Liveoffroad's '84 4runner build
Old Feb 12, 2013 | 10:15 AM
  #121
rustED's Avatar
thanks Live I appreciate the info on your rear suspension setup... it will probably be awhile before I dig into mine, I'm just trying to gather info to help me to decide what direction I want to go!
Old Feb 12, 2013 | 11:37 AM
  #122
liveoffroad's Avatar
Originally Posted by liveoffroad
1. fix the heater slide-switch (switch is stuck and something broke in there.... i hate screwing with these things)
2. Replace the t-case mount with HD one
3. install my ss brake lines in the front
4. upgrade to 1" bore brake cylinder and possibly bypass the LSV in the back
5. build a spare tire carrier for my receiver hitch
6. swap radiators AGAIN to a factory 7mge radiator
7. build a front bumper
well i'm finishing up #1 right now. decided to go a little crazy while i had my dash apart... i'm putting in a cobra 18 cb and a new stereo head unit. ended up spending a lot more on this than i intended, but i think i'll be much happier with this setup.
picked up some goodies at the local salvage yard
i found the only unmolested radio bezel in the yard!
Old Feb 12, 2013 | 05:52 PM
  #123
rustED's Avatar
nice find on the stereo bezel, that one is in really nice shape, like you said, it's pretty hard to find one that's not all hacked up!
Old Feb 21, 2013 | 10:27 AM
  #124
I picked up a lighted cigarete lighter with the new radio bezel, unfortunately it didn't come with a lighted one originally and the hole is too small. after filing on it for a few minutes, i discovered that there is a steel plate that is pressed into the hole to make the non-lighted plug fit. makes sense from a production standpoint, that way they only have to make 1 radio bezel for both sr5 and base models. so all you need to do the retrofit is a pocket knife and some wire connectors
more pics to come
i also decided to do a horn upgrade. i've always hated toyota horns, so i swiped the horn from a suburban my brother was parting. it was a fairly simple upgrade, i just used a factory toyota relay out of an old wiring harness
Old Mar 1, 2013 | 06:22 AM
  #125
finished up the radio and cb install. i'm pretty happy with how it turned out, looks a lot cleaner
BEFORE:
AFTER:
Old Mar 1, 2013 | 06:28 AM
  #126
Orion22rte's Avatar
Wow that looks clean!!! You've just convinced me to attempt an install like that!
Old Mar 1, 2013 | 02:10 PM
  #127
thanks, now that my interior is starting to come together i'm anxious to get new carpet in there too
Old Mar 1, 2013 | 02:59 PM
  #128
Orion22rte's Avatar
Did you paint the dash plastic? What did you use cuz in the pic it looks like fresh from the factory looking plastic. My entire interior is blue... I'd much prefer a black or at least dark grey interior.
Old Mar 2, 2013 | 12:22 PM
  #129
do you mean the radio bezel or the grey dash trim? the only thing i've painted is the dash pad but its not shown in the pic. i just clean everything with armorall
Old Mar 2, 2013 | 01:04 PM
  #130
Orion22rte's Avatar
That would explain why it looks factory! Lol , yeah, I think the lighting is different too and with the armorall it looks really fresh and clean. Looks really good black tho, I might try to paint my blue dash if I could have it come out pretty decent
Old Mar 8, 2013 | 05:57 AM
  #131
Last night i tried this:
http://www.4x4wire.com/toyota/minutemods/seatbelt/
I even washed it and it still doesn't retract very well, but it did help some.
I also made a tailgate cover plate. I didn't take a before picture, but the old one was a nasty piece of what was once carpet, and the plastic trim was brown. I used SEM graphite paint on the plastic...not sure why it looks blue in these pictures but its actually dark grey
Its made from 11 guage steel. I wanted to go with aluminum since its a lot lighter but i wasn't willing to pay the extra money for it. in the end, i'm glad i went with steel cuz i had to weld and re-drill a couple of the holes haha.
I was afraid of getting some road noise after removing the carpet cover so lined the back of it with this:
Its supposed to be a budget friendly sound deadener, we'll see how well it works
Old Mar 12, 2013 | 12:54 AM
  #132
dark_fairytales's Avatar
question, what made you choose to go with 5.29 gears, and what rpm do you run at 70mph?
Old Mar 12, 2013 | 06:24 AM
  #133
I ran 4.56's with 33s for a long time and wanted a little deeper gearing, so when i went up to 35's i took a bigger step up to 5.29's. I ran some numbers comparing the stock gearing/tire size for the 7mge and it worked out that with 5.29's and 35's it is pretty dang close to factory. my spedo is off maybe 5% at most. it tach's at just over 3k @75mph but i'd say 60% of the highway i drive is 65 mph so it works out pretty well.
Old Mar 12, 2013 | 12:10 PM
  #134
How does it pull up hill in 5th gear, I'm talking 6% grade, or do you shift to 4th?
Old Mar 12, 2013 | 01:15 PM
  #135
i would have to shift to 4th on a 6% grade, even then i'd have trouble holding 75.
Old Mar 13, 2013 | 11:51 AM
  #136
coryc85's Avatar
Man that diamond plate on the tailgate looks good. Saw you put 4.7s in a single case. When you go between obstacles, what do you do shift out of low? I'd love 4.7s, but feel like I'd miss those 2.28s and I'm not too sure I'd want to cut up the floor and put in duals. I made a spreadsheet trying to figure out my speed in each gear with 2.28s versus 4.7s and I'm still not convinced either way. I doubt I'd ever put in duals, so I guess I'd have to live with 4.7.
Old Mar 13, 2013 | 12:47 PM
  #137
Been thinking about On board air for a while now. i found this write up today and it has some good ideas, so i'll save this for later
http://www.f150online.com/forums/art...d-air-how.html
Old Mar 13, 2013 | 12:50 PM
  #138
thanks!
i love the 4.7 singe case. i really don't run accross too many times where i miss the stock low range. with the 7mge i don't need to shift into low unless i'm on an obstacle. it could be a different story with a 22re though
Old Mar 14, 2013 | 05:18 AM
  #139
coryc85's Avatar
thanks!
Ah gotcha, the 7mge is a big difference. For the sandy, muddy stuff here in Florida I have to use low gear quite a lot with the 22re. Thanks for the info, I still might put 4.7s in my case and just try it.
Old Mar 14, 2013 | 08:19 AM
  #140
got my truck back this morning from getting some exhaust work done. 2" mandrel from the manifold back. still need to do the muffler (didn't want to pay them to do it) but so far i'm liking it a lot
x-over- had them put a flange on each side so i can pull the trans
