly this was specifically designed for this exact application. How the company screwed that up I dont know, and they never replied to my email about its failings. I also put washers on the bolts because it didn't even come with those. So hey front range offroad, you failed here.
I also discovered that my drivers front hub does not actually unlock when set in "free". So thats neat.
Old Oct 12, 2016 | 06:13 PM
  #203
A few of the passenger side holes don't line up on my winch plate.
The yellow circled holes line up and I just gotta buy the bolts. The green one I'm going to drill it out and run a bolt with a nut on the back. That should do it!
Old Oct 13, 2016 | 03:27 AM
  #204
arlindsay1992's Avatar
The frame tab behind the green circle is pretty easily bent. A couple bumps with a hammer should be able to move it to right behind the hole in the bumper.
Old Oct 13, 2016 | 03:28 AM
  #205
I already have a frame brace welded onto it thats 1/4"
Old Oct 13, 2016 | 03:33 AM
  #206
That changes things. You could also slot out the hole in the bumper. Saves you from having to reach around and hold then nut every time you install or remove the bumper. Just ideas.
Old Oct 13, 2016 | 03:52 AM
  #207
I like that idea. Just use a big washer. Thanks for your input.
Old Oct 13, 2016 | 04:56 PM
  #208
Gizler00's Avatar
Pics arent working for some reason.
Old Oct 13, 2016 | 05:21 PM
  #209
I know!! Photobucket crashed or something none of my pics work in this and my truck thread! They better fix it or im gonna be pissed!!!
Old Oct 28, 2016 | 06:55 AM
  #210
Putting two marlin crawler HD eco seals into the transfer case. Its definitely beefier. Also putting rtv behind the washer and nut.
FYI, If doing rear seal dont drain the tcase. If doing front seal just drain it first.
Old Oct 28, 2016 | 09:13 AM
  #211
Gizler00's Avatar
Nice work buddy. Sorry I did not get back to you right away. I have been swamped this week.
Old Oct 28, 2016 | 04:24 PM
  #212
All I got to say
Old Nov 3, 2016 | 05:15 PM
  #213
Never used a bolt extractor before. Didnt work. Probably needed a bigger one.
So I ended up cutting out more sheet metal around the shifter to access the bolts without lowering the transfer case. I just used tin snips and a drill bit. So i put oil in from the top and will worry about the fill bolt later. On to the next item which is drivers hub rebuild.
Old Nov 3, 2016 | 05:28 PM
  #214
Gizler00's Avatar
I can help you get that off easy.
Old Nov 3, 2016 | 05:31 PM
  #215
How? I tried welding a nut to it. Couldn't get it to stick. The bolt may be alloy??
Old Nov 4, 2016 | 05:28 AM
  #216
Gizler00's Avatar
I believe it is an alloy drain plug.
I have some other extracting methods. I can see if I can slip away over a weekend or one night during the week, when the wifes back in town, to come give you a hand.
Old Nov 4, 2016 | 09:58 AM
  #217
Ya or I can trailer it up to iowa and we can also burn on the front spring hanger and put in the frame tubes.
Old Nov 4, 2016 | 04:16 PM
  #218
Gizler00's Avatar
I'm down with that
Old Nov 5, 2016 | 09:06 AM
  #219
Rebuilding the hub.
So I took it out for a test drive. No weird noises or anything. I think that bad sound I heard last time was the front square driveshaft clanking because it has some play in it.
So I was definitely happy with everything! I'm going to fix the passenger front fender next.
Old Nov 5, 2016 | 10:11 AM
  #220
Gizler00's Avatar
Very nice!
