Broke and driftin SAS
Old Jul 6, 2014 | 11:21 AM
  #181
kornhuskerwizard's Avatar
Well Saturday my buddy came to weld my sas and we decided it was so nice out that we decided to go wheeling on the river...Name:  053_zpsfe0ed1b3.jpg
Unstuck...3hrs later thanks to a hi lift and some aluminum ramps we shoved under the tires.Name:  067_zps0cd119e2.jpg
Size:  17.1 KBName:  image_zpse9618d34.jpg
So we didnt get no welding done so that was a bummer but we had fun cause we dont get to go wheeling often,actually it was on private farmground and the farmer showed up and told is to not leave any trash and have fun!
Old Jul 6, 2014 | 11:30 AM
  #182
Gizler00's Avatar
Seriously looks like a blast. That's Too bad you didn't get any welding done though.
Nice farmer!!
Old Jul 6, 2014 | 02:46 PM
  #183
Terrys87's Avatar
Looks like a good time you guys had. Looks like some bottomless mud.
Old Jul 7, 2014 | 07:03 PM
  #184
Yea, i really wish i could of got some welding done, but im actually happy i CAN use the welder now...it took forever to get it wired to my garage. But im definetly excited about getting this project moving because it deserves it!!
Nice farmer!!
Great time Terry...and yes...bottomless mud and sand, someone said down the river theres a old bronco 2 buried in the sand so bad all you can see above the surface of the sand is like 4 inches of the roof. They must of left it stuck and then it rained or something.Ill have to see if i can get a pic of it.
Old Jul 7, 2014 | 07:21 PM
  #185
rattlewagon's Avatar
I want to see pics of that! Just dont drive to it...
Old Jul 8, 2014 | 06:53 PM
  #186
Actually this river is very driveable but this year we have had alota rain, but it was deceiving cause the surface was dry but wet like 6inches under...REALLY WET
Old Jul 25, 2014 | 09:52 AM
  #187
d01.jpg[/IMG]
Made some headway on my truck this morning, had a freind stick weld my tubes and hanger with 3/32 7018, did a good job. So i went ahead and put the springs and axle under it and went to mount it but i realized i dont have ubolt plates. I could make my own,but i might check and see whats available.
Old Jul 25, 2014 | 11:16 AM
  #188
Gizler00's Avatar
Looks great buddy.
Old Jul 25, 2014 | 12:04 PM
  #189
Thanks Mark!!
Old Jul 25, 2014 | 04:27 PM
  #190
rustED's Avatar
Looking good Chris, nice to see that front axel under there!
I still need to get a u-bolt flip kit for my front axel, I reused the original ubolts and brackets that came with the 85 axel because I was on a tight budget at the time, but man those things are rock anchors!
Old Jul 26, 2014 | 04:14 AM
  #191
I imagine they are, yea a flip kit shouldn't be to much,maybe today I'll try and remove the old pitmann arm,its gonna be a bear!!
Old Jul 29, 2014 | 06:18 PM
  #192
Swapped out the pitman arm.
Old Jul 29, 2014 | 07:14 PM
  #193
Gizler00's Avatar
Nice work buddy. Good idea on cutting that arm to relieve the tension. I would not have thought of that
Old Jul 30, 2014 | 04:22 AM
  #194
bump530's Avatar
Ive had to cut pitman arms off before (I cut vertically tho). Knowing that, Ive sprayed mine down a couple times with PB Blaster over the past few months hoping it will be easy to take off when the time comes lol. Which reminds me, I need to do it again lol.
Looking good.
Old Jul 30, 2014 | 04:54 AM
  #195
Ive had to cut every one Ive ever taken off. I agree its nice to see that axle under there!
Old Aug 5, 2014 | 05:21 PM
  #196
Installed the high steer,looks good,ordering spring plates and then it will be all buttoned up other than my shock hoops,shocks,and then the spindles.
Old Aug 5, 2014 | 06:17 PM
  #197
Gizler00's Avatar
Awesome buddy!! Looks great.
Old Aug 5, 2014 | 06:35 PM
  #198
Thanks Mark!!!
Old Aug 5, 2014 | 06:39 PM
  #199
Hey Mark,when get your hi steer we can rebuild the axle and setup the preload and install the high steer in probably a day.ten you will just need aligned.
Old Aug 5, 2014 | 06:46 PM
  #200
Gizler00's Avatar
Sounds like a plan to me
